全部資料51hei下載地址:
Sample_Code.rar
(10.72 MB, 下載次數(shù): 220)
2018-8-15 16:32 上傳
部分源碼預(yù)覽:
- #if 0
- //#define Enable_ADC_AIN0 ADCCON0&=0xF0;P17_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT0;ADCCON1|=SET_BIT0 //P17
- //#define Enable_ADC_AIN1 ADCCON0&=0xF0;ADCCON0|=0x01;P30_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT1;ADCCON1|=SET_BIT0 //P30
- //#define Enable_ADC_AIN2 ADCCON0&=0xF0;ADCCON0|=0x02;P07_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT2;ADCCON1|=SET_BIT0 //P07
- //#define Enable_ADC_AIN3 ADCCON0&=0xF0;ADCCON0|=0x03;P06_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT3;ADCCON1|=SET_BIT0 //P06
- //#define Enable_ADC_AIN4 ADCCON0&=0xF0;ADCCON0|=0x04;P05_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT4;ADCCON1|=SET_BIT0 //P05
- //#define Enable_ADC_AIN5 ADCCON0&=0xF0;ADCCON0|=0x05;P04_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT5;ADCCON1|=SET_BIT0 //P04
- //#define Enable_ADC_AIN6 ADCCON0&=0xF0;ADCCON0|=0x06;P03_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT6;ADCCON1|=SET_BIT0 //P03
- //#define Enable_ADC_AIN7 ADCCON0&=0xF0;ADCCON0|=0x07;P11_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT7;ADCCON1|=SET_BIT0 //P11
- //#define Enable_ADC_BandGap ADCCON0|=SET_BIT3;ADCCON0&=0xF8; //Band-gap 1.22V
- //#define PWM0_FALLINGEDGE_TRIG_ADC ADCCON0&=~SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
- //#define PWM2_FALLINGEDGE_TRIG_ADC ADCCON0&=~SET_BIT5;ADCCON0|=SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
- //#define PWM4_FALLINGEDGE_TRIG_ADC ADCCON0|=SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
- //#define PWM0_RISINGEDGE_TRIG_ADC ADCCON0&=~SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
- //#define PWM2_RISINGEDGE_TRIG_ADC ADCCON0&=~SET_BIT5;ADCCON0|=SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
- //#define PWM4_RISINGEDGE_TRIG_ADC ADCCON0|=SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
- //#define P04_FALLINGEDGE_TRIG_ADC ADCCON0|=0x30;ADCCON1&=0xF3;ADCCON1|=SET_BIT1;ADCCON1&=~SET_BIT6
- //#define P13_FALLINGEDGE_TRIG_ADC ADCCON0|=0x30;ADCCON1&=0xF3;ADCCON1|=SET_BIT1;ADCCON1|=SET_BIT6
- //#define P04_RISINGEDGE_TRIG_ADC ADCCON0|=0x30;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1;ADCCON1&=~SET_BIT6
- //#define P13_RISINGEDGE_TRIG_ADC ADCCON0|=0x30;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1;ADCCON1|=SET_BIT6
- #endif
- The main C function. Program execution starts
- here after stack initialization.
- void main (void)
- P12_Quasi_Mode; //For GPIO1 output, Find in "Function_define.h" - "GPIO INIT"
- InitialUART0_Timer1(115200);
- Enable_ADC_BandGap; //Find in "Function_define.h" - "ADC INIT"
- while(1)
- clr_ADCF;
- set_ADCS; // Each time ADC start trig signal
- while(ADCF == 0);
- printf ("\n Value = 0x%bx",ADCRH);
- printf ("\n Value = 0x%bx",ADCRL);
- clr_GPIO1;
- // Timer0_Delay1ms(100);
- set_GPIO1;
