查看: 2497|回復: 1
單片機溫度的加減控制步進電機正反轉
ID:389411 發表于 2018-8-23 20:56 | 顯示全部樓層 |閱讀模式
這是我的一個項目
以下是代碼;
#include <reg52.H>
#include <intrins.H>
#include <math.H>
#define MotorData P1
        sbit dula = P2^6;
  sbit wela = P2^7;
  sbit RS = P3^5;
  sbit LCDEN = P3^4;
sbit buzzer = P2^3;
int w;
int a;
uchar phasecw[4] ={0x08,0x04,0x02,0x01};
uchar phaseccw[4]={0x01,0x02,0x04,0x08};
void delay(uint p)
        while(p++);
void Delay_xms(uint x)
uint i,j;
for(i=0;i<x;i++)
  for(j=0;j<112;j++);
void MotorCW(void)
uchar i;
        uchar f;
        for(f=0;f<60;f++)
for(i=0;i<4;i++)
   MotorData=phasecw[i];
   Delay_xms(4);
void MotorCCW(void)
uchar i;
        uchar f;
        for(f=0;f<60;f++)
for(i=0;i<4;i++)
   MotorData=phaseccw[i];
   Delay_xms(4);
void MotorStop(void)
MotorData=0x00;
void delayUs()
    _nop_();
void delayMs(uint a)
    uint i, j;
    for(i = a; i > 0; i--)
        for(j = 100; j > 0; j--);
void writeComm(uchar comm)
     RS = 0;
    P0 = comm;
    LCDEN = 1;
     delayUs();
    LCDEN = 0;
    delayMs(1);
//D′êy?Y:RS=1, RW=0;
void writeData(uchar dat)
     RS = 1;
     P0 = dat;
     LCDEN = 1;
    delayUs();
    LCDEN = 0;
    delayMs(1);
void init()
     dula = wela = 0;
    writeComm(0x38);
   writeComm(0x0c);
    writeComm(0x06);
    writeComm(0x01);
void writeString(uchar * str, uchar length)
     uchar i;
    for(i = 0; i < length; i++)
         writeData(str[i]);
/**//*****************************DS18B20*******************************/
sbit ds = P2^2;
void dsInit()
    unsigned int i;
    ds = 0;
    i = 100;
     while(i>0) i--;
    ds = 1;
    i = 4;
     while(i>0) i--;
void dsWait()
      unsigned int i;
      while(ds);
      while(~ds);
      i = 4;
      while(i > 0) i--;
bit readBit()
    unsigned int i;
    bit b;
    ds = 0;
    i++;
    ds = 1;
   i++; i++;
    b = ds;
    i = 8;
    while(i>0) i--;
    return b;
unsigned char readByte()
    unsigned int i;
    unsigned char j, dat;
   dat = 0;
    for(i=0; i<8; i++)
        j = readBit();
        dat = (j << 7) | (dat >> 1);
    return dat;
void writeByte(unsigned char dat)
    unsigned int i;
    unsigned char j;
    bit b;
    for(j = 0; j < 8; j++)
        b = dat & 0x01;
        dat >>= 1;
        if(b)
           ds = 0;          i++; i++;
            ds = 1;
            i = 8; while(i>0) i--;
            ds = 0;
            ds = 1;
           i++; i++;
void sendChangeCmd()
    dsInit();
    dsWait();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0x44);
void sendReadCmd()
    dsInit();
    dsWait();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0xbe);
int getTmpValue()
    unsigned int tmpvalue;
    int value;
    float t;
    unsigned char low, high;
    sendReadCmd();
    low = readByte();
    high = readByte();
    tmpvalue = high;
    tmpvalue <<= 8;
    tmpvalue |= low;
    value = tmpvalue;
    t = value * 0.0625;
    value = t * 100 + (value > 0 ? 0.5 : -0.5); //′óóú0?ó0.5, D?óú0??0.5
    return value;
void bijiao()
        int i,j,c;
        i=getTmpValue();
        i=i/100;
        delay(50);
        j=getTmpValue();
        j=j/100;
                c=getTmpValue();
        a=i-j;
        if(a>0)
                 MotorCW();
                Delay_xms(100);
                 MotorStop();
        if(a<0)
                MotorCCW();
                Delay_xms(100);
                MotorStop();
void display(int v)
    unsigned char count;
    unsigned char datas[] = {0, 0, 0, 0, 0};
    unsigned int tmp = abs(v);
    datas[0] = tmp / 10000;
    datas[1] = tmp % 10000 / 1000;
    datas[2] = tmp % 1000 / 100;
    datas[3] = tmp % 100 / 10;
    datas[4] = tmp % 10;
    writeComm(0xc0+3);
    if(v < 0)
        writeString("- ", 2);
       writeString("+ ", 2);
    if(datas[0] != 0)
        writeData('0'+datas[0]);
    for(count = 1; count != 5; count++)
        writeData('0'+datas[count]);
        if(count == 2)
            writeData('.');
    uchar table[] = " xianzaiwendu:  ";
    sendChangeCmd();
    init();
    writeComm(0x80);
    writeString(table, 16);
                        w=getTmpValue();
                        if(w>=3000)
                        { bijiao();}
        delayMs(1000); //???è×a??ê±??Dèòa750msò?é?
        writeComm(0xc0);
        display(getTmpValue());
        sendChangeCmd();
ID:1 發表于 2018-8-23 23:06 | 顯示全部樓層
樓主您好,原理圖能分享下嗎?
