查看: 3781|回復: 0
MOSFET參數(shù)解讀(英文版資料)
ID:391513 發(fā)表于 2018-8-30 11:21 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
分享MOSFET參數(shù)解讀
MOSFET datasheet parameters introduction
Introduction
When choosing a MOSFET, parameters that are focused on by most engineers intuitively are VDS,
RDS(on), ID. However, in power systems, it is significant to pick up a suitable MOSFET based on
different applications. In this application note, Taiwan Semiconductor (TSC) introduces the definition
of every single parameter of a MOSFET, and from chapter 3, TSC also explains how each parameter is
realized, hoping this would help designers on the power projects.
全部資料51hei下載地址:
AN-1001_A1611.pdf (854.93 KB, 下載次數(shù): 16)
