查看: 26820|回復: 41
試做的RGB全彩LED廣州塔(單片機源碼PCB電路圖資料分享)
本帖最后由 浸染的夜 于 2018-8-30 08:09 編輯
RGB全彩LED廣州塔效果視頻:
https://v.youku.com/v_show/id_XMzgwMTY3Nzk5Ng==.html
燈體焊接教程視頻
http://www.tudou.com/programs/view/U1rRxIadz0Q/
折燈方法:
模板制作:
a4紙1:1打。0逦募谫Y料里)
用脫水、膠帶都可以
孔是5mm的,烙鐵頭,鑷子等都是可以打孔的
焊接:
上圖LED燈為早期買的,這種小草帽不太好
要買這種,RGB全彩共陰,別買錯了
以上是焊好和燈塔,不過我建議做好底板電路,每焊一層燈,就接到板子上,
LED燈買上圖這種,
焊接板子時沒有拍照,忘了。
我用的插件的單片機與2803、573,適合洞洞板焊接。
Altium Designer畫的RGB全彩LED廣州塔原理圖和PCB圖如下:(51hei附件中可下載工程文件)
  1.
  2.       /*////////////////////////////////////////////////////////////////////
  3.       //   本程序禁止用于未經本人同意的其它商用目的,一經發現,各種騷擾   //
  4.       ////////////////////////////////////////////////////////////////////*/
  5. #include<reg52.h>                         //頭文件
  6. #define uint unsigned int         //宏定義
  7. #define uchar unsigned char         //宏定義
  8. #include<intrins.h>                         //循環函數的頭文件
  9. uchar code table0[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//從低位往高位滅一個燈流水
  10. uchar code table1[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//從高位往低位滅一個燈流水
  11. uchar code table2[]={0xfe,0xfa,0xf8,0xf0,0xe0,0xa0,0x80,0x00};//從低位到高位逐步全部熄滅
  12. uchar code table3[]={0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00};//從高位到低位逐步全部熄滅
  13. uchar code table4[]={0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};//從低位到高位逐步全部點亮
  14. uchar code table5[]={0x80,0xa0,0xe0,0xf0,0xf8,0xfa,0xfe,0xff};//從高位到低位逐步全部點亮
  15. uchar code table6[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};//從低位到高位,亮一個燈移動
  16. uchar code table7[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//從高位到低位,亮一個燈移動
  17. uchar code table8[]={0xfc,0xfe,0xff,0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00,0x80,0xc0,0xe0,0xf0,0xf1};
  18. uchar code table9[]={0x03,0x01,0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff,0x7f,0x3f,0x1f,0x0f,0x07};
  19. uchar code table10[]={0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff,0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01};
  20. uchar code table11[]={0xff,0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe};
  21. uchar code table12[]={0x1f,0x0f,0x07,0x03,0x01,0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff,0x7f,0x3f};
  22. uchar code table13[]={0xe0,0xf0,0xf8,0xfc,0xfe,0xff,0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00,0x80,0xc0};
  23. uchar i,b;
  24. sbit r1=P3^2; //紅色上8層片選
  25. sbit r2=P3^3; //紅色下8層片選
  26. sbit b1=P3^4; //綠色上8層片選
  27. sbit b2=P3^5; //綠色下8層片選
  28. sbit g1=P3^6; //藍色上8層片選
  29. sbit g2=P3^7; //藍色下8層片選
  30. void delay(uint z) //延時函數
  31. {
  32.         uint x,y;
  33.         for(x=z;x>0;x--)
  34.                 for(y=314;y>0;y--);
  35. }
  36. /******************************************/
  37. void liushui0()//兩列紅色逆時針轉動
  38. {
  39.         r1=1;        //開紅色使能
  40.         r2=1;        //開紅色使能
  41.         P0=0xff;//
  42.         for(i=0;i<8;i++)
  43.         {
  44.                 P1=table6[i];
  45.                 P2=table6[i];
  46.                 delay(30);
  47.         }
  48.            P1=0x00;P2=0x00;
  49.         P0=0x00;
  50.         r1=0;  //關紅色使能
  51.         r2=0;  //關紅色使能
  52. }
  53. void rr()//紅色亮一會兒
  54. {
  55.         r1=1;
  56.         r2=1;
  57.         P0=0xff;
  58.         P2=0xff;
  59.         P1=0xff;
  60.         delay(100);
  61.         P0=0x00;
  62.         r1=0;
  63.         r2=0;
  64.         P2=0x00;
  65.         P1=0x00;
  66. }
  67. /******************************************/
  68. void liushui1()//兩列綠色逆時針轉動
  69. {
  70.         g1=1;        //開綠色使能
  71.         g2=1;        //開綠色使能
  72.         P0=0xff;//
  73.         for(i=0;i<8;i++)
  74.         {
  75.                 P1=table6[i];
  76.                 P2=table6[i];
  77.                 delay(30);
  78.         }
  79.            P1=0x00;P2=0x00;
  80.         P0=0x00;
  81.         g1=0;  //關綠色使能
  82.         g2=0;  //關綠色使能
  83. }
  84. void gg()//綠色亮一會兒
  85. {
  86.         g1=1;
  87.         g2=1;
  88.         P0=0xff;
  89.         P2=0xff;
  90.         P1=0xff;
  91.         delay(100);
  92.         P0=0x00;
  93.         g1=0;
  94.         g2=0;
  95.         P2=0x00;
  96.         P1=0x00;
  97. }
  98. /******************************************/
  99. void liushui2()//兩列藍色逆時針轉動
  100. {
  101.         b1=1;        //開藍色使能
  102.         b2=1;        //開藍色使能
  103.         P0=0xff;//
  104.         for(i=0;i<8;i++)
  105.         {
  106.                 P1=table6[i];
  107.                 P2=table6[i];
  108.                 delay(30);
  109.         }
  110.            P1=0x00;P2=0x00;
  111.         P0=0x00;
  112.         b1=0;  //關藍色使能
  113.         b2=0;  //關藍色使能
  114. }
  115. void bb()//藍色亮一會兒
  116. {
  117.         b1=1;
  118.         b2=1;
  119.         P0=0xff;
  120.         P2=0xff;
  121.         P1=0xff;
  122.         delay(100);
  123.         P0=0x00;
  124.         b1=0;
  125.         b2=0;
  126.         P2=0x00;
  127.         P1=0x00;
  128. }
  129. void liushui3()//紅色單層向上移動
  130. {
  131.         P1=0xff;P2=0xff;
  132.         b2=1;
  133.         for(i=0;i<8;i++)
  134.         {
  135.                 P0=table7[i];
  136.                 delay(30);
  137.         }
  138.         P0=0x00;
  139.         b2=0;
  140. /********* **********/
  141.         P1=0xff;P2=0xff;
  142.         b1=1;
  143.         for(i=0;i<8;i++)
  144.         {
  145.                 P0=table7[i];
  146.                 delay(30);
  147.         }
  148.         P0=0x00;
  149.         b1=0;
  150. }
  151. /***********************/
  152. void liushui4()//紅、黃、綠、青、藍、洋紅、白、紅,向上流動
  153. {
  154.         uchar a,b,c;//綠、紅、藍
  155.         a=0x8d;
  156.         b=0x38;
  157.         c=0xe1;
  158. /////////////
  159.         r1=1;P0=b;r1=0;
  160.         r2=1;P0=b;r2=0;
  161.         g1=1;P0=a;g1=0;
  162.         g2=1;P0=a;g2=0;
  163.         b1=1;P0=c;b1=0;
  164.         b2=1;P0=c;b2=0;
  165.         P1=0xff;P2=0xff;
  166.         for(i=0;i<8;i++)
  167.         {
  168.                 a=_cror_(a,1);//循環左移
  169.                 b=_cror_(b,1);//循環左移
  170.                 c=_cror_(c,1);//循環左移
  171.                 delay(80);//延時
  172.         r1=1;P0=b;r1=0;
  173.         r2=1;P0=b;r2=0;
  174.         g1=1;P0=a;g1=0;
  175.         g2=1;P0=a;g2=0;
  176.         b1=1;P0=c;b1=0;
  177.         b2=1;P0=c;b2=0;
  178.         }
  179.         P3=0xff;P0=0x00;P3=0x00;
  180.         P1=0x00;P2=0x00;
  181. }
  182. /*************************************************/
  183. void liushui5()//紅、黃、綠、青、藍、洋紅、白、紅,向下流動
  184. {
  185.         uchar a,b,c;//綠、紅、藍
  186.         a=0x8d;
  187.         b=0x38;
  188.         c=0xe1;
  189. /////////////
  190.         r1=1;P0=b;r1=0;
  191.         r2=1;P0=b;r2=0;
  192.         g1=1;P0=a;g1=0;
  193.         g2=1;P0=a;g2=0;
  194.         b1=1;P0=c;b1=0;
  195.         b2=1;P0=c;b2=0;
  196.         P1=0xff;P2=0xff;
  197.         for(i=0;i<8;i++)
  198.         {
  199.                 a=_crol_(a,1);//循環左移
  200.                 b=_crol_(b,1);//循環左移
  201.                 c=_crol_(c,1);//循環左移
  202.                 delay(80);//延時
  203.         r1=1;P0=b;r1=0;
  204.         r2=1;P0=b;r2=0;
  205.         g1=1;P0=a;g1=0;
  206.         g2=1;P0=a;g2=0;
  207.         b1=1;P0=c;b1=0;
  208.         b2=1;P0=c;b2=0;
  209.         }
  210.         P3=0xff;P0=0x00;P3=0x00;
  211.         P1=0x00;P2=0x00;
  212. }
  213. void liushui6()//白色單層向上
  214. {
  215.         uchar a,b,c;//綠、紅、藍
  216.         a=0x80;
  217.         b=0x80;
  218.         c=0x80;
  219. /////////////
  220.         r2=1;P0=b;r2=0;
  221.         g2=1;P0=a;g2=0;
  222.         b2=1;P0=c;b2=0;
  223.         P1=0xff;P2=0xff;
  224.         for(i=0;i<8;i++)
  225.         {
  226.                 a=_cror_(a,1);//循環左移
  227.                 b=_cror_(b,1);//循環左移
  228.                 c=_cror_(c,1);//循環左移
  229.                 delay(25);//延時
  230.         r2=1;P0=b;r2=0;
  231.         g2=1;P0=a;g2=0;
  232.         b2=1;P0=c;b2=0;
  233.         }
  234.         P3=0xff;P0=0x00;P3=0x00;
  235.         P1=0x00;P2=0x00;
  236. /*****************************************/
  237.         r1=1;P0=b;r1=0;
  238.         g1=1;P0=a;g1=0;
  239.         b1=1;P0=c;b1=0;
  240.         P1=0xff;P2=0xff;
  241.         for(i=0;i<8;i++)
  242.         {
  243.                 a=_cror_(a,1);//循環左移
  244.                 b=_cror_(b,1);//循環左移
  245.                 c=_cror_(c,1);//循環左移
  246.                 delay(25);//延時
  247.         r1=1;P0=b;r1=0;
  248.         g1=1;P0=a;g1=0;
  249.         b1=1;P0=c;b1=0;
  250.         }
  251.         P3=0xff;P0=0x00;P3=0x00;
  252.         P1=0x00;P2=0x00;
  253. }
  254. /****************************************************/
  255. void liushui7()//白色單層向下
  256. {
  257.         uchar a,b,c;//綠、紅、藍
  258.         a=0x01;
  259.         b=0x01;
  260.         c=0x01;
  261. /////////////
  262.         r1=1;P0=b;r1=0;
  263.         g1=1;P0=a;g1=0;
  264.         b1=1;P0=c;b1=0;
  265.         P1=0xff;P2=0xff;
  266.         for(i=0;i<8;i++)
  267.         {
  268.                 a=_crol_(a,1);//循環左移
  269.                 b=_crol_(b,1);//循環左移
  270.                 c=_crol_(c,1);//循環左移
  271.                 delay(25);//延時
  272.         r1=1;P0=b;r1=0;
  273.         g1=1;P0=a;g1=0;
  274.         b1=1;P0=c;b1=0;
  275.         }
  276.         P3=0xff;P0=0x00;P3=0x00;
  277.         P1=0x00;P2=0x00;
  278. /*****************************************/
  279.         r2=1;P0=b;r2=0;
  280.         g2=1;P0=a;g2=0;
  281.         b2=1;P0=c;b2=0;
  282.         P1=0xff;P2=0xff;
  283.         for(i=0;i<8;i++)
  284.         {
  285.                 a=_crol_(a,1);//循環左移
  286.                 b=_crol_(b,1);//循環左移
  287.                 c=_crol_(c,1);//循環左移
  288.                 delay(25);//延時
  289.         r2=1;P0=b;r2=0;
  290.         g2=1;P0=a;g2=0;
  291.         b2=1;P0=c;b2=0;
  292.         }
  293.         P3=0xff;P0=0x00;P3=0x00;
  294.         P1=0x00;P2=0x00;
  295. }
  296. /********************************************************************/
  297. void liushui8()//6色向上流動
  298. {
  299.         P1=0x00;P2=0x00;
  300.         P1=0xff;P2=0xff;
  301.         for(i=0;i<16;i++)
  302.         {
  303.                 r2=1;P0=table8[i];r2=0;
  304.                 r1=1;P0=table9[i];r1=0;
  305.         P1=0x00;P2=0x00;
  306.         P1=0xff;P2=0xff;
  307.                 /******/
  308.                 g2=1;P0=table10[i];g2=0;
  309.                 g1=1;P0=table11[i];g1=0;
  310.         P1=0x00;P2=0x00;
  311.         P1=0xff;P2=0xff;
  312.                 b2=1;P0=table12[i];b2=0;
  313.                 b1=1;P0=table13[i];b1=0;
  314.                 delay(25);
  315.         }
  316.         P3=0xff;P0=0x00;P3=0x00;
  317. }
  318. /***********************************************************************/
  319. void liushui9()//6色向下流動
  320. {
  321.         P1=0x00;P2=0x00;
  322.         P1=0xff;P2=0xff;
  323.         for(i=16;i>0;i--)
  324.         {
  325.                 r2=1;P0=table8[i];r2=0;
  326.                 r1=1;P0=table9[i];r1=0;
  327.         P1=0x00;P2=0x00;
  328.         P1=0xff;P2=0xff;
  329.                 /******/
  330.                 g2=1;P0=table10[i];g2=0;
  331.                 g1=1;P0=table11[i];g1=0;
  332.         P1=0x00;P2=0x00;
  333.         P1=0xff;P2=0xff;
  334.                 b2=1;P0=table12[i];b2=0;
  335.                 b1=1;P0=table13[i];b1=0;
  336.                 delay(25);
  337.         }
  338.         P3=0xff;P0=0x00;P3=0x00;
  339. }
  340. /********************************************************************************
  341. *********************************************************************************
  342. *********************************************************************************/
  343. void main()
  344. {
  345.         r1=1;P0=0x80;r1=0;
  346.         r2=1;P0=0x80;r2=0;
  347.         g1=1;P0=0x00;g1=0;
  348.         g2=1;P0=0x00;g2=0;
  349.         b1=1;P0=0x00;b1=0;
  350.         b2=1;P0=0x00;b2=0;
  351.         P1=0x00;
  352.         P2=0x00;
  353. /**************************************/
  354. while(1)
  355.          {
  356. /*        */
  357.           liushui0();//兩列紅色逆時針轉動
  358.           liushui1();//兩列綠色逆時針轉動
  359.           liushui2();//兩列藍色逆時針轉動
  360.           liushui3();//紅色單層向上移動
  361.
  362.           gg();//綠色亮一會兒
  363.           rr();//紅色亮一會兒
  364.           bb();//藍色亮一會兒
  365.           liushui4();//紅、黃、綠、青、藍、洋紅、白、紅,向上流動
  366.           liushui4();//紅、黃、綠、青、藍、洋紅、白、紅,向上流動
  367.           liushui4();//紅、黃、綠、青、藍、洋紅、白、紅,向上流動
  368.           liushui5();//紅、黃、綠、青、藍、洋紅、白、紅,向下流動
  369.           liushui5();//紅、黃、綠、青、藍、洋紅、白、紅,向下流動
  370.           liushui5();//紅、黃、綠、青、藍、洋紅、白、紅,向下流動
  371.           liushui6();//白色單層向上
  372.           liushui7();//白色單層向下
  373.           liushui8();//6色向上流動
  374.           liushui8();//6色向上流動
  375.           liushui8();//6色向上流動
  376.           liushui9();//6色向下流動
  377.           liushui9();//6色向下流動
  378.           liushui9();//6色向下流動
  379. /******************************************/
  380.         }
  381.
  382. }
RGB廣州塔16x16.zip (19.2 MB, 下載次數: 451)
先這樣,有什么不懂的,加上面群交流吧。
參與人數 1黑幣 +100 收起 理由
admin + 100 共享資料的黑幣獎勵!
收藏收藏19 分享淘帖 頂1 踩
ID:383624 發表于 2023-6-20 13:42 | 只看該作者
怎么沒有元器件清單呢
ID:1011444 發表于 2022-7-13 18:09 | 只看該作者
資料下載看了一下,感覺兩腳led全彩燈焊接起來要容易一些,四腳led焊接操作太復雜了,弄不好腳與腳會相碰短路。樓主認真仔細精神可嘉,謝謝分享
ID:1038548 發表于 2022-7-6 11:37 | 只看該作者
學習代碼,學習電路圖,樓主厲害!
ID:851418 發表于 2021-1-18 05:45 | 只看該作者
非常漂亮的全彩廣州塔,樓主厲害!
ID:169064 發表于 2020-8-7 12:33 來自觸屏版 | 只看該作者
這個真不錯!很好很好
ID:476465 發表于 2020-3-23 14:57 | 只看該作者
樓主能提供材料清單嗎?我也想DIY一個
ID:711872 發表于 2020-3-22 18:00 | 只看該作者
樓主有材料清單嗎?分享一下
ID:639372 發表于 2020-3-19 20:59 | 只看該作者
作為廣東人 看到這個很激動啊 加油樓主 51黑有你更精彩
ID:690363 發表于 2020-3-18 17:11 | 只看該作者
這個更好,上午剛看了單色的廣州塔,現在又找到了RGB的塔,簡直太棒了
ID:381496 發表于 2020-3-18 15:34 | 只看該作者
正準備做個全彩的,剛好就看到了你的資料,謝謝分享
ID:161151 發表于 2020-3-14 18:30 | 只看該作者
這是大工程。
ID:439863 發表于 2020-3-14 14:59 | 只看該作者
這手工,厲害厲害了。
ID:701939 發表于 2020-3-4 14:36 | 只看該作者
樓主,問下能否弄的出來律動的效果呢?
ID:246783 發表于 2020-3-3 23:16 來自觸屏版 | 只看該作者
耐心,技術,動手能力缺一不可
ID:621012 發表于 2019-10-9 18:51 | 只看該作者
樓主我加群為何不通過。
ID:621012 發表于 2019-10-9 12:30 | 只看該作者
樓主求一份元器件清單
ID:284079 發表于 2019-9-15 16:04 | 只看該作者
很不錯的資料
ID:105826 發表于 2019-9-12 13:44 | 只看該作者
看了成品視頻,效果真的是驚嘆,真的很不錯,如果有個上位機能像點陣一樣顯示可玩性會不會好很多?
ID:312815 發表于 2019-7-15 00:04 | 只看該作者
感謝分享
ID:510055 發表于 2019-5-13 07:51 來自觸屏版 | 只看該作者
可以試著做一下
ID:493298 發表于 2019-5-9 08:10 | 只看該作者
初學者,來這學習了!厲害厲害
ID:432687 發表于 2019-4-22 04:36 來自觸屏版 | 只看該作者
完美的靈感和學習效果頁面。 我很驚訝于聰明才智。 好主意,堅持下去! 不幸的是,我不懂你的語言,我非常依賴翻譯。 但意志會放山。
ID:344062 發表于 2019-4-14 03:00 來自觸屏版 | 只看該作者
樓主有材料清單嗎?分享一下
ID:344062 發表于 2019-4-14 01:16 來自觸屏版 | 只看該作者
LED燈珠四個腳的和兩個腳的鏈接方法一樣嗎?
ID:471375 發表于 2019-2-13 22:41 來自觸屏版 | 只看該作者
太棒了,不錯不錯
ID:453974 發表于 2019-1-9 19:07 來自觸屏版 | 只看該作者
焊的真漂亮,有技術
ID:243748 發表于 2019-1-9 12:41 來自觸屏版 | 只看該作者
用共陽燈,程序怎么改
ID:137563 發表于 2019-1-1 17:55 | 只看該作者
大佬,學習了,牛逼,牛逼
