使用的電機是12V的371電機,帶光柵編碼器,一圈是360線,電機帶減速機,減速比是 1:34
加上減速,一圈的脈沖是 360 * 34 = 12240
現(xiàn)在遇到2個問題,
1,一圈的脈沖太高了,因為加上減速機,一圈是12240,算上4倍頻,會變成48960,有點吃不銷了,也用不上這么精確。
2,很奇怪,按道理算下來,一圈是12440,應(yīng)該跑完360度,才會激發(fā)一次中斷,但現(xiàn)在是在180度的時候,就已經(jīng)產(chǎn)生一次中斷,
主要是想解決第1個問題,本來我是想通過輸入捕獲預(yù)分頻來控制,如果12240 / 8 = 1530,
可惜怎么試都不行,不知道為什么?
- TIM_ICInitTypeDef IC;
- IC.TIM_ICPrescaler = TIM_ICPSC_DIV8;
以下是定時器設(shè)置模塊代碼
- static void TIM4_Mode_Config(void)
- GPIO_InitTypeDef GPIO;
- TIM_TimeBaseInitTypeDef TimeBase;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
- /*- Õy½»±àÂëÆ÷êäèëòy½Å PB->6 PB->7 -*/
- GPIO.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
- GPIO.GPIO_Mode = GPIO_Mode_IN_FLOATING; // GPIO_Mode_IPU ; //GPIO_Mode_IPD;
- GPIO.GPIO_Speed = GPIO_Speed_10MHz;
- GPIO_Init(GPIOB, &GPIO);
- /*- TIM4±àÂëÆ÷Ä£ê½ÅäÖà -*/
- TIM_DeInit(TIM4);
- TimeBase.TIM_Period = 12240;
- TimeBase.TIM_Prescaler = 0;
- TimeBase.TIM_ClockDivision =TIM_CKD_DIV1 ;
- TimeBase.TIM_CounterMode = TIM_CounterMode_Up;
- //TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
- TIM_TimeBaseInit(TIM4, &TimeBase);
- //TIM_ICStructInit(&IC);
- IC.TIM_Channel = TIM_Channel_1 | TIM_Channel_2;
- IC.TIM_ICPolarity = TIM_ICPolarity_Rising;
- IC.TIM_ICSelection = TIM_ICSelection_DirectTI;
- IC.TIM_ICFilter = 0; //ÅäÖÃÂË2¨Æ÷
- TIM_ICInit(TIM4, &IC);
- //ÅäÖñàÂëÆ÷Ä£ê½′¥·¢Ô′oí¼«DÔ
- TIM_EncoderInterfaceConfig(TIM4, TIM_EncoderMode_TI1, TIM_ICPolarity_Rising ,TIM_ICPolarity_Rising);
- TIM_ITConfig(TIM4,TIM_IT_Update|TIM_IT_CC1 ,ENABLE);
- TIM4->CNT = 0;
- TIM_Cmd(TIM4, ENABLE);
- void TIM4_IRQHandler(void)
- if(TIM4->SR&0X0001)
- u8 dir = TIM4->CR1 & ( 1 << 4 );
- if(dir == 0x0000) circle += 1;
- else circle -= 1;
- TIM4->SR&=~(1<<0);
