#include "stc15f2k60s2.h"
#include "lcd.h"
#include <stdio.h>
#include <string.h>
#include "intrins.h"
int i;
uint code zhiling[ ]={0xDD,0xA5,0x03,0x00,0xFF,0xFD,0x77};
char xdata char_U[50]; //總電壓
char xdata char_I[50]; //總電流
char xdata char_EXT[50]; //電池溫度
void display(); //屏幕顯示
sbit newTXD = P4^1; //發送端設為P4.1
sbit newRXD = P4^2; //接收端設為p4.2
void Delayxms(unsigned char i)
while(--i)
_nop_();
void UartInit() //串口初始化
{TMOD= 0x02; //定時器0方式2
TH0 = 0xFD; //9600波特率
TL0 = TH0;
TR0 = 0; //在發送或接受才開始使用
TF0 = 0;
ET0 = 1; //允許允許定時器0中斷
EA=1; //中斷允許
void WByte(uint input)
//發送啟始位
uchar j=8;
newTXD=(bit)0; //發送8位數據位
while(j--)
newTXD=(bit)(input&0x01); //先傳低位
input=input>>1;
//發送校驗位(無)
//發送結束位
newTXD=(bit)1;
void Sendata()
for(i=0;i<sizeof(zhiling);i++)//外層循環,遍歷數組
WByte(zhiling[i]);
void display()
display_graphic_16x16(1,1,0,zong16);
display_graphic_16x16(1,17,0,dian16);
display_graphic_16x16(1,33,0,ya16);
display_string_8x16(1,49,0,":"); //總電壓
display_graphic_16x16(3,1,0,zong16);
display_graphic_16x16(3,17,0,dian16);
display_graphic_16x16(3,33,0,liu16);
display_string_8x16(3,49,0,":"); //總電流
display_graphic_16x16(5,1,0,sheng16);
display_graphic_16x16(5,17,0,yu16);
display_graphic_16x16(5,33,0,dian16);
display_graphic_16x16(5,49,0,liang16);
display_string_8x16(5,65,0,":"); //剩余電量
display_graphic_16x16(7,1,0,dian16);
display_graphic_16x16(7,17,0,chi16);
display_graphic_16x16(7,33,0,wen16);
display_graphic_16x16(7,49,0,du16);
display_string_8x16(7,65,0,":"); //電池溫度
UartInit();
Sendata();
