查看: 8156|回復: 10
無字庫LCD12864液晶同時顯示大小漢字,有圖有單片機程序含全部資料
近日從電路板上拆下一批無字庫的LCD12864液晶屏,為了測試屏的好壞,特地寫了測試程序,結果幾十塊屏全部都是好的!
先來看看實物圖片
正面
背面
引腳功能
時序圖與LCD1602一樣
大漢字取模方法
最終效果圖
只要加入時間和18B20溫度傳感器,就成時鐘和溫度計
部分主要程序
12864初始化:
lcd12864.c
  1.   sbit e=P3^4;
  2.   sbit rw=P3^6;
  3.   sbit rs=P3^5;
  4.   sbit cs1=P3^7;
  5.   sbit cs2=P3^3;
  6.   sbit duan=P2^7;  //定義74H373的控制引腳,
  7.   sbit wei=P2^6;
  8.   void lcd12864_write_com(uchar com) //寫指令
  9.   {
  10.   rs=0;rw=0;e=0;
  11.   P0=com;
  12.   e=1;
  13.   delay(5);
  14.   e=0;
  15.   }
  16.   void lcd12864_write_date(uchar date)//寫數據
  17.   {
  18.   rs=1;rw=0;e=0;
  19.   P0=date;
  20.   e=1;
  21.   delay(5);
  22.   e=0;
  23.   }
  24.   void lcd12864_init()        //初始化
  25.   {
  26.    lcd12864_write_com(0xc0); //行的初始化地址
  27.    lcd12864_write_com(0xb8);//頁的初始化地址
  28.    lcd12864_write_com(0x40);//列的初始化地址
  29.    lcd12864_write_com(0x3f);//打開屏幕        ,關閉是3e
  30.   }
  31.   void clear_lcd12864()        //清屏
  32.   {
  33.    uchar i,j;
  34.    cs1=1;cs2=1;         //打開左右兩屏,實物  注意:LCD12864實物是CS1=1;CS2=1為打開,
  35.    for(i=0;i<8;i++)          //共8頁
  36.    {
  37.    lcd12864_write_com(0xb8+i);//頁的初始化地址
  38.    lcd12864_write_com(0x40);//列的初始化地址
  39.    for(j=0;j<64;j++)  //共64列
  40.    {
  41.    lcd12864_write_date(0x00);
  42.    }
  43.    }
  44.   }
12864顯示程序:
lcd12864dis.c
  1. /***********大漢字數組,取模方式32X32*****************/
  2. uchar code tab[][128]={
  3. //好好學習天天向上
  4.   /***********0-好*****************/
  5. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0x78,0x08,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xA0,0xE0,0x70,0x60,0x00,0x00,0x00,0x00,
  6. 0x00,0x02,0x02,0x02,0x02,0xE2,0xFF,0x0F,0x02,0x02,0x02,0xF2,0xFF,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0xFC,0x02,0x01,0x00,0x00,0x00,0x80,0x00,0x00,0x00,
  7. 0x00,0x00,0x00,0x20,0x3C,0x27,0x40,0x40,0xC0,0xE0,0xFE,0x8F,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0xFF,0xFF,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x00,0x00,
  8. 0x00,0x40,0x40,0x20,0x10,0x08,0x0C,0x06,0x03,0x01,0x01,0x03,0x07,0x0E,0x00,0x00,0x10,0x10,0x30,0x30,0x70,0x3F,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"好",0*/
  9.    /***********1-好*****************/
  10. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0x78,0x08,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xA0,0xE0,0x70,0x60,0x00,0x00,0x00,0x00,
  11. 0x00,0x02,0x02,0x02,0x02,0xE2,0xFF,0x0F,0x02,0x02,0x02,0xF2,0xFF,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0xFC,0x02,0x01,0x00,0x00,0x00,0x80,0x00,0x00,0x00,
  12. 0x00,0x00,0x00,0x20,0x3C,0x27,0x40,0x40,0xC0,0xE0,0xFE,0x8F,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0xFF,0xFF,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x00,0x00,
  13. 0x00,0x40,0x40,0x20,0x10,0x08,0x0C,0x06,0x03,0x01,0x01,0x03,0x07,0x0E,0x00,0x00,0x10,0x10,0x30,0x30,0x70,0x3F,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"好",1*/
  14. /***********2-學*****************/
  15. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x70,0xE0,0xC0,0x00,0x00,0x04,0x38,0xF0,0xE0,0x00,0x00,0x00,0x00,0xC0,0x70,0x3C,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  16. 0x00,0x00,0x00,0x60,0x7C,0x3C,0x04,0x84,0x84,0x85,0x85,0x84,0x84,0x84,0x84,0x85,0x84,0x84,0x84,0x84,0x87,0xC5,0xC4,0x84,0x04,0x24,0x14,0x1E,0x0E,0x04,0x00,0x00,
  17. 0x00,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xFC,0xF8,0x24,0x24,0x22,0x21,0x21,0x20,0x20,0x20,0x20,0x30,0x38,0x30,0x20,0x00,0x00,
  18. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x10,0x30,0x70,0x3F,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"學",2*/
  19.   /***********3-習*****************/
  20. {0x00,0x00,0x00,0x00,0x20,0x60,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xE0,0xF0,0x20,0x00,0x00,0x00,0x00,0x00,
  21. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x04,0x0C,0x18,0x78,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
  22. 0x00,0x00,0x00,0x80,0x80,0x80,0x80,0xC0,0xC0,0xC0,0x60,0x20,0x30,0x10,0x10,0x08,0x08,0x04,0x04,0x02,0x02,0x02,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
  23. 0x00,0x00,0x00,0x00,0x01,0x03,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x08,0x08,0x08,0x18,0x38,0x38,0x1F,0x07,0x00,0x00,0x00,0x00,0x00,0x00},/*"習",3*/
  24. /***********4-天*****************/
  25. {0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xE0,0xE0,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x30,0x38,0x30,0x20,0x00,0x00,0x00,0x00,0x00,
  26. 0x00,0x00,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0xFF,0xFF,0x40,0xC0,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x60,0x70,0x60,0x40,0x00,0x00,0x00,
  27. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0x70,0x3E,0x0F,0x00,0x00,0x03,0x0C,0x30,0xE0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  28. 0x00,0x00,0x40,0x40,0x20,0x30,0x10,0x08,0x04,0x06,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x06,0x0E,0x1C,0x38,0x38,0x10,0x10,0x10,0x00},/*"天",4*/
  29.   /***********5-天*****************/
  30. {0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xE0,0xE0,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x30,0x38,0x30,0x20,0x00,0x00,0x00,0x00,0x00,
  31. 0x00,0x00,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0xFF,0xFF,0x40,0xC0,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x60,0x70,0x60,0x40,0x00,0x00,0x00,
  32. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0x70,0x3E,0x0F,0x00,0x00,0x03,0x0C,0x30,0xE0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  33. 0x00,0x00,0x40,0x40,0x20,0x30,0x10,0x08,0x04,0x06,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x06,0x0E,0x1C,0x38,0x38,0x10,0x10,0x10,0x00},/*"天",5*/
  34.   /***********6-向*****************/
  35. {0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x3C,0x1C,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x80,0x00,0x00,0x00,0x00,
  36. 0x00,0x00,0x00,0x00,0x00,0xFF,0x01,0x01,0x01,0x01,0x01,0xE1,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0xC1,0xE1,0x41,0x01,0x01,0x01,0x01,0xFF,0xFF,0x00,0x00,0x00,0x00,
  37. 0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0xFF,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,
  38. 0x00,0x00,0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x10,0x10,0x10,0x30,0x78,0x3F,0x0F,0x00,0x00,0x00,0x00},/*"向",6*/
  39.   /***********7-上*****************/
  40. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  41. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x30,0x38,0x30,0x20,0x00,0x00,0x00,0x00,0x00,
  42. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  43. 0x00,0x00,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x1F,0x1F,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x18,0x1C,0x1C,0x18,0x10,0x00},/*"上",7*/
  44. };
  45. /***********標準漢字數組,取模方式16X16*****************/
  46. uchar code tab_biao[][32]={
  47. /*********0-----好***************/
  48. {0x00,0x10,0x10,0xF0,0x1F,0x10,0xF0,0x00,0x80,0x82,0x82,0xE2,0x92,0x8A,0x86,0x80,
  49. 0x00,0x40,0x22,0x15,0x08,0x16,0x61,0x00,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,0x00},
  50. /*********1-----好***************/
  51. {0x00,0x10,0x10,0xF0,0x1F,0x10,0xF0,0x00,0x80,0x82,0x82,0xE2,0x92,0x8A,0x86,0x80,
  52. 0x00,0x40,0x22,0x15,0x08,0x16,0x61,0x00,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,0x00},
  53. /*********2-----學***************/
  54. {0x00,0x40,0x30,0x11,0x96,0x90,0x90,0x91,0x96,0x90,0x90,0x98,0x14,0x13,0x50,0x30,
  55. 0x00,0x04,0x04,0x04,0x04,0x04,0x44,0x84,0x7E,0x06,0x05,0x04,0x04,0x04,0x04,0x04},
  56. /*********3-----習***************/
  57. {0x00,0x00,0x02,0x02,0x02,0x12,0x22,0xC2,0x02,0x02,0x02,0x02,0x02,0xFE,0x00,0x00,
  58. 0x00,0x00,0x08,0x18,0x08,0x04,0x04,0x04,0x02,0x02,0x41,0x81,0x40,0x3F,0x00,0x00},
  59. /*********4-----“:”***************/
  60. {0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  61. 0x00,0x00,0x00,0x00,0x7B,0x7B,0x7B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
  62.   /*********5-----心形***************/
  63. {0x00,0xE0,0x10,0x10,0x10,0x30,0x40,0x80,0x80,0x40,0x20,0x10,0x10,0x10,0xF0,0x00,
  64. 0x00,0x03,0x04,0x08,0x10,0x20,0x20,0x40,0x40,0x20,0x20,0x10,0x08,0x04,0x03,0x00},
  65. };
  66.   /*********小數字數組:半列顯示,取模方式16X8***************/
  67. uchar code tab_banlie[][16]={
  68. /*********0***************/
  69. {0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,
  70. 0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00},
  71. /*********1***************/
  72. {0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,
  73. 0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00},
  74. /*********2***************/
  75. {0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,
  76. 0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00},
  77. /*********3***************/
  78.   {0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,
  79. 0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00},
  80.         /*********4***************/
  81. {0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,
  82. 0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00},
  83.    /*********5***************/
  84. {0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,
  85. 0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00},
  86.         /*********6***************/
  87.    {0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,
  88. 0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00},
  89.   /*********7***************/
  90.   {0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,
  91. 0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00},
  92.         /*********8***************/
  93.    {0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,
  94. 0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00},
  95.         /*********9***************/
  96.    {0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,
  97. 0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00},
  98.    /*********10--Q***************/
  99.   {0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,
  100. 0x0F,0x18,0x24,0x24,0x38,0x50,0x4F,0x00},
  101. };
  102.   /***********大漢字顯示函數************************/
  103. void hanzi(uchar ye,uchar lie,uchar *shuzhu)        //定義任意頁、任意列、任意數組(*表示指針類型)
  104. {
  105.   uchar i,j;
  106.   for(i=0;i<4;i++)        //4頁
  107.   {
  108.   lcd12864_write_com(0xb8+ye+i);//頁的初始化地址
  109.    lcd12864_write_com(0x40+lie);//列的初始化地址
  110.    for(j=0;j<32;j++)        //這里要顯示大漢字,取模為32X32
  111.    {
  112.    lcd12864_write_date(shuzhu[i*32+j]);
  113.    }
  114.   }
  115. }
  116.         /***********標準漢字顯示函數************************/
  117. void hanzi2(uchar ye,uchar lie,uchar *shuzhu)        //定義任意頁、任意列、任意數組(*表示指針類型)
  118. {
  119.   uchar i,j;
  120.   for(i=0;i<2;i++)        //2頁
  121.   {
  122.   lcd12864_write_com(0xb8+ye+i);//頁的初始化地址
  123.    lcd12864_write_com(0x40+lie);//列的初始化地址
  124.    for(j=0;j<16;j++)        //這里要顯示標準漢字,取模為16X16
  125.    {
  126.    lcd12864_write_date(shuzhu[i*16+j]);
  127.    }
  128.   }
  129. }
  130.            /***********小數字顯示函數************************/
  131.   void shuzi2(uchar ye,uchar lie,uchar *shuzhu)        //定義任意頁、任意列、任意數組(*表示指針類型)
  132. {
  133.   uchar i,j;
  134.   for(i=0;i<2;i++)        //2頁
  135.   {
  136.   lcd12864_write_com(0xb8+ye+i);//頁的初始化地址
  137.    lcd12864_write_com(0x40+lie);//列的初始化地址
  138.    for(j=0;j<8;j++)        //數字取半模,這里要改為8
  139.    {
  140.    lcd12864_write_date(shuzhu[i*8+j]);
  141.    }
  142.   }
  143. }
  144. void lcd12864_dis() //漢字顯示函數
  145. {
  146. /*******顯示第一行***********/
  147. cs1=1;cs2=0;//打開左半屏 ,實物
  148. shuzi2(0,0,tab_banlie[10]);// Q
  149. shuzi2(0,8,tab_banlie[10]);// Q
  150. hanzi2(0,16,tab_biao[4]); //":"
  151. shuzi2(0,32,tab_banlie[1]);// 1
  152. shuzi2(0,40,tab_banlie[2]);// 2
  153. shuzi2(0,48,tab_banlie[3]);// 3
  154. shuzi2(0,56,tab_banlie[4]);// 4
  155. cs1=0;cs2=1;//打開右半屏 ,實物
  156. shuzi2(0,0,tab_banlie[5]);// 5
  157. shuzi2(0,8,tab_banlie[6]);// 6
  158. shuzi2(0,16,tab_banlie[7]);// 7
  159. shuzi2(0,24,tab_banlie[8]);// 8
  160. shuzi2(0,32,tab_banlie[9]);// 9
  161.    /*******顯示第二行(標準漢字)***********/
  162. cs1=1;cs2=0;//打開左半屏 ,實物
  163. hanzi2(2,0,tab_biao[0]); //好
  164. hanzi2(2,16,tab_biao[1]); //好
  165. hanzi2(2,32,tab_biao[2]);        //學
  166. hanzi2(2,48,tab_biao[3]); //習
  167. cs1=0;cs2=1;//打開右半屏 ,實物
  168. hanzi2(2,32,tab_biao[5]);        // 心
  169. /*******顯示第三行(大漢字)***********/
  170. cs1=1;cs2=0;//打開左半屏 ,實物
  171. hanzi(4,0,tab[4]); //天
  172. hanzi(4,32,tab[5]); //天
  173. cs1=0;cs2=1;//打開右半屏 ,實物
  174. hanzi(4,0,tab[6]); //向
  175. hanzi(4,32,tab[7]); //上
  176. }
全部資料51hei下載地址:
無字庫LCD12864液晶同時顯示大小漢字含全部資料.rar (7.27 MB, 下載次數: 237)
參與人數 2黑幣 +58 收起 理由
stkh + 8 很給力!
收藏收藏8 分享淘帖 頂1 踩
ID:403645 發表于 2018-9-28 16:52 | 只看該作者
大佬能分享一下取模軟件嗎
ID:307643 發表于 2018-9-28 17:04 | 只看該作者
試試看效果
ID:467921 發表于 2019-4-14 11:13 | 只看該作者
你好 請問4號引腳是D/I是程序上的RS吧
ID:461428 發表于 2019-5-4 17:08 來自觸屏版 | 只看該作者
這個不錯。。學習了
ID:553778 發表于 2019-6-6 14:43 | 只看該作者
謝謝,我收獲了很多,知道該如何解決我遇到的問題了
ID:74784 發表于 2019-10-5 18:23 | 只看該作者
出給我幾個行不?
ID:584814 發表于 2019-10-6 10:19 來自觸屏版 | 只看該作者
這個很好,受益匪淺。
ID:243267 發表于 2019-12-24 17:45 來自觸屏版 | 只看該作者
我也是用無字庫的12864液晶,為什么最多只能顯示兩個字模的漢字?是單片機內存不夠嗎?
ID:31133 發表于 2020-4-11 17:43 | 只看該作者
這個資料不錯,正需要
ID:102939 發表于 2020-9-21 08:51 | 只看該作者
還有12864嗎?
