制作出來的51單片機矩陣鍵盤控制播放音樂的實物圖如下:
在前人的基礎上改進了一下,按鍵共陽數碼管顯示,同時控制11個io口,定時播放音樂,按鍵P2^6是取消定時及播放。
- #include<reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define GPIO_KEY P1
- #define weixuan P2
- sbit BEEP=P2^5;
- sbit a= P3^7;sbit b= P3^3;sbit c= P3^4;sbit d= P3^5;
- sbit e= P3^6;sbit f= P2^2;sbit g= P2^3;sbit h= P2^4;
- sbit fm=P2^5; sbit key=P2^6;
- //uchar //用于存放定時器的高8
- //0~F的共陽數碼管段碼,最后一個是黑屏
- const uchar SEG_CODE[] =
- { 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
- 0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xFF
- sbit wei1=P2^0;
- sbit wei2=P2^1;
- sbit led1=P0^7;
- uchar ge,shi,bai;qian;KeyValue,j;timeh,timel;
- char aa=0;
- /*****延時函數*****/
- void delay1ms(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=112;y>0;y--); //12M晶振下,延時1MS
- void delay(uchar x)
- uchar i;
- while(x--)
- for (i = 0; i<13; i++) {;}
- void beep()
- BEEP=0; //關閉蜂鳴器
- delay(10); //延時
- BEEP=1; }
- /*****顯示函數*****/
- void xianshi(uchar k)
- ge=k%10; //個位
- shi=k/10; //十位
- bai=0;
- if(k>9)
- weixuan=0xfd;
- P0=SEG_CODE[ge];//個位段選
- delay1ms(10);
- weixuan=0xfe;
- P0=SEG_CODE[shi];//十位段碼,顯示
- delay1ms(10);
- else
- weixuan=0xfe;
- delay1ms(10);
- /***鍵盤掃描函數***/
- uchar keyscan()
- GPIO_KEY=0x0f; //P1口值準備
- if(GPIO_KEY!=0x0f)
- delay1ms(10); //延時消抖
- if(GPIO_KEY!=0x0f)//再次判斷
- GPIO_KEY=0x0f; //再次裝值準備
- switch(GPIO_KEY) //測試行
- case(0x07):KeyValue=0;break; //第一行
- case(0x0b):KeyValue=1;break; //第二行
- case(0x0d):KeyValue=2;break; //第三行
- case(0x0e):KeyValue=3;break; //第四行
- GPIO_KEY=0xf0; //高四位賦1,判斷準備
- case(0x70):KeyValue=KeyValue; break; //0-3
- case(0xb0):KeyValue=KeyValue+4; break; //4-7
- case(0xd0):KeyValue=KeyValue+8;break; //8-11
- case(0xe0):KeyValue=KeyValue+12;break;//12-15
- while((GPIO_KEY!=0x0f)&&(aa<10)) //判斷是否松手,假若沒有松手,
- //一段延時后依舊判斷松手完成
- { beep();
- delay1ms(5);
- aa++;
- aa=0;
- return KeyValue;
- uchar code zbjbxf[]=
- { //定義豬八戒背媳婦的簡譜數組
- 0x64,0xA3,0xC1,0xA2,0x62,0x84,0x61,0x81,0x61,0xA4,
- 0xA1,0x91,0xA1,0x81,0x64,0xA3,0xC1,0xD2,0xD2,0xD2,
- 0xA2,0xC4,0xA1,0xC1,0xA1,0xC1,0xD2,0xD2,0xD2,0xA2,
- 0xC4,0xC2,0x62,0xC2,0x62,0xA2,0xA2,0x84,0x94,0x94,
- 0x92,0x81,0x91, 0xA2,0xC2,0xD4,0xE4,0xA4,0xE4,0xA2,
- 0xE2,0xA2,0xE2,0xA2, 0xA2,0x84,0x94,0x94,0x92,0x81,
- 0x91,0xA2,0xC2,0xD8
- }; //適合12M 的晶振定時器初值表,高低 位分開
- uchar code chuzhi[]=
- 0xff,0xff,0xFC,0x8E,0xFC, 0xED,0xFD,0x43,0xFD,0x6A,
- 0xFD,0xB3,0xFD,0xF3,0xFE,0x2D,0xFE, 0x47,0xFE,0x76,
- 0xFE,0xA1,0xFE,0xC7,0xFE,0xD9,0xFE,0xF9,0xFF,0x16
- void timer0() interrupt 1 //定時器0中斷服務程序
- TH0=timeh;//將timeh 賦給計時器的高8
- TL0=timel;//將timel 賦給計時器的低8
- fm=~fm;
- }//定時器每次到時將蜂鳴器反相
- void delay0(uint z)
- { uint y;
- for(z;z>0;z--)
- for(y=19000;y>0;y--);
- void delay1(uint z)
- { uint y;
- for(z;z>0;z--)
- void delay3(unsigned int x)
- unsigned int i;
- while(x--)
- { if(key==0){delay1(5);if(key==0){break;}}
- for(i=0;i<113;i++);
- void play1()
- { uint temp; //存放簡譜數組中的每一個音符的臨時變量
- uchar jp; //jp 用于取出temp
- uchar i=0;
- while(1)
- temp=zbjbxf[i];
- if(temp==0xff) break;
- jp=temp/16;
- if(jp!=0)
- timeh=chuzhi[jp*2];
- timel=chuzhi[jp*2+1];
- TR0=1;//開定時器
- else {TR0=0;fm=1;}
- delay0(temp%16);TR0=0;fm=1; delay1(5); TR0=1;i++;//關定時器
- if(key==0){delay1(5);if(key==0){break;}}
- TR0=0;//關定時器
- fm=1; //關蜂鳴器
- /*****主函數*******/
- void main()
- uchar b;
- a=1; b=1;c=1;d=1;e=1;f=1;g=1;h=1;key=1;
- TMOD=0x01;//設置定時器T0工作于方式1
- IE=0x82; //允許T0 中斷
- while(1)
- if((GPIO_KEY!=0x0f)&&(aa<10))
- { delay1ms(10);//aa++;
- b=keyscan();
4X4鍵盤數碼管顯示及控制io 口.rar
(56.94 KB, 下載次數: 19)
2018-8-18 15:47 上傳
