歡迎做ZIGBEE開發(fā)交流
2018-8-27 19:26 上傳
單片機(jī)源程序如下:
- Device Description File
- This file contains descriptor information needed to describe and
- implement a ZigBee application. This file is application-specific -
- each application should have its own file.
- In the future, this file should be automatically generated by a ZigBee
- configuration tool.
- * FileName: MyZigBee.c
- * Dependencies:
- * Processor: PIC18
- * Complier: MCC18 v1.00.50 or higher
- * HITECH PICC-18 V8.10PL1 or higher
- * Company: Microchip Technology, Inc.
- * Software License Agreement
- * The software supplied herewith by Microchip Technology Incorporated
- * (the 揅ompany? for its PICmicro?Microcontroller is intended and
- * supplied to you, the Company抯 customer, for use solely and
- * exclusively on Microchip PICmicro Microcontroller products. The
- * software is owned by the Company and/or its supplier, and is
- * protected under applicable copyright laws. All rights are reserved.
- * Any use in violation of the foregoing restrictions may subject the
- * user to criminal sanctions under applicable laws, as well as to
- * civil liability for the breach of the terms and conditions of this
- * license.
- * THIS SOFTWARE IS PROVIDED IN AN 揂S IS?CONDITION. NO WARRANTIES,
- * WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
- * TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
- * PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
- * IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
- * CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
- * Author Date Comment
- * DF/KO 04/29/05 Microchip ZigBee Stack v1.0-2.0
- * DF/KO 07/27/05 Microchip ZigBee Stack v1.0-3.1
- * DF/KO 09/08/05 Microchip ZigBee Stack v1.0-3.3
- #include "zigbee.h"
- #include "zdo.h"
- // Node Descriptor
- // This structure describes the node type and its capabilities
- ROM NODE_DESCRIPTOR Config_Node_Descriptor =
- NODE_LOGICAL_TYPE,
- NODE_FREQ_BAND,
- ALT_PAN_COORD | DEVICE_TYPE | POWER_SOURCE | RECEIVER_ON_IDLE | SECURITY_CAPABILITY,
- NODE_MAX_BUFFER_SIZE,
- NODE_MAX_TRANSFER_SIZE
- // Node Power Descriptor
- // This structure describes the node's power characteristics.
- // Current version does not support variable charge level advertisement.
- ROM NODE_POWER_DESCRIPTOR Config_Power_Descriptor =
- NODE_CURRENT_POWER_MODE | (NODE_AVAILABLE_POWER_SOURCES << 4),
- NODE_AVAILABLE_POWER_SOURCES | (0x0f << 4)
- // Simple Descriptors
- // This structure defines all endpoints that are implemented in the application.
- // The first endpoint is the ZigBee Device Object endpoint - DO NOT MODIFY.
- // The following endpoints describe the application endpoints.
- ROM NODE_SIMPLE_DESCRIPTOR Config_Simple_Descriptors[NUM_DEFINED_ENDPOINTS] =
- // ZigBee Device Object Endpoint
- // DO NOT MODIFY THIS DESCRIPTOR!!!
- EP_ZDO, // ZDO Endpoint is endpoint 0
- {MY_PROFILE_ID_LSB,MY_PROFILE_ID_MSB}, // Application Profile ID, from the ZigBee Alliance
- {0x00,0x00}, // ZDO Device ID
- 0x00, // ZDO Device Version
- NO_OTHER_DESCRIPTOR_AVAILABLE, // Application Flags
- ZDO_INPUT_CLUSTERS, // Application Input Cluster Count
- { NWK_ADDR_REQ, IEEE_ADDR_REQ, NODE_DESC_REQ, POWER_DESC_REQ,
- SIMPLE_DESC_REQ, ACTIVE_EP_REQ, MATCH_DESC_REQ
- #ifdef INCLUDE_OPTIONAL_NODE_MANAGEMENT_SERVICES
- , MGMT_NWK_DISC_REQ, MGMT_LQI_REQ, MGMT_RTG_REQ,
- MGMT_BIND_REQ, MGMT_LEAVE_REQ, MGMT_DIRECT_JOIN_REQ
- #endif
- #ifdef INCLUDE_OPTIONAL_SERVICE_DISCOVERY_RESPONSES
- , COMPLEX_DESC_REQ, USER_DESC_REQ, DISCOVERY_REGISTER_REQ,
- END_DEVICE_ANNCE, USER_DESC_SET
- #endif
- #if defined(I_AM_COORDINATOR) && defined(SUPPORT_END_DEVICE_BINDING)
- , END_DEVICE_BIND_REQ
- #endif
- #if defined(I_AM_COORDINATOR) || defined(I_SUPPORT_BINDINGS)
- , BIND_REQ, UNBIND_REQ
- #endif
- #ifdef I_AM_COORDINATOR
- , CUSTOM_DEMO_BIND // Demo only!
- #endif
- }, // Application Input Cluster List
- ZDO_OUTPUT_CLUSTERS, // Application Output Cluster Count
- { NWK_ADDR_RSP, IEEE_ADDR_RSP, NODE_DESC_RSP, POWER_DESC_RSP,
- SIMPLE_DESC_RSP, ACTIVE_EP_RSP, MATCH_DESC_RSP
- , MGMT_NWK_DISC_RSP, MGMT_LQI_RSP, MGMT_RTG_RSP,
- MGMT_BIND_RSP, MGMT_LEAVE_RSP, MGMT_DIRECT_JOIN_RSP
- #endif
- , COMPLEX_DESC_RSP, USER_DESC_RSP, DISCOVERY_REGISTER_RSP,
- USER_DESC_CONF
- #endif
- #endif
- #endif
- } // Application Output Cluster List
- // User Descriptors
- // Enter application endpoint descriptors here.
- // Switch endpoint information
- EP_SWITCH, // Endpoint number
- {SW_REMOTE_CONTROL_DEV_ID_LSB,SW_REMOTE_CONTROL_DEV_ID_MSB}, // Application Device ID, from the ZigBee Alliance
- SW_REMOTE_CONTROL_DEV_VER, // Application Device Version, from the ZigBee Alliance
- 0x00, // Application Input Cluster Count
- { NO_CLUSTER }, // Application Input Cluster List
- 0x01, // Application Output Cluster Count
- { OnOffSRC_CLUSTER } // Application Output Cluster List
- // Complex Descriptor
- // This structure is optional It contains more information about the device.
- // This structure is option. It can be one character string up to 16 characters
- // long.
- // Network Mode and Parameters
- ROM _Config_NWK_Mode_and_Params Config_NWK_Mode_and_Params =
- PROFILE_nwkcProtocolVersion, // BYTE ProtocolVersion;
- MY_STACK_PROFILE_ID, // BYTE StackProfile;
- 15, // BYTE BeaconOrder; (non-slotted)
- 15, // BYTE SuperframeOrder; (non-slotted)
- FALSE, // BYTE BatteryLifeExtension;
- PROFILE_nwkSecurityLevel, // BYTE SecuritySetting;
- {0xFFFF} // WORD Channels (scan all channels)
ZigBee開源協(xié)議棧MpZBee.rar
(4.07 MB, 下載次數(shù): 44)
2018-8-27 18:29 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
