2018-9-18 03:13 上傳
2018-9-18 03:13 上傳
串口32位delphi上位機(jī)
2018-9-18 03:15 上傳
2018-9-18 03:15 上傳
單片機(jī)下位機(jī)源程序如下:
- #include "reg51.h"
- #include "string.h"
- sbit P3_2=P3^2;
- char receive_data[96];
- char flag;
- char converse=0;
- unsigned char code table[]={
- 0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
- //串口初始化 晶振為11.0592M 方式1 波特率300-57600
- void InitCom(unsigned char BaudRate)
- unsigned char THTL;
- switch (BaudRate)
- case 1: THTL = 64; break; //波特率300
- case 2: THTL = 160; break; //600
- case 3: THTL = 208; break; //1200
- case 4: THTL = 232; break; //2400
- case 5: THTL = 244; break; //4800
- case 6: THTL = 250; break; //9600
- case 7: THTL = 253; break; //19200
- case 8: THTL = 255; break; //57600
- default: THTL = 208;
- SCON = 0x50; //串口方式1,允許接收
- TMOD = 0x20; //定時(shí)器1定時(shí)方式2
- TCON = 0x40; //設(shè)定時(shí)器1開(kāi)始計(jì)數(shù)
- TH1 = THTL;
- TL1 = THTL;
- PCON = 0x80; //波特率加倍控制,SMOD位
- RI = 0; //清收發(fā)標(biāo)志
- TI = 0;
- TR1 = 1; //啟動(dòng)定時(shí)器
- //從串口接收一個(gè)定長(zhǎng)字符串(非中斷方式,只用于字符需有一個(gè)的idata字符串?dāng)?shù)組)
- //如unsigned char *Str;
- //unsigned char i[]="abcd";
- //InHandStr = &i;
- void ComInStr(unsigned char *Str)
- while(*Str !='@') //判斷是否到了字符串的尾部
- while(!RI); //空語(yǔ)句判斷字符是否收完
- *Str = SBUF; //保存字符
- RI = 0; //清RI
- Str++; //字符串指針加一
- converse=1;
- void delay(int c)
- int i,j;
- for(i=0;i<c;i++)
- for(j=0;j<10;j++)
- void delay1s(void)
- unsigned char i,j,k;
- for(k=60;k>0;k--)
- for(i=20;i>0;i--)
- for(j=248;j>0;j--);
- void main()
- unsigned char i,j; //i:每個(gè)字的顯示循環(huán);j每個(gè)字的顯示碼除以2?
- unsigned int b=0; //顯示偏移控制,char類型最多只能顯示14個(gè)漢字+一個(gè)空白位字符
- unsigned char a;//控制移動(dòng)間隔時(shí)間
- InitCom(6);
- EA=1;
- ES=1;
- ET1=0;
- while(1)
- { char i;
- ComInStr(receive_data);
- while(converse)
- j=0;
- if(a>3) //移動(dòng)間隔時(shí)間;取值0--255
- a=0;
- b+=2;
- if(b>=96) //顯示到最后一個(gè)字,回頭顯示,判斷值=字?jǐn)?shù)*32
- b=0;
- P3_2=1;
- for(i=0;i<16;i++)
- P1=i;
- P0=receive_data[j+b];
- P2=receive_data[j+b+1];
- delay(5);
- P0=0x00;
- P2=0x00;
- j+=2;
- P3_2=0;
- for(i=0;i<16;i++)
- P1=i;
- delay(5);
- P0=0x00;
- P2=0x00;
- j+=2;
- a++;
- //串口接收中斷函數(shù)
- //void serial () interrupt 4 using 3
- //ComInStr(receive_data);
- //flag=1;
led大屏幕點(diǎn)陣屏設(shè)計(jì)資料.rar
(378.82 KB, 下載次數(shù): 79)
2018-9-17 10:13 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
