查看: 12888|回復(fù): 2
TJA1021引腳圖—LIN2.0標(biāo)準(zhǔn)收發(fā)器數(shù)據(jù)手冊(cè)下載
TJA1021—LIN2.0 標(biāo)準(zhǔn)收發(fā)器數(shù)據(jù)
TJA1021T引腳圖:
TJA1021T管腳功能定義:
The TJA1021 is the interface between the LIN master/slave protocol controller and the
physical bus in a Local Interconnect Network (LIN). The TJA1021 is LIN 2.0/SAE J2602
compliant and provides optimum ElectroMagnetic Compatibility (EMC) performance due
to wave shaping of the LIN output.
The /20 version of the TJA1021 is optimized for the maximum specified LIN transmission
speed of 20 kBd; the /10 version of the TJA1021 is optimized for the LIN transmission
speed of 10.4 kBd as specified by the SAE J2602.
完整的pdf格式文檔51黑下載地址:
TJA1021—LIN2.0 標(biāo)準(zhǔn)收發(fā)器數(shù)據(jù)手冊(cè).pdf (129.49 KB, 下載次數(shù): 99)
收藏收藏 分享淘帖 頂 踩2
無(wú)效樓層,該帖已經(jīng)被刪除
ID:125320 發(fā)表于 2021-4-7 17:17 | 只看該作者
謝謝!好資料,51黑有你更精彩!!!
ID:615192 發(fā)表于 2021-7-29 10:21 | 只看該作者
謝謝分享!剛好有用到,下來(lái)看看
