查看: 13377|回復: 1
電源芯片CS5171引腳圖電路圖與資料手冊下載
cs5171其實需要一些處理。
CS5171引腳圖:
CS5171電路圖:
CS5171框圖:
The CS5171/2/3/4 products are 280 kHz/560 kHz switching
regulators with a high efficiency, 1.5 A integrated switch. These parts
operate over a wide input voltage range, from 2.7 V to 30 V. The
flexibility of the design allows the chips to operate in most power
supply configurations, including boost, flyback, forward, inverting,
and SEPIC. The ICs utilize current mode architecture, which allows
excellent load and line regulation, as well as a practical means for
limiting current. Combining high frequency operation with a highly
integrated regulator circuit results in an extremely compact power
supply solution. The circuit design includes provisions for features
such as frequency synchronization, shutdown, and feedback controls
for either positive or negative voltage regulation. These parts are
pin−to−pin compatible with LT1372/1373.
完整的pdf格式文檔51黑下載地址:
cs5171.pdf (187.43 KB, 下載次數: 85)
ID:405613 發表于 2022-3-15 15:46 | 只看該作者
有沒有中文的資料?英文的看不大懂
