查看: 5781|回復: 4
emWin兩個窗口間的切換程序
ID:382757 發表于 2018-9-14 12:08 | 顯示全部樓層 |閱讀模式
emWin 兩個窗口間的切換
  1. #include "DIALOG.h"
  2. #define ID_FRAMEWIN_0        (GUI_ID_USER + 0x00)
  3. #define ID_BUTTON_0                (GUI_ID_USER + 0x01)
  4. #define ID_BUTTON_1                (GUI_ID_USER + 0x02)
  5. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {        //控件結構體數組
  6.         { FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 0, 0, 320, 240, FRAMEWIN_CF_MOVEABLE, 0x64, 0 },
  7.         { BUTTON_CreateIndirect, "Button", ID_BUTTON_0, 5, 180, 60, 25, 0, 0x0, 0 },
  8.         { BUTTON_CreateIndirect, "Button", ID_BUTTON_1, 75, 180, 60, 25, 0, 0x0, 0 },
  9. };
  10. extern WM_HWIN hPage[4];
  11. static void _cbDialog(WM_MESSAGE * pMsg)
  12. {
  13.         WM_HWIN hItem;
  14.         int                 NCode;
  15.         int                 Id;
  16.         switch (pMsg->MsgId)
  17. {
  18.         case WM_INIT_DIALOG:      //初始化消息,創建窗口/控件時有效,比如在這里設置一些
  19. 控件的初始參數
  20.                 hItem = pMsg->hWin;
  21.                 FRAMEWIN_SetTextAlign(hItem, GUI_TA_LEFT | GUI_TA_VCENTER);
  22.                 FRAMEWIN_SetText(hItem, "Page 0");
  23.                 FRAMEWIN_SetTitleHeight(hItem, 18);
  24.                 FRAMEWIN_SetFont(hItem, GUI_FONT_16B_1);
  25.                 FRAMEWIN_SetTextColor(hItem, (0x008000FF));
  26.                 FRAMEWIN_AddCloseButton(hItem, FRAMEWIN_BUTTON_RIGHT, 0);
  27.                 FRAMEWIN_AddMaxButton(hItem, FRAMEWIN_BUTTON_RIGHT, 0);
  28.                 FRAMEWIN_AddMinButton(hItem, FRAMEWIN_BUTTON_RIGHT, 0);
  29.                 FRAMEWIN_SetClientColor(pMsg->hWin, GUI_GREEN);
  30.                 hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_0);
  31.                 BUTTON_SetText(hItem, "Return");
  32.                 hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_1);
  33.                 BUTTON_SetText(hItem, "Next");
  34.                 break;
  35.         case WM_PAINT:           //窗口重繪消息,這個比較難說明白,反正在Framewin或Window
  36. 窗體之中我們一般是用控
  37.                                           //件,如果要在Framewin或Window窗體之中顯示文字或繪制直線、
  38. 矩形、圓等在這里實現
  39.                 GUI_SetColor(GUI_BLUE);        //設置前景顏色
  40.                 GUI_SetFont((GUI_FONT *)&GUI_Font16_ASCII);                            //設置當前字庫
  41.                 GUI_SetTextMode(GUI_TEXTMODE_TRANS);                                //設置文字透明顯示
  42.                 GUI_DispStringAt("neqee.com", 3, 3);                                        //重繪顯示文字
  43.                 break;
  44.         case WM_NOTIFY_PARENT:          //操作觸發消息處理(操作屏幕程序會跑到這里),
  45. 比如點擊按鍵、點擊編輯框(任何的操作)等等......
  46.                 Id                = WM_GetId(pMsg->hWinSrc);
  47.                 NCode = pMsg->Data.v;
  48.                 switch(Id) {
  49.                 case ID_BUTTON_0:                                                //ID為ID_BUTTON_0的按鍵被點擊
  50.                         switch(NCode)
  51. {
  52.                         case WM_NOTIFICATION_CLICKED:                //按下動作消息
  53.                                 break;
  54.                         case WM_NOTIFICATION_RELEASED:                //彈起動作消息
  55.                                 break;
  56.                         }
  57.                         break;
  58.                 case ID_BUTTON_1:                                                //ID為ID_BUTTON_1的按鍵被點擊
  59.                         switch(NCode)
  60.   {
  61.                         case WM_NOTIFICATION_CLICKED:                //按下動作消息
  62.                                 break;
  63.                         case WM_NOTIFICATION_RELEASED:                //彈起動作消息
  64.                                 WM_HideWindow(hPage[0]);                        //隱藏Page 0
  65.                                 WM_ShowWindow(hPage[1]);                //顯示Page 1
  66.                                 break;
  67.                         }
  68.                         break;
  69.                 }
  70.                 break;
  71.         default:
  72.                 WM_DefaultProc(pMsg);
  73.                 break;
  74.         }
  75. }
  76. static void _cbBackGround(WM_MESSAGE* pMsg)     //桌面背景的回調函數
  77. {
  78. switch (pMsg->MsgId)
  79.         {
  80.         case WM_PAINT:               //窗口重繪消息,這個比較難說明白,反正在Framewin
  81. 或Window窗體之中我們一般是用控
  82.                                                     //件,如果要在Framewin或Window窗體之中顯示文字
  83. 或繪制直線、矩形、圓等在這里實現
  84.                 GUI_SetBkColor(GUI_RED);        //設置背景顏色
  85.                 GUI_Clear();                                                        //清屏
  86.                 break;
  87.         default: WM_DefaultProc(pMsg); break;
  88.         }
  89. }
  90. WM_HWIN CreateFramewin0(WM_HWIN hParent);
  91. WM_HWIN CreateFramewin0(WM_HWIN hParent)
  92. {
  93.         WM_HWIN hWin;
  94.         WM_SetCallback(WM_HBKWIN, _cbBackGround);         //設置桌面背景的回調函數
  95.         hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, hParent, 0, 0);
  96.         return hWin;
  97. }
enWin兩個窗口切換.docx
15.12 KB, 下載次數: 64, 下載積分: 黑幣 -5
ID:1 發表于 2018-9-14 17:32 | 顯示全部樓層
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
ID:108573 發表于 2020-2-9 11:15 | 顯示全部樓層
這種比較耗內存,不過速度快。
ID:701889 發表于 2020-5-13 19:14 | 顯示全部樓層
一個物理按鍵切換多個界面怎么做,哪位有做過?
ID:455905 發表于 2021-7-14 16:29 | 顯示全部樓層
gcs001 發表于 2020-5-13 19:14
大佬搞出來了嗎,我最近也在做這個功能
