查看: 3606|回復(fù): 1
51單片機(jī)的HX711壓感模塊源程序資料(5kg電子秤)
ID:385913 發(fā)表于 2018-8-13 17:59 | 顯示全部樓層 |閱讀模式
51的HX711壓感模塊資料
單片機(jī)源程序如下:
  1. #include "main.h"
  2. #include "HX711.h"
  3. #include "uart.h"
  4. #include "LCD1602.h"
  5. #define   uchar unsigned char
  6. #define   uint unsigned int
  7. unsigned long HX711_Buffer = 0;
  8. unsigned long Weight_Maopi = 0;
  9. long Weight_Shiwu = 0;
  10. unsigned char flag = 0;
  11. bit Flag_ERROR = 0;
  12. bit Flag_send = 0;
  13. sbit speak= P3^5;
  14. unsigned char a;
  15. //校準(zhǔn)參數(shù)
  16. //因?yàn)椴煌膫鞲衅魈匦郧不是很一致,因此,每一個傳感器需要矯正這里這個參數(shù)才能使測量值很準(zhǔn)確。
  17. //當(dāng)發(fā)現(xiàn)測試出來的重量偏大時,增加該數(shù)值。
  18. //如果測試出來的重量偏小時,減小改數(shù)值。
  19. //該值可以為小數(shù)
  20. #define GapValue 390
  21. //****************************************************
  22. //主函數(shù)
  23. //****************************************************
  24. void main()
  25. {
  26.     Uart_Init();
  27.     Send_Word("Welcome to use!\n");
  28.
  29.         Init_LCD1602();
  30.         LCD1602_write_com(0x80);
  31.         LCD1602_write_word("Weight");
  32.         Delay_ms(1000);                 //延時,等待傳感器穩(wěn)定
  33.         Get_Maopi();                                //稱毛皮重量
  34.
  35.         while(1)
  36.         {
  37.                 if(RI == 1)
  38.                 {
  39.                         a=SBUF;//獲取接收數(shù)據(jù)
  40.                         RI = 0;    //
  41.                         switch (a)
  42.                         {
  43.                                 case 'a':
  44.                                 Get_Weight();
  45.                                 Send_ASCII(Weight_Shiwu/1000 + 0X30);
  46.                                 Send_ASCII(Weight_Shiwu%1000/100 + 0X30);
  47.                                 Send_ASCII(Weight_Shiwu%100/10 + 0X30);
  48.                                 Send_ASCII(Weight_Shiwu%10 + 0X30);
  49.                                 Send_Word("g-");
  50.                                 break;
  51.                                 case 'b':
  52.                                         Get_Maopi();
  53.                                         break;
  54.                                 case 'c':
  55.                                         Flag_send=1;
  56.                                         break;
  57.                                 case 'd':
  58.                                         Flag_send=0;
  59.                                         break;
  60.                         }
  61.                 }
  62.
  63.                 Get_Weight();                        //稱重
  64.                 Scan_Key();
  65.                 //顯示當(dāng)前重量
  66.                 if( Flag_ERROR == 1)
  67.                 {
  68.             Send_Word("ERROR\n");
  69.
  70.                         LCD1602_write_com(0x80+0x40);
  71.                         LCD1602_write_word("ERROR ");
  72.                         speak=0;
  73.                 }
  74.                 else
  75.                 {
  76.                         speak=1;
  77.             LCD1602_write_com(0x80+0x40);
  78.                                           LCD1602_write_data(Weight_Shiwu/1000 + 0X30);
  79.             LCD1602_write_data(Weight_Shiwu%1000/100 + 0X30);
  80.             LCD1602_write_data(Weight_Shiwu%100/10 + 0X30);
  81.             LCD1602_write_data(Weight_Shiwu%10 + 0X30);
  82.                                           LCD1602_write_word(" g");
  83.                         if( Flag_send == 1)
  84.                         {
  85.                                 Send_ASCII(Weight_Shiwu/1000 + 0X30);
  86.                                 Send_ASCII(Weight_Shiwu%1000/100 + 0X30);
  87.                                 Send_ASCII(Weight_Shiwu%100/10 + 0X30);
  88.                                 Send_ASCII(Weight_Shiwu%10 + 0X30);
  89.                                 Send_Word("g-");
  90.                         }
  91.
  92.                 }
  93.
  94.         }
  95. }
  96. //掃描按鍵
  97. void Scan_Key()
  98. {
  99.         if(KEY1 == 0)
  100.         {
  101.                 Delay_ms(5);
  102.                 if(KEY1 == 0)
  103.                 {
  104.                         while(KEY1 == 0);
  105.                                 Get_Maopi();
  106.                 }
  107.         }
  108. }
  109. //****************************************************
  110. //稱重
  111. //****************************************************
  112. void Get_Weight()
  113. {
  114.         Weight_Shiwu = HX711_Read();
  115.         Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                //獲取凈重
  116.         if(Weight_Shiwu > 0)
  117.         {
  118.                 Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/GapValue);         //計算實(shí)物的實(shí)際重量
  119.
  120.
  121.                 if(Weight_Shiwu > 5000)                //超重報警
  122.                 {
  123.                         Flag_ERROR = 1;
  124.                 }
  125.                 else
  126.                 {
  127.                         Flag_ERROR = 0;
  128.                 }
  129.         }
  130.         else
  131.         {
  132.                 Weight_Shiwu = 0;
  133.         //        Flag_ERROR = 1;                                //負(fù)重報警
  134.         }
  135.
  136. }
  137. //****************************************************
  138. //獲取毛皮重量
  139. //****************************************************
  140. void Get_Maopi()
  141. {
  142.         Weight_Maopi = HX711_Read();
  143. }
  144. //****************************************************
  145. //MS延時函數(shù)(12M晶振下測試)
  146. //****************************************************
  147. void Delay_ms(unsigned int n)
  148. {
  149.         unsigned int  i,j;
  150.         for(i=0;i<n;i++)
  151.                 for(j=0;j<123;j++);
  152. }
5kg電子秤程序.rar (76.68 KB, 下載次數(shù): 55)
無效樓層,該帖已經(jīng)被刪除
ID:549247 發(fā)表于 2019-7-30 16:14 | 顯示全部樓層
我想請問一下 Send_ASCII(Weight_Shiwu/1000 + 0X30);這段輸出的數(shù)值是ASCII格式還是正常數(shù)值格式?
