本帖最后由 lenmon13 于 2018-9-9 14:18 編輯
HC6800-ES V2.0.pdf
(404.98 KB, 下載次數: 35)
2018-9-9 01:15 上傳
stc89c52超聲波測距怎么接線和程序是什么?買開發板給的程序和接線要求 Trig ------- P2^1; Echo ------- P2^0; VCC -------- +5v GND -------- GND
我接上去了,程序也燒錄進去了 就是液晶屏沒有顯示。
#include"lcd.h"
void Read_Busy() //忙檢測函數,判斷bit7是0,允許執行;1禁止
unsigned char sta; //
LCD1602_DB = 0xff;
LCD1602_RS = 0;
LCD1602_RW = 1;
do
LCD1602_EN = 1;
sta = LCD1602_DB;
LCD1602_EN = 0; //使能,用完就拉低,釋放總線
}while(sta & 0x80);
void Lcd1602_Write_Cmd(unsigned char cmd) //寫命令
Read_Busy();
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_DB = cmd;
LCD1602_EN = 1;
LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat) //寫數據
Read_Busy();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_EN = 1;
LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y) //坐標顯示
unsigned char addr;
if(y == 0)
addr = 0x00 + x;
addr = 0x40 + x;
Lcd1602_Write_Cmd(addr|0x80);
//按指定位置顯示一個字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
X |= 0x80; //算出指令碼
Lcd1602_Write_Cmd(X); //發命令字
Lcd1602_Write_Data(DData); //發數據
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str) //顯示字符串
LcdSetCursor(x,y); //當前字符的坐標
while(*str != '\0')
Lcd1602_Write_Data(*str++);
void InitLcd1602() //1602初始化
Lcd1602_Write_Cmd(0x38); //打開,5*8,8位數據
Lcd1602_Write_Cmd(0x0c);
Lcd1602_Write_Cmd(0x06);
Lcd1602_Write_Cmd(0x01); //清屏
