查看: 2086|回復: 0
用單片機定時器控制led
ID:380532 發表于 2018-8-23 22:10 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#define u16 unsigned int
#define u8  unsigned char
u16 s=0,id=0;
sbit k1=P3^1;
sbit k2=P3^0;
sbit L0=P2^0;
sbit L1=P2^1;
sbit L2=P2^2;
sbit L3=P2^3;
sbit L4=P2^4;
sbit L5=P2^5;
sbit L6=P2^6;
sbit L7=P2^7;
void delay(u16 i);
void key();
void tim0d();
        tim0d();
                key();
                key();
                if(s>=400)
                        s=0;
                        id++;
                switch(id)
                        case 0: L0=~L0;L7=1;break;
                        case 1: L1=~L1;L0=1;break;
                        case 2: L2=~L2;L1=1;break;
                        case 3: L3=~L3;L2=1;break;
                        case 4: L4=~L4;L3=1;break;
                        case 5: L5=~L5;L4=1;break;
                        case 6: L6=~L6;L5=1;break;
                        case 7: L7=~L7;L6=1;break;
                        case 8: L6=~L6;L7=1;break;
                        case 9: L5=~L5;L6=1;break;
                        case 10: L4=~L4;L5=1;break;
                        case 11: L3=~L3;L4=1;break;
                        case 12: L2=~L2;L3=1;break;
                        case 13: L1=~L1;L2=1;break;
                        case 14: L0=~L0;L1=1; id=0;break;
void delay(u16 i)
        while(i--);
void key()
        if(k1==0)
                delay(1000);
                if(k1==0)
                        TR0=1;
        while(!k1);
        if(k2==0)
                delay(1000);
                if(k2==0)
                        TR0=0;
                        id=0;
                        s=0;
                        P2=0xfe;
        while(!k2);
void tim0d()
        TMOD|=0X01;
        TH0=0XFC;
        TL0=0X18;
        ET0=1;
        EA=1;
        TR0=0;
void tim0() interrupt 1
        TH0=0XFC;
        TL0=0X18;
        s++;
