組態(tài)王51單片機(jī)ASCII協(xié)議編程
單片機(jī)源程序如下:
- #define uchar unsigned char
- #define uint unsigned int
- #define tim0 -50000
- #define BPS57600 -1 //11.0592
- #define BPS28800 -2 //11.0592
- #define BPS19200 -3 //11.0592
- #define BPS9600 -6 //11.0592
- #define BPS4800 -12 //11.0592
- //支持字節(jié)和字類(lèi)型,由于他的浮點(diǎn)怪異所以不支持
- idata uchar DatB[4]; //組態(tài)字節(jié)
- idata uint DatW[4]; //組態(tài)整數(shù)
- idata float DatF[4]; //組態(tài)浮點(diǎn)
- uchar Addr;
- bit RECV=0;
- idata uchar Rbuf[40],Rptr,Rnum;
- idata uchar Tbuf[40],Tptr,Tnum;
- code uchar asc[]="0123456789ABCDEF";
- uchar AscHex(uchar m)
- if(m>='0' && m<='9') return m-'0';
- else if(m>='A' && m<='F') return m-'A'+10;
- else if(m>='a' && m<='f') return m-'a'+10;
- return 0;
- uchar AscByte(uchar p) //ASC變BYTE
- uchar x1,x2;
- x1=AscHex(Rbuf[p]);
- x2=AscHex(Rbuf[p+1]);
- return x2+x1*16;
- void ByteAsc(uchar p) //BUYE變ASC
- Tbuf[Tnum++]=asc[p>>4];
- Tbuf[Tnum++]=asc[p&15];
- bit ChkLRC() //接收數(shù)據(jù)包效驗(yàn)
- uchar i,d,s=0;
- for(i=0;i<Rnum-2;i++) s^=Rbuf[i];
- d=AscByte(Rnum-2);
- return s==d;
- void SetLRC() //發(fā)送數(shù)據(jù)包效驗(yàn)并發(fā)送
- uchar i,s=0;
- for(i=0;i<Tnum;i++) s^=Tbuf[i];
- ByteAsc(s);
- Tbuf[Tnum++]=0x0d; //添加包結(jié)束符
- SBUF=0x40; //發(fā)送包起始并啟動(dòng)串口發(fā)送
- void serial() interrupt 4 using 2 //串口數(shù)據(jù)收發(fā)
- uchar m;
- if(RI) //接收部分
- RI=0; m=SBUF;
- if(m==0x40) //幀開(kāi)始
- Rptr=0; Rnum=0;
- else if(m==0x0D) //幀結(jié)束
- RECV=1;
- else if(Rnum<40) //包長(zhǎng)限制
- Rbuf[Rptr++]=m;
- Rnum++;
- if(TI) //發(fā)送部分
- TI=0;
- if(Tnum>0)
- SBUF=Tbuf[Tptr++];
- Tnum--;
- void KingASC() //通信協(xié)議的處理程序
- uint p,x0,x1,x2;
- uchar n,cmd,i;
- uchar *s;
- cmd=AscByte(2)&0xf;
- p=AscByte(4)*256+AscByte(6);
- n=AscByte(8);
- if((cmd&1)==0) //組態(tài)王從單片機(jī)讀數(shù)據(jù)
- Tnum=0; Tptr=0;
- ByteAsc(Addr);
- ByteAsc(n);
- switch(cmd&0x0c)
- case 0x00: //字節(jié)變量處理
- s=(uchar*)DatB+p;
- for(i=0;i<n;i++)
- ByteAsc(s[i]);
- break;
- case 0x04: //字變量處理
- s=(uchar*)DatW+2*p;
- for(i=0;i<n/2;i++)
- ByteAsc(s[2*i]);
- ByteAsc(s[2*i+1]);
- break;
- case 0x08: //浮點(diǎn)變量處理
- case 0x0c: //浮點(diǎn)變量處理
- s=(uchar*)DatF+4*p;
- for(i=0;i<n/4;i++)
- x1=s[4*i]&0x80;
- x2=s[4*i]<<1;
- x2+=(s[4*i+1])>>7;
- ByteAsc(x1+x2-126);
- ByteAsc((s[4*i+1])|0x80);
- ByteAsc(s[4*i+2]);
- ByteAsc(s[4*i+3]);
- break;
- SetLRC();
- else //組態(tài)王向單片機(jī)寫(xiě)數(shù)據(jù)
- switch(cmd&0x0c)
- case 0x00: ////字節(jié)變量處理
- s=(uchar*)DatB+p;
- for(i=0;i<n;i++)
- s[i]=AscByte(10+2*i);
- break;
- s[2*i]=AscByte(10+4*i);
- s[2*i+1]=AscByte(12+4*i);
- break;
- x0=AscByte(10+8*i);
- x1=x0&0x80;
- x2=x0&0x7f;
- x2=x2+126;
- x0=x1|(x2>>1);
- s[4*i]=x0;
- x0=AscByte(12+8*i)&0x7f;
- if(x2&1) x0=x0|0x80;
- s[4*i+1]=x0;
- s[4*i+2]=AscByte(14+8*i);
- s[4*i+3]=AscByte(16+8*i);
- break;
- Tnum=0; Tptr=0;
- ByteAsc(Addr);
- Tbuf[Tnum++]='#';
- Tbuf[Tnum++]='#';
- SetLRC();
- Rnum=0; Rptr=0;
- void timer0() interrupt 1 //定時(shí)對(duì)串口收到的數(shù)據(jù)包進(jìn)行處理
- TH0=tim0>>8; TL0=tim0;
- if(RECV)
- RECV=0;
- if(ChkLRC()) //先進(jìn)行數(shù)據(jù)效驗(yàn)
- if(AscByte(0)==Addr) KingASC(); //地址是本機(jī)則進(jìn)行協(xié)議的處理
- void Init() //對(duì)定時(shí)器及串口進(jìn)行初始化
- EA=1; ES=1; ET0=1;
- TMOD=0X21; IP=0x10;
- SCON=0X50; PCON=0X80;
- TH1=BPS19200; TR1=1; //串口波特率的設(shè)置
- TH0=tim0>>8; TL0=tim0; TR0=1;
- 主函數(shù):
- #include <reg52.h>
- #include <glzxj.h> //對(duì)協(xié)議的引用
- main()
- Init(); //資源的初始化
- DatB[0]=0xff; DatB[1]=0xff;
- DatW[0]=123; DatW[1]=234;
- DatW[2]=345; DatW[3]=456;
- DatF[0]=-1.123; DatF[1]=-1.145;
- DatF[2]=10.123; DatF[3]=100.145;
- Addr=1; //單片機(jī)地址設(shè)置
- while(1)
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
組態(tài)王單片機(jī)ASCII協(xié)議編程.rar
(25.66 KB, 下載次數(shù): 102)
2018-8-14 08:53 上傳
點(diǎn)擊文件名下載附件
評(píng)分
查看全部評(píng)分
