查看: 2594|回復: 1
stm32 cube編寫的AD采集加串口屏顯示
ID:336427 發表于 2018-9-13 20:34 | 顯示全部樓層 |閱讀模式
adc.c
  * File Name          : ADC.c
  * Description        : This file provides code for the configuration
  *                      of the ADC instances.
  ** This notice applies to any and all portions of this file
  * that are not between comment pairs USER CODE BEGIN and
  * USER CODE END. Other portions of this file, whether
  * inserted by the user or by software development tools
  * are owned by their respective copyright owners.
  * COPYRIGHT(c) 2018 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
#include "adc.h"
#include "gpio.h"
#include "dma.h"
/* USER CODE BEGIN 0 */
#include "sys.h"
/* USER CODE END 0 */
ADC_HandleTypeDef hadc1;
DMA_HandleTypeDef hdma_adc1;
/* ADC1 init function */
void MX_ADC1_Init(void)
  ADC_ChannelConfTypeDef sConfig;
    /**Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
  hadc1.Init.ContinuousConvMode = ENABLE;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.NbrOfConversion = 6;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
    /**Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_10;
  sConfig.Rank = ADC_REGULAR_RANK_1;
  sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
  sConfig.Channel = ADC_CHANNEL_11;
  sConfig.Rank = ADC_REGULAR_RANK_2;
  sConfig.Channel = ADC_CHANNEL_12;
  sConfig.Rank = ADC_REGULAR_RANK_3;
  sConfig.Channel = ADC_CHANNEL_13;
  sConfig.Rank = ADC_REGULAR_RANK_4;
  sConfig.Channel = ADC_CHANNEL_14;
  sConfig.Rank = ADC_REGULAR_RANK_5;
  sConfig.Channel = ADC_CHANNEL_15;
  sConfig.Rank = ADC_REGULAR_RANK_6;
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(adcHandle->Instance==ADC1)
  /* USER CODE BEGIN ADC1_MspInit 0 */
  /* USER CODE END ADC1_MspInit 0 */
    /* ADC1 clock enable */
    __HAL_RCC_ADC1_CLK_ENABLE();
    /**ADC1 GPIO Configuration
    PC0     ------> ADC1_IN10
    PC1     ------> ADC1_IN11
    PC2     ------> ADC1_IN12
    PC3     ------> ADC1_IN13
    PC4     ------> ADC1_IN14
    PC5     ------> ADC1_IN15
    GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
                          |GPIO_PIN_4|GPIO_PIN_5;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
    HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
    /* ADC1 DMA Init */
    /* ADC1 Init */
    hdma_adc1.Instance = DMA1_Channel1;
    hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;
    hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
    hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
    hdma_adc1.Init.Mode = DMA_NORMAL;
    hdma_adc1.Init.Priority = DMA_PRIORITY_LOW;
    if (HAL_DMA_Init(&hdma_adc1) != HAL_OK)
    __HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc1);
  /* USER CODE BEGIN ADC1_MspInit 1 */
  /* USER CODE END ADC1_MspInit 1 */
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
  /* USER CODE BEGIN ADC1_MspDeInit 0 */
  /* USER CODE END ADC1_MspDeInit 0 */
    /* Peripheral clock disable */
    __HAL_RCC_ADC1_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOC, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
                          |GPIO_PIN_4|GPIO_PIN_5);
    /* ADC1 DMA DeInit */
    HAL_DMA_DeInit(adcHandle->DMA_Handle);
  /* USER CODE BEGIN ADC1_MspDeInit 1 */
  /* USER CODE END ADC1_MspDeInit 1 */
/* USER CODE BEGIN 1 */
//cube調用ADC有始有終
void readadcdma(u32 * advalue){
        //ADC啟動函數
        HAL_ADC_Start_DMA(&hadc1,(uint32_t*)advalue,6);
        HAL_Delay(10);
        //ADC停止函數
        HAL_ADC_Stop_DMA(&hadc1);
//讀取ADC的值,所有已設定通道
void readadc(u32 * advalue){
        *advalue = HAL_ADC_GetValue(&hadc1);
/* USER CODE END 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
hmi.c
#include "stdio.h"
#include "usart.h"
#include "string.h"
#include "hmi.h"
//切記串口屏默認波特率是9600
void hmi(char* hmistr)
        char end[3]={0xff,0xff,0xff};
        HAL_UART_Transmit_DMA(&huart1,hmistr,strlen(hmistr));
        HAL_Delay(100);
        HAL_UART_Transmit_DMA(&huart1,end,3);
        HAL_Delay(100);
main.c
  * @file           : main.c
  * @brief          : Main program body
#include "main.h"
#include "stm32f1xx_hal.h"
#include "adc.h"
#include "dma.h"
#include "usart.h"
#include "gpio.h"
/* USER CODE BEGIN Includes */
#include "stdio.h"
#include "sys.h"
#include "hmi.h"
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
uint8_t aRxBuffer[20];
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_NVIC_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
  * @brief  The application entry point.
  * @retval None
int main(void)
//        char a[] = {"lilei666666\r\n"};
        char str[50];
        u32 uhADCxConvertedValue[5];
        float ADC1_1;
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_USART1_UART_Init();
  MX_USART2_UART_Init();
  MX_ADC1_Init();
  /* Initialize interrupts */
  MX_NVIC_Init();
  /* USER CODE BEGIN 2 */
        HAL_UART_Receive_DMA(&huart1, UsartType.RX_pData, RX_LEN);
        __HAL_UART_ENABLE_IT(&huart1, UART_IT_IDLE);
        HAL_UART_Receive_DMA(&huart2, UsartType.RX_pData, RX_LEN);
        __HAL_UART_ENABLE_IT(&huart2, UART_IT_IDLE);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
//        HAL_UART_Transmit_IT(&huart1,"strat!\r\n",9);
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
                    readadcdma(uhADCxConvertedValue);//讀取ADC各個通道數據
                  ADC1_1 = uhADCxConvertedValue[0]*3.3/4096;
//                HAL_UART_Transmit(&huart4,"start!\r\n",9,UINT16_MAX);
          if((ADC1_1 >= 0.7)&&(ADC1_1<= 1))
                  sprintf(str,"t1.txt=\"%f\"",ADC1_1-0.7);
                hmi(str);
          else if(ADC1_1>1)
                hmi(str);
//                if(UsartType.RX_flag)            // Receive flag
//                        UsartType.RX_flag=0;        // clean flag
//                        HAL_UART_Transmit(&huart1, UsartType.RX_pData, UsartType.RX_Size, 0xFFFF);
//                switch(UsartType.RX_pData[0])
//                        //全亮
//                        case '1':
////                                        HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_0);
//                                HAL_GPIO_WritePin(GPIOB, LED0_Pin|LED1_Pin|LED2_Pin, GPIO_PIN_RESET);
//                                break;
//                        case '2':
//                                HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_1);
//                                break;
//                        case '3':
//                                HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_5);
//                                break;
//                //UsartType.RX_pData[RX_LEN] = '\0';
                HAL_Delay(1000);
  /* USER CODE END 3 */
雙串口+AD.rar
9.57 MB, 下載次數: 20, 下載積分: 黑幣 -5
cube編寫的ad和串口屏程序
ID:1 發表于 2018-9-13 22:25 | 顯示全部樓層
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
