查看: 5064|回復: 0
單片機lcd1602屏幕左移顯示程序
ID:382962 發表于 2018-8-15 10:52 | 顯示全部樓層 |閱讀模式
電路原理圖如下:
  1. #include<reg51.h>
  2. #include<sting.h>
  3. #define        uchar unsigned char
  4. #define uint unsigned int
  5. sbit  RS=P2^0;
  6. sbit  RW=P2^1;
  7. sbit   E=P2^2;
  8. uchar tab1[]={"1433223        "};
  9. uchar tab2[]={"        1433223"};
  10. void delay(uint x)
  11. {
  12. uint i,j;
  13. for(i=0;i<x;i++)
  14.         for(j=0;j<110;j++);
  15. }
  16. void writecmd(uchar com)
  17. {
  18. E=0;
  19. RS=0;
  20. RW=0;
  21. P3=com;
  22. delay(2);
  23. E=1;
  24. delay(2);
  25. E=0;
  26. }
  27. void writedata(uchar dat)
  28. {
  29.   E=0;
  30.   RS=1;
  31.   RW=0;
  32.   P3=dat;
  33.   delay(2);
  34.   E=1;
  35.   delay(2);
  36.   E=0;
  37. }
  38. void init(void)
  39. {
  40. delay(15);
  41. writecmd(0x38);
  42. delay(5);
  43. writecmd(0x38);
  44. delay(5);
  45. writecmd(0x38);
  46. writecmd(0x38);
  47. writecmd(0x08);
  48. writecmd(0x01);
  49. writecmd(0x06);
  50. writecmd(0x0c);
  51. }
  52. void main()
  53. {  uchar j;
  54.   init();
  55.   writecmd(0x80);
  56.   for(j=0;j<16;j++)
  57.   {
  58.    writedata(tab1[j]);
  59.         delay(100);
  60.   }
  61.   writecmd(0x80+0x40);
  62.   for(j=0;j<16;j++)
  63.   { writedata(tab2[j]);
  64.          delay(100);
  65.   }
  66.   while(1)
  67.   {
  68.   delay(200);
  69.    writecmd(0x18);
  70.    delay(200);
  71.   }
  72. }
