我的顯示為什么不正常,錯(cuò)在了哪里啊?程序如下
- #include <reg52.h>
- #include <string.h>
- #include "zf.h"
- #include "io.h"
- #define uchar unsigned char
- #define uint unsigned int
- uchar ye=0,lie=0;
- #define DB P0
- #define chr_width 7
- #define chn_width 15
- unsigned char disp_no;
- unsigned char position,which;
- /*****************************延時(shí)*************************/
- void delay(uint i)
- while(--i);
- /****************12864液晶寫數(shù)據(jù)命令地址函數(shù)*****************/
- void writedacm(uchar dat,uchar log) //寫數(shù)據(jù) RS=1數(shù)據(jù),RS=0命令
- delay(8);
- RW = 0;
- if(log) RS=1;
- else RS=0;
- E = 1;
- DB = dat;
- E = 0;
- /************************頁列設(shè)置*************************/
- void set_YL( uchar y, uchar x) //ye -> 0 : 7 頁 lie -> 0 :63 列
- y= y&0x07|0xb8;
- writedacm(y,0);
- x= x&0x3f|0x40;
- writedacm(x,0);
- /*************************12864液晶屏幕選擇函數(shù)************/
- void setPM(uchar PX) //選擇屏幕( 0-左屏,1-右屏,2-全屏 )
- switch(PX){
- case 0 : CS1 = 0; CS2 = 1; break;
- case 1 : CS1 = 1; CS2 = 0; break;
- case 2 : CS1 = 0; CS2 = 0;
- /******************左右屏設(shè)置*************************/
- void chear() //清屏(0-清左屏1-清右屏,2-清全屏 ),
- { uchar i,j;
- setPM(2);
- for(i = 0;i <8;i++)
- { set_YL(i,0);
- for(j = 0;j <64 ; j++)
- writedacm(0x00,1);
- void SetOnOff(uchar onoff) //1-開顯示 0-關(guān)
- if(onoff == 1){ setPM(2); writedacm(0x3f,0);}
- if(onoff == 0){ setPM(2); writedacm(0x3e,0);}
- /******************** 12864液晶復(fù)位函數(shù)******************/
- void init_lcd()
- Reset = 0; delay(2);
- Reset = 1; delay(2);
- chear(); //清屏
- SetOnOff(1) ;
- delay(100);
- CS1=1; //剛開始關(guān)閉兩屏
- CS2=1;
- delay(100);
- writedacm(0x3e,0); //顯示關(guān)
- writedacm(0xb8,0); //定義Y坐標(biāo)
- writedacm(0xC0,0);
- writedacm(0x40,0); //設(shè)定X坐標(biāo)
- writedacm(0x3f,0); //顯示開
- void DrawBmp(uchar x0,bit layer,uchar width,uchar *bmp)
- uchar x,i=0,j=16; //RAMadr表示顯存的物理地址
- uchar page=0;
- delay(10);
- if (layer) page=2;
- delay(10);
- for (x=x0;x<(x0+width);x++)
- delay(10);
- setPM(0);//顯示左半屏
- writedacm(0xb8,0);//從第一行開始顯示
- writedacm(bmp,1);//寫第一行字上半部分
- i=i+1;
- delay(10);
- setPM(0);
- writedacm(0xb8+1,0);//從第一行開始顯示
- writedacm(bmp[j],1);//寫第一行字下半部分
- j=j+1;
- #define welcome_hanzi 6
- void disp_welcome(void)
- unsigned char cyc_counter;
- delay(10);
- for(cyc_counter=0; cyc_counter<6; cyc_counter++)
- delay(10);
- DrawBmp(16+cyc_counter*chn_width,0,chn_width,chn_font+(cyc_counter+welcome_hanzi)*chn_width*2);
- delay(10);
- disp_no = 0x00;
- /**********************主函數(shù)*****************************/
- main()
- init_lcd();
- chear();
- disp_welcome();
- while(1);
- /*******************下面是字庫摸******************************/
- //漢字用的字號是五號字
- unsigned char code chn_font[]={
- 無(0) 池(1) 流(2) 壓(3) 容(4) 量(5)
- 新(6) 鄉(xiāng)(7) 安(8) 科(9) 電(10) 子(11) ----這里的6個(gè)漢字必須是連續(xù)的,給顯示公司用
- 型(12) 號(13) 異(14) 充(15) 放(16) 次(17)
- 數(shù)(18) 生(19) 產(chǎn)(20) 額(21) 定(22) 編(23)
- 常(24) 滿(25) 低(26) 溫(27) 度(28) 非(29)
- 字(30) 日(31) 期(32) 鎘(33) 鎳(34) 鋰(35)
- /*-- 文字: 無0 --*/
- /*-- 宋體11; 此字體下對應(yīng)的點(diǎn)陣為:寬x高=15x15 --*/
- /*-- 高度不是8的倍數(shù),現(xiàn)調(diào)整為:寬度x高度=15x16 --*/
- 0x00,0x22,0x22,0x22,0x22,0x22,0xFE,0x22,0xE2,0x22,0x22,0x23,0x32,0x20,0x00,0x00,
- 0x20,0x20,0x10,0x08,0x06,0x01,0x00,0x1F,0x20,0x20,0x20,0x20,0x3C,0x00,
- /*-- 文字: 池1 --*/
- 0x10,0x61,0x86,0x60,0x40,0xFC,0x20,0x20,0xFF,0x10,0x10,0xF8,0x10,0x00,0x00,0x02,
- 0x3E,0x01,0x00,0x00,0x1F,0x20,0x20,0x27,0x20,0x22,0x23,0x20,0x38,0x00,
- /*-- 文字: 流2 --*/
- 0x10,0x61,0x02,0xC6,0x00,0xA4,0x34,0x2D,0xA6,0x24,0xA4,0x34,0x66,0x04,0x00,0x04,
- 0x3C,0x03,0x20,0x10,0x0F,0x00,0x00,0x3F,0x00,0x1F,0x20,0x20,0x38,0x00,
- /*-- 文字: 壓3 --*/
- 0x00,0x00,0xFE,0x02,0x42,0x42,0x42,0xFA,0x42,0x42,0x42,0x42,0x03,0x02,0x00,0x20,
- 0x18,0x07,0x10,0x10,0x10,0x10,0x1F,0x10,0x10,0x11,0x16,0x10,0x10,0x00,
- /*-- 文字: 容4 --*/
- 0x10,0x4C,0x44,0x24,0x94,0x44,0x25,0x26,0x44,0x84,0x14,0x24,0x4C,0x04,0x00,0x04,
- 0x04,0x02,0x01,0x3E,0x22,0x22,0x22,0x22,0x22,0x3F,0x01,0x02,0x02,0x00,
- /*-- 文字: 量5 --*/
- 0x00,0x20,0x20,0xBE,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xBF,0x22,0x20,0x00,0x00,
- 0x20,0x28,0x2F,0x2A,0x2A,0x2A,0x3F,0x2A,0x2A,0x2A,0x2F,0x28,0x20,0x00,
- /*-- 文字: 新6 --*/
- 0x20,0x24,0x2C,0x35,0xE6,0x34,0x2C,0x00,0xFE,0x24,0x24,0xE2,0x33,0x22,0x00,0x10,
- 0x09,0x15,0x21,0x1F,0x05,0x29,0x10,0x0F,0x00,0x00,0x3F,0x00,0x00,0x00,
- /*-- 文字: 鄉(xiāng)7 --*/
- 0x00,0x00,0x00,0x10,0x18,0x94,0x52,0x31,0x10,0x08,0x04,0xC0,0x00,0x00,0x00,0x00,
- 0x20,0x20,0x21,0x21,0x11,0x11,0x09,0x05,0x03,0x01,0x00,0x00,0x00,0x00,
- /*-- 文字: 安8 --*/
- 0x40,0x50,0x4C,0x44,0x44,0xC4,0x75,0x46,0x44,0xC4,0x44,0x54,0x4C,0x40,0x00,0x00,
- 0x20,0x20,0x20,0x13,0x12,0x0C,0x04,0x06,0x09,0x08,0x10,0x30,0x00,0x00,
- /*-- 文字: 科9 --*/
- 0x14,0x14,0x94,0xFE,0x93,0x12,0x00,0x20,0xC4,0x18,0x00,0xFF,0x00,0x00,0x00,0x04,
- 0x03,0x00,0x3F,0x00,0x01,0x02,0x02,0x02,0x02,0x02,0x3F,0x01,0x01,0x00,
- /*-- 文字: 電10 --*/
- 0x00,0x00,0xF8,0x48,0x48,0x48,0xFF,0x48,0x48,0x48,0x48,0xFC,0x08,0x00,0x00,0x00,
- 0x00,0x07,0x02,0x02,0x02,0x1F,0x22,0x22,0x22,0x22,0x23,0x20,0x38,0x00,
- /*-- 文字: 子11 --*/
- 0x40,0x40,0x42,0x42,0x42,0x42,0x42,0xF2,0x52,0x4A,0x46,0x43,0x62,0x40,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x10,0x20,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: 型12 --*/
- 0x00,0x12,0x92,0x7E,0x12,0x12,0xFE,0x12,0x00,0x7E,0x80,0x00,0xFF,0x00,0x00,0x00,
- 0x21,0x24,0x24,0x24,0x24,0x25,0x3E,0x24,0x24,0x24,0x25,0x30,0x20,0x00,
- /*-- 文字: 號13 --*/
- 0x40,0x40,0x40,0x5E,0xD2,0x52,0x52,0x52,0x52,0x52,0x5F,0x42,0x40,0x40,0x00,0x00,
- 0x00,0x00,0x02,0x03,0x01,0x11,0x21,0x21,0x11,0x0F,0x00,0x00,0x00,0x00,
- /*-- 文字: 異14 --*/
- 0x00,0x00,0x00,0x3E,0xD2,0x52,0x52,0x52,0x52,0xD2,0x5F,0x42,0x70,0x00,0x00,0x22,
- 0x22,0x12,0x0A,0x07,0x02,0x02,0x02,0x02,0x3F,0x02,0x02,0x02,0x02,0x00,
- /*-- 文字: 充15 --*/
- 0x00,0x04,0x44,0x44,0x64,0xD4,0x4D,0x46,0xC4,0x54,0x64,0xC4,0x06,0x04,0x00,0x00,
- 0x20,0x10,0x08,0x04,0x03,0x00,0x00,0x1F,0x20,0x20,0x20,0x20,0x38,0x00,
- /*-- 文字: 放16 --*/
- 0x08,0x08,0xF9,0x4E,0x48,0xC8,0x08,0x20,0xF8,0x0F,0x08,0xF8,0x0C,0x08,0x00,0x20,
- 0x18,0x07,0x10,0x10,0x0F,0x20,0x20,0x10,0x09,0x06,0x09,0x10,0x20,0x00,
- /*-- 文字: 次17 --*/
- 0x00,0x02,0x8C,0x60,0x98,0x40,0x30,0x0F,0xE8,0x08,0x08,0x28,0x18,0x00,0x00,0x01,
- 0x01,0x1F,0x20,0x20,0x10,0x0C,0x03,0x00,0x03,0x04,0x08,0x30,0x10,0x00,
- /*-- 文字: 數(shù)18 --*/
- 0x08,0x4A,0x2C,0x18,0xFF,0x2C,0x4A,0x28,0xF0,0x0F,0x08,0x88,0x7C,0x08,0x00,0x21,
- 0x21,0x15,0x17,0x09,0x0D,0x13,0x20,0x10,0x0B,0x04,0x0B,0x10,0x20,0x00,
- /*-- 文字: 生19 --*/
- 0x80,0x40,0x30,0x1E,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x18,0x10,0x00,0x00,0x20,
- 0x20,0x20,0x21,0x21,0x21,0x21,0x3F,0x21,0x21,0x21,0x21,0x30,0x20,0x00,
- /*-- 文字: 產(chǎn)20 --*/
- 0x00,0x04,0xC4,0x44,0x4C,0x74,0x45,0x46,0x64,0x5C,0x44,0x44,0x44,0x44,0x00,0x20,
- 0x18,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: 額21 --*/
- 0x4C,0x24,0xBC,0x55,0x56,0xB4,0x0C,0xFA,0x0A,0x0E,0xEA,0x0A,0xFB,0x02,0x00,0x02,
- 0x01,0x3E,0x12,0x12,0x1E,0x21,0x27,0x10,0x08,0x07,0x08,0x17,0x20,0x00,
- /*-- 文字: 定22 --*/
- 0x00,0x10,0x2C,0xA4,0x24,0x24,0x25,0xE6,0x24,0x24,0x24,0x24,0x14,0x0C,0x00,0x20,
- 0x10,0x08,0x07,0x08,0x10,0x10,0x3F,0x22,0x22,0x22,0x22,0x20,0x20,0x00,
- /*-- 文字: 編23 --*/
- 0x20,0xB8,0x67,0x30,0x00,0xFC,0xD4,0x54,0xD5,0x56,0xD4,0x54,0xDC,0x00,0x00,0x09,
- 0x1B,0x09,0x25,0x18,0x07,0x3F,0x02,0x1F,0x02,0x1F,0x22,0x3F,0x00,0x00,
- /*-- 文字: 常24 --*/
- 0x20,0x18,0x08,0x0A,0xEC,0xA8,0xA8,0xAF,0xA8,0xA8,0xEC,0x0A,0x28,0x18,0x00,0x00,
- 0x00,0x00,0x1E,0x02,0x02,0x02,0x3F,0x02,0x02,0x12,0x1E,0x00,0x00,0x00,
- /*-- 文字: 滿25 --*/
- 0x10,0x61,0x86,0x60,0xA4,0xA4,0xA4,0xEF,0xA4,0xE4,0xAF,0xA4,0xB6,0x24,0x00,0x02,
- 0x3E,0x01,0x00,0x3F,0x08,0x04,0x03,0x0A,0x07,0x12,0x24,0x1F,0x00,0x00,
- /*-- 文字: 低26 --*/
- 0x40,0x20,0xF8,0x07,0x00,0xFC,0x44,0x44,0x44,0xFC,0x42,0x43,0x62,0x40,0x00,0x00,
- 0x00,0x3F,0x00,0x00,0x1F,0x10,0x08,0x14,0x21,0x06,0x08,0x10,0x3C,0x00,
- /*-- 文字: 溫27 --*/
- 0x10,0x61,0x86,0x60,0x00,0x7E,0x4A,0x4A,0x4A,0x4A,0x4A,0x7F,0x02,0x00,0x00,0x02,
- 0x3E,0x01,0x20,0x3F,0x21,0x21,0x3F,0x21,0x3F,0x21,0x21,0x3F,0x20,0x00,
- /*-- 文字: 度28 --*/
- 0x00,0x00,0xFC,0x04,0x14,0x14,0x7C,0x55,0x56,0x54,0x7C,0x14,0x16,0x04,0x00,0x20,
- 0x18,0x07,0x20,0x21,0x21,0x13,0x15,0x09,0x15,0x13,0x21,0x20,0x20,0x00,
- /*-- 文字: 非29 --*/
- 0x08,0x48,0x48,0x48,0x48,0xFF,0x00,0x00,0xFF,0x48,0x48,0x48,0x4C,0x08,0x00,0x04,
- 0x04,0x04,0x04,0x04,0x3F,0x00,0x00,0x3F,0x04,0x04,0x04,0x06,0x04,0x00,
- /*-- 文字: 字30 --*/
- 0x00,0x10,0x0C,0x14,0x14,0x14,0x15,0xD6,0x54,0x34,0x14,0x14,0x8C,0x00,0x00,0x01,
- 0x01,0x01,0x01,0x01,0x11,0x21,0x1F,0x01,0x01,0x01,0x01,0x01,0x01,0x00,
- /*-- 文字: 日31 --*/
- 0x00,0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0xFF,0x02,0x00,0x00,0x00,
- 0x00,0x00,0x3F,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x3F,0x00,0x00,0x00,
- /*-- 文字: 期32 --*/
- 0x00,0x04,0xFF,0x94,0x94,0xFF,0x04,0x00,0xFE,0x12,0x12,0x12,0xFF,0x02,0x00,0x22,
- 0x12,0x0B,0x06,0x02,0x07,0x2A,0x10,0x0F,0x01,0x11,0x21,0x1F,0x00,0x00,
- /*-- 文字: 鎘33 --*/
- 0x60,0x38,0xE7,0x24,0x24,0x00,0x82,0xBA,0xAA,0xAA,0xAA,0xBA,0x83,0x02,0x00,0x01,
- 0x01,0x3F,0x11,0x09,0x01,0x3F,0x04,0x06,0x1C,0x06,0x24,0x3F,0x00,0x00,
- /*-- 文字: 鎳34 --*/
- 0x60,0x38,0xE7,0x24,0x24,0x00,0xFE,0xAA,0xAB,0xAA,0xAA,0xFE,0x00,0x00,0x00,0x01,
- 0x01,0x1F,0x11,0x29,0x12,0x0A,0x06,0x02,0x3F,0x06,0x0A,0x12,0x22,0x00,
- /*-- 文字: 鋰35 --*/
- 0x60,0x38,0xE7,0x24,0x24,0x00,0xFE,0x92,0x92,0xFE,0x92,0x92,0xFF,0x02,0x00,0x01,
- 0x01,0x3F,0x11,0x09,0x21,0x24,0x24,0x24,0x3F,0x24,0x24,0x24,0x20,0x00,
- /*-- 文字: 記36 --*/
- 0x20,0x20,0x21,0xE6,0x00,0x00,0xC4,0x44,0x44,0x44,0x44,0x44,0x7E,0x04,0x00,0x00,
- 0x00,0x00,0x1F,0x08,0x04,0x1F,0x20,0x20,0x20,0x20,0x20,0x20,0x3C,0x00,
- /*-- 文字: 錄37 --*/
- 0x20,0x20,0xA2,0xAA,0x2A,0x2A,0x2A,0xEA,0x2A,0x2A,0x3F,0xA2,0x20,0x20,0x00,0x10,
- 0x10,0x08,0x08,0x05,0x12,0x22,0x1F,0x01,0x02,0x05,0x08,0x18,0x08,0x00
