stm32f103c8 mpu6050
單片機(jī)源程序如下:
- $License:
- Copyright (C) 2011-2012 InvenSense Corporation, All Rights Reserved.
- See included License.txt for License information.
- * @addtogroup DRIVERS Sensor Driver Layer
- * @brief Hardware drivers to communicate with sensors via I2C.
- * @file inv_mpu.c
- * @brief An I2C-based driver for Invensense gyroscopes.
- * @details This driver currently works for the following devices:
- * MPU6050
- * MPU6500
- * MPU9150 (or MPU6050 w/ AK8975 on the auxiliary bus)
- * MPU9250 (or MPU6500 w/ AK8963 on the auxiliary bus)
- #include <stdio.h>
- #include <stdint.h>
- #include <stdlib.h>
- #include <string.h>
- #include <math.h>
- #include "inv_mpu.h"
- #include "stm32f10x.h"
- #include "I2C.h"
- #include "delay.h"
- #include "Time.h"
- #include "usart.h"
- /* The following functions must be defined for this platform:
- * i2c_write(unsigned char slave_addr, unsigned char reg_addr,
- * unsigned char length, unsigned char const *data)
- * i2c_read(unsigned char slave_addr, unsigned char reg_addr,
- * unsigned char length, unsigned char *data)
- * delay_ms(unsigned long num_ms)
- * get_ms(unsigned long *count)
- * reg_int_cb(void (*cb)(void), unsigned char port, unsigned char pin)
- * labs(long x)
- * fabsf(float x)
- * min(int a, int b)
- #define MPU6050
- #define MOTION_DRIVER_TARGET_MSP430
- #if defined MOTION_DRIVER_TARGET_MSP430
- /*#include "msp430.h"
- #include "msp430_i2c.h"
- #include "msp430_clock.h"
- #include "msp430_interrupt.h" */
- #define i2c_write i2cwrite
- #define i2c_read i2cread
- #define delay_ms delay_ms
- #define get_ms get_ms
- //static int reg_int_cb(struct int_param_s *int_param)
- // /*return msp430_reg_int_cb(int_param->cb, int_param->pin, int_param->lp_exit,
- // int_param->active_low);*/
- // return 0;
- //#define log_i(...) do {} while (0)
- //#define log_e(...) do {} while (0)
- #define log_e PrintChar
- #define log_i PrintChar
- /* labs is already defined by TI's toolchain. */
- /* fabs is for doubles. fabsf is for floats. */
- #define fabs fabsf
- #define min(a,b) ((a<b)?a:b)
- #elif defined EMPL_TARGET_MSP430
- #include "msp430.h"
- #include "log.h"
- #define i2c_write msp430_i2c_write
- #define i2c_read msp430_i2c_read
- #define delay_ms msp430_delay_ms
- #define get_ms msp430_get_clock_ms
- static inline int reg_int_cb(struct int_param_s *int_param)
- return msp430_reg_int_cb(int_param->cb, int_param->pin, int_param->lp_exit,
- int_param->active_low);
- #define log_i MPL_LOGI
- #define log_e MPL_LOGE
- #elif defined EMPL_TARGET_UC3L0
- /* Instead of using the standard TWI driver from the ASF library, we're using
- * a TWI driver that follows the slave address + register address convention.
- #include "twi.h"
- #include "sysclk.h"
- #include "log.h"
- #include "sensors_xplained.h"
- #include "uc3l0_clock.h"
- #define i2c_write(a, b, c, d) twi_write(a, b, d, c)
- #define i2c_read(a, b, c, d) twi_read(a, b, d, c)
- /* delay_ms is a function already defined in ASF. */
- #define get_ms uc3l0_get_clock_ms
- sensor_board_irq_connect(int_param->pin, int_param->cb, int_param->arg);
- return 0;
- /* UC3 is a 32-bit processor, so abs and labs are equivalent. */
- #define labs abs
- #define fabs(x) (((x)>0)?(x):-(x))
- #else
- //#error Gyro driver is missing the system layer implementations.
- #endif
- #if !defined MPU6050 && !defined MPU9150 && !defined MPU6500 && !defined MPU9250
- //#error Which gyro are you using? Define MPUxxxx in your compiler options.
- #endif
- /* Time for some messy macro work. =]
- * #define MPU9150
- * is equivalent to..
- * #define MPU6050
- * #define AK8975_SECONDARY
- * #define MPU9250
- * #define MPU6500
- * #define AK8963_SECONDARY
- #if defined MPU9150
- #ifndef MPU6050
- #define MPU6050
- #endif /* #ifndef MPU6050 */
- #if defined AK8963_SECONDARY
- #error "MPU9150 and AK8963_SECONDARY cannot both be defined."
- #elif !defined AK8975_SECONDARY /* #if defined AK8963_SECONDARY */
- #define AK8975_SECONDARY
- #endif /* #if defined AK8963_SECONDARY */
- #elif defined MPU9250 /* #if defined MPU9150 */
- #ifndef MPU6500
- #define MPU6500
- #endif /* #ifndef MPU6500 */
- #if defined AK8975_SECONDARY
- #error "MPU9250 and AK8975_SECONDARY cannot both be defined."
- #elif !defined AK8963_SECONDARY /* #if defined AK8975_SECONDARY */
- #define AK8963_SECONDARY
- #endif /* #if defined AK8975_SECONDARY */
- #endif /* #if defined MPU9150 */
- #if defined AK8975_SECONDARY || defined AK8963_SECONDARY
- #define AK89xx_SECONDARY
- #else
- /* #warning "No compass = less profit for Invensense. Lame." */
- #endif
- static int set_int_enable(unsigned char enable);
- /* Hardware registers needed by driver. */
- struct gyro_reg_s {
- unsigned char who_am_i;
- unsigned char rate_div;
- unsigned char lpf;
- unsigned char prod_id;
- unsigned char user_ctrl;
- unsigned char fifo_en;
- unsigned char gyro_cfg;
- unsigned char accel_cfg;
- //unsigned char accel_cfg2;
- //unsigned char lp_accel_odr;
- unsigned char motion_thr;
- unsigned char motion_dur;
- unsigned char fifo_count_h;
- unsigned char fifo_r_w;
- unsigned char raw_gyro;
- unsigned char raw_accel;
- unsigned char temp;
- unsigned char int_enable;
- unsigned char dmp_int_status;
- unsigned char int_status;
- //unsigned char accel_intel;
- unsigned char pwr_mgmt_1;
- unsigned char pwr_mgmt_2;
- unsigned char int_pin_cfg;
- unsigned char mem_r_w;
- unsigned char accel_offs;
- unsigned char i2c_mst;
- unsigned char bank_sel;
- unsigned char mem_start_addr;
- unsigned char prgm_start_h;
- #if defined AK89xx_SECONDARY
- unsigned char s0_addr;
- unsigned char s0_reg;
- unsigned char s0_ctrl;
- unsigned char s1_addr;
- unsigned char s1_reg;
- unsigned char s1_ctrl;
- unsigned char s4_ctrl;
- unsigned char s0_do;
- unsigned char s1_do;
- unsigned char i2c_delay_ctrl;
- unsigned char raw_compass;
- /* The I2C_MST_VDDIO bit is in this register. */
- unsigned char yg_offs_tc;
- #endif
- /* Information specific to a particular device. */
- struct hw_s {
- unsigned char addr;
- unsigned short max_fifo;
- unsigned char num_reg;
- unsigned short temp_sens;
- short temp_offset;
- unsigned short bank_size;
- unsigned short compass_fsr;
- #endif
- /* When entering motion interrupt mode, the driver keeps track of the
- * previous state so that it can be restored at a later time.
- * TODO: This is tacky. Fix it.
- struct motion_int_cache_s {
- unsigned short gyro_fsr;
- unsigned char accel_fsr;
- unsigned short lpf;
- unsigned short sample_rate;
- unsigned char sensors_on;
- unsigned char fifo_sensors;
- unsigned char dmp_on;
- /* Cached chip configuration data.
- * TODO: A lot of these can be handled with a bitmask.
- struct chip_cfg_s {
- /* Matches gyro_cfg >> 3 & 0x03 */
- unsigned char gyro_fsr;
- /* Matches accel_cfg >> 3 & 0x03 */
- /* Enabled sensors. Uses same masks as fifo_en, NOT pwr_mgmt_2. */
- unsigned char sensors;
- /* Matches config register. */
- unsigned char clk_src;
- /* Sample rate, NOT rate divider. */
- /* Matches fifo_en register. */
- unsigned char fifo_enable;
- /* Matches int enable register. */
- /* 1 if devices on auxiliary I2C bus appear on the primary. */
- unsigned char bypass_mode;
- /* 1 if half-sensitivity.
- * NOTE: This doesn't belong here, but everything else in hw_s is const,
- * and this allows us to save some precious RAM.
- unsigned char accel_half;
- /* 1 if device in low-power accel-only mode. */
- unsigned char lp_accel_mode;
- /* 1 if interrupts are only triggered on motion events. */
- unsigned char int_motion_only;
- struct motion_int_cache_s cache;
- /* 1 for active low interrupts. */
- unsigned char active_low_int;
- /* 1 for latched interrupts. */
- unsigned char latched_int;
- /* 1 if DMP is enabled. */
- /* Ensures that DMP will only be loaded once. */
- unsigned char dmp_loaded;
- /* Sampling rate used when DMP is enabled. */
- unsigned short dmp_sample_rate;
- #ifdef AK89xx_SECONDARY
- /* Compass sample rate. */
- unsigned short compass_sample_rate;
- unsigned char compass_addr;
- short mag_sens_adj[3];
- #endif
- /* Information for self-test. */
- struct test_s {
- unsigned long gyro_sens;
- unsigned long accel_sens;
- unsigned char reg_rate_div;
- unsigned char reg_lpf;
- unsigned char reg_gyro_fsr;
- unsigned char reg_accel_fsr;
- unsigned short wait_ms;
- unsigned char packet_thresh;
- float min_dps;
- float max_dps;
- float max_gyro_var;
- float min_g;
- float max_g;
- float max_accel_var;
- /* Gyro driver state variables. */
- struct gyro_state_s {
- const struct gyro_reg_s *reg;
- const struct hw_s *hw;
- struct chip_cfg_s chip_cfg;
- const struct test_s *test;
- /* Filter configurations. */
- enum lpf_e {
- INV_FILTER_256HZ_NOLPF2 = 0,
- INV_FILTER_188HZ,
- INV_FILTER_98HZ,
- INV_FILTER_42HZ,
- INV_FILTER_20HZ,
- INV_FILTER_10HZ,
- INV_FILTER_5HZ,
- INV_FILTER_2100HZ_NOLPF,
- NUM_FILTER
- /* Full scale ranges. */
- enum gyro_fsr_e {
- INV_FSR_250DPS = 0,
- INV_FSR_500DPS,
- INV_FSR_1000DPS,
- INV_FSR_2000DPS,
- NUM_GYRO_FSR
- enum accel_fsr_e {
- INV_FSR_2G = 0,
- INV_FSR_4G,
- INV_FSR_8G,
- INV_FSR_16G,
- NUM_ACCEL_FSR
- /* Clock sources. */
- enum clock_sel_e {
- INV_CLK_INTERNAL = 0,
- INV_CLK_PLL,
- NUM_CLK
- /* Low-power accel wakeup rates. */
- enum lp_accel_rate_e {
- #if defined MPU6050
- INV_LPA_1_25HZ,
- INV_LPA_5HZ,
- INV_LPA_20HZ,
- INV_LPA_40HZ
- #elif defined MPU6500
- INV_LPA_0_3125HZ,
- INV_LPA_0_625HZ,
- INV_LPA_1_25HZ,
- INV_LPA_2_5HZ,
- INV_LPA_5HZ,
- INV_LPA_10HZ,
- INV_LPA_20HZ,
- INV_LPA_40HZ,
- INV_LPA_80HZ,
- INV_LPA_160HZ,
- INV_LPA_320HZ,
- INV_LPA_640HZ
- #endif
- #define BIT_I2C_MST_VDDIO (0x80)
- #define BIT_FIFO_EN (0x40)
- #define BIT_DMP_EN (0x80)
- #define BIT_FIFO_RST (0x04)
- #define BIT_DMP_RST (0x08)
- #define BIT_FIFO_OVERFLOW (0x10)
- #define BIT_DATA_RDY_EN (0x01)
- #define BIT_DMP_INT_EN (0x02)
- #define BIT_MOT_INT_EN (0x40)
- #define BITS_FSR (0x18)
- #define BITS_LPF (0x07)
- #define BITS_HPF (0x07)
- #define BITS_CLK (0x07)
- #define BIT_FIFO_SIZE_1024 (0x40)
- #define BIT_FIFO_SIZE_2048 (0x80)
- #define BIT_FIFO_SIZE_4096 (0xC0)
- #define BIT_RESET (0x80)
- #define BIT_SLEEP (0x40)
- #define BIT_S0_DELAY_EN (0x01)
- #define BIT_S2_DELAY_EN (0x04)
- #define BITS_SLAVE_LENGTH (0x0F)
- #define BIT_SLAVE_BYTE_SW (0x40)
- #define BIT_SLAVE_GROUP (0x10)
- #define BIT_SLAVE_EN (0x80)
- #define BIT_I2C_READ (0x80)
- #define BITS_I2C_MASTER_DLY (0x1F)
- #define BIT_AUX_IF_EN (0x20)
- #define BIT_ACTL (0x80)
- #define BIT_LATCH_EN (0x20)
- #define BIT_ANY_RD_CLR (0x10)
- #define BIT_BYPASS_EN (0x02)
- #define BITS_WOM_EN (0xC0)
- #define BIT_LPA_CYCLE (0x20)
- #define BIT_STBY_XA (0x20)
- #define BIT_STBY_YA (0x10)
- #define BIT_STBY_ZA (0x08)
- #define BIT_STBY_XG (0x04)
- #define BIT_STBY_YG (0x02)
- #define BIT_STBY_ZG (0x01)
- #define BIT_STBY_XYZA (BIT_STBY_XA | BIT_STBY_YA | BIT_STBY_ZA)
- #define BIT_STBY_XYZG (BIT_STBY_XG | BIT_STBY_YG | BIT_STBY_ZG)
- #define SUPPORTS_AK89xx_HIGH_SENS (0x00)
- #define AK89xx_FSR (9830)
- #elif defined AK8963_SECONDARY
- #define SUPPORTS_AK89xx_HIGH_SENS (0x10)
- #define AK89xx_FSR (4915)
- #endif
- #define AKM_REG_WHOAMI (0x00)
- #define AKM_REG_ST1 (0x02)
- #define AKM_REG_HXL (0x03)
- #define AKM_REG_ST2 (0x09)
- #define AKM_REG_CNTL (0x0A)
- #define AKM_REG_ASTC (0x0C)
- #define AKM_REG_ASAX (0x10)
- #define AKM_REG_ASAY (0x11)
- #define AKM_REG_ASAZ (0x12)
- #define AKM_DATA_READY (0x01)
- #define AKM_DATA_OVERRUN (0x02)
- #define AKM_OVERFLOW (0x80)
- #define AKM_DATA_ERROR (0x40)
- #define AKM_BIT_SELF_TEST (0x40)
- #define AKM_POWER_DOWN (0x00 | SUPPORTS_AK89xx_HIGH_SENS)
- #define AKM_SINGLE_MEASUREMENT (0x01 | SUPPORTS_AK89xx_HIGH_SENS)
- #define AKM_FUSE_ROM_ACCESS (0x0F | SUPPORTS_AK89xx_HIGH_SENS)
- #define AKM_MODE_SELF_TEST (0x08 | SUPPORTS_AK89xx_HIGH_SENS)
- #define AKM_WHOAMI (0x48)
- #endif
- const struct gyro_reg_s reg = {
- .who_am_i = 0x75,
- .rate_div = 0x19,
- .lpf = 0x1A,
- .prod_id = 0x0C,
- .user_ctrl = 0x6A,
- .fifo_en = 0x23,
- .gyro_cfg = 0x1B,
- .accel_cfg = 0x1C,
- .motion_thr = 0x1F,
- .motion_dur = 0x20,
- .fifo_count_h = 0x72,
- .fifo_r_w = 0x74,
- .raw_gyro = 0x43,
- .raw_accel = 0x3B,
- .temp = 0x41,
- .int_enable = 0x38,
- .dmp_int_status = 0x39,
- .int_status = 0x3A,
- .pwr_mgmt_1 = 0x6B,
- .pwr_mgmt_2 = 0x6C,
- .int_pin_cfg = 0x37,
- .mem_r_w = 0x6F,
- .accel_offs = 0x06,
- .i2c_mst = 0x24,
- .bank_sel = 0x6D,
- .mem_start_addr = 0x6E,
- .prgm_start_h = 0x70
- ,.raw_compass = 0x49,
- .yg_offs_tc = 0x01,
- .s0_addr = 0x25,
- .s0_reg = 0x26,
- .s0_ctrl = 0x27,
- .s1_addr = 0x28,
- .s1_reg = 0x29,
- .s1_ctrl = 0x2A,
- .s4_ctrl = 0x34,
- .s0_do = 0x63,
- .s1_do = 0x64,
- .i2c_delay_ctrl = 0x67
- #endif
- const struct hw_s hw = {
- .addr = 0x68,
- .max_fifo = 1024,
- .num_reg = 118,
- .temp_sens = 340,
- .temp_offset = -521,
- .bank_size = 256
- ,.compass_fsr = AK89xx_FSR
- #endif
- const struct hw_s hw={
- 0x68, //addr
- 1024, //max_fifo
- 118, //num_reg
- 340, //temp_sens
- -521, //temp_offset
- 256 //bank_size
- 0x75, //who_am_i
- 0x19, //rate_div
- 0x1A, //lpf
- 0x0C, //prod_id
- 0x6A, //user_ctrl
- 0x23, //fifo_en
- 0x1B, //gyro_cfg
- 0x1C, //accel_cfg
- 0x1F, // motion_thr
- 0x20, // motion_dur
- 0x72, // fifo_count_h
- 0x74, // fifo_r_w
- 0x43, // raw_gyro
- 0x3B, // raw_accel
- 0x41, // temp
- 0x38, // int_enable
- 0x39, // dmp_int_status
- 0x3A, // int_status
- 0x6B, // pwr_mgmt_1
- 0x6C, // pwr_mgmt_2
- 0x37, // int_pin_cfg
- 0x6F, // mem_r_w
- 0x06, // accel_offs
- 0x24, // i2c_mst
- 0x6D, // bank_sel
- 0x6E, // mem_start_addr
- 0x70 // prgm_start_h
- //const struct test_s test = {
- // .gyro_sens = 32768/250,
- // .accel_sens = 32768/16,
- // .reg_rate_div = 0, /* 1kHz. */
- // .reg_lpf = 1, /* 188Hz. */
- // .reg_gyro_fsr = 0, /* 250dps. */
- // .reg_accel_fsr = 0x18, /* 16g. */
- // .wait_ms = 50,
- // .packet_thresh = 5, /* 5% */
- // .min_dps = 10.f,
- // .max_dps = 105.f,
- // .max_gyro_var = 0.14f,
- // .min_g = 0.3f,
- // .max_g = 0.95f,
- // .max_accel_var = 0.14f
- const struct test_s test={
- 32768/250, //gyro_sens
- 32768/16, // accel_sens
- 0, // reg_rate_div
- 1, // reg_lpf
- 0, // reg_gyro_fsr
- 0x18, // reg_accel_fsr
- 50, // wait_ms
- 5, // packet_thresh
- 10.0f, // min_dps
- 105.0f, // max_dps
- 0.14f, // max_gyro_var
- 0.3f, // min_g
- 0.95f, // max_g
- 0.14f // max_accel_var
- static struct gyro_state_s st = {
- .reg = ®,
- .hw = &hw,
- .test = &test
- static struct gyro_state_s st={
- &hw,
- {0},
- &test
- //st.chip_cfg.dmp_on = 1;
- //st.dhip_cfg.fifo_enabel = 1;
- .who_am_i = 0x75,
- .rate_div = 0x19,
- .lpf = 0x1A,
- .prod_id = 0x0C,
- .fifo_en = 0x23,
- .gyro_cfg = 0x1B,
- .accel_cfg2 = 0x1D,
- .lp_accel_odr = 0x1E,
- .fifo_r_w = 0x74,
- .raw_gyro = 0x43,
- .temp = 0x41,
- .accel_intel = 0x69,
- .mem_r_w = 0x6F,
- .accel_offs = 0x77,
- .i2c_mst = 0x24,
- .bank_sel = 0x6D,
- .s0_addr = 0x25,
- .s0_reg = 0x26,
- .s0_ctrl = 0x27,
- .s1_addr = 0x28,
- .s1_reg = 0x29,
- .s1_ctrl = 0x2A,
- .s4_ctrl = 0x34,
- .s0_do = 0x63,
- .s1_do = 0x64,
- #endif
- .addr = 0x68,
- .max_fifo = 1024,
- .num_reg = 128,
- .temp_sens = 321,
- .temp_offset = 0,
- .bank_size = 256
- #endif
- // .wait_ms = 50,
- // .min_g = 0.3f,
- //static struct gyro_state_s st = {
- // .reg = ®,
- // .hw = &hw,
- // .test = &test
- #endif
- #define MAX_PACKET_LENGTH (12)
- static int setup_compass(void);
- #define MAX_COMPASS_SAMPLE_RATE (100)
- #endif
- * @brief Enable/disable data ready interrupt.
- * If the DMP is on, the DMP interrupt is enabled. Otherwise, the data ready
- * interrupt is used.
- * @param[in] enable 1 to enable interrupt.
- * @return 0 if successful.
- unsigned char tmp;
- if (st.chip_cfg.dmp_on) {
- if (enable)
- tmp = BIT_DMP_INT_EN;
- else
- tmp = 0x00;
- if (i2c_write(st.hw->addr, st.reg->int_enable, 1, &tmp))
- return -1;
- st.chip_cfg.int_enable = tmp;
- } else {
- if (!st.chip_cfg.sensors)
- return -1;
- if (enable && st.chip_cfg.int_enable)
- return 0;
- if (enable)
- tmp = BIT_DATA_RDY_EN;
- else
- tmp = 0x00;
- return -1;
- return 0;
- * @brief Register dump for testing.
- int mpu_reg_dump(void)
- unsigned char ii;
- unsigned char data;
- for (ii = 0; ii < st.hw->num_reg; ii++) {
- if (ii == st.reg->fifo_r_w || ii == st.reg->mem_r_w)
- continue;
- if (i2c_read(st.hw->addr, ii, 1, &data))
- return -1;
- //log_i("%#5x: %#5x\r\n", ii, data);
- return 0;
- * @brief Read from a single register.
- * NOTE: The memory and FIFO read/write registers cannot be accessed.
- * @param[in] reg Register address.
- * @param[out] data Register data.
- int mpu_read_reg(unsigned char reg, unsigned char *data)
- if (reg == st.reg->fifo_r_w || reg == st.reg->mem_r_w)
- return -1;
- if (reg >= st.hw->num_reg)
- return -1;
- return i2c_read(st.hw->addr, reg, 1, data);
- * @brief Initialize hardware.
- * Initial configuration:\n
- * Gyro FSR: +/- 2000DPS\n
- * Accel FSR +/- 2G\n
- * DLPF: 42Hz\n
- * FIFO rate: 50Hz\n
- * Clock source: Gyro PLL\n
- * FIFO: Disabled.\n
- * Data ready interrupt: Disabled, active low, unlatched.
- * @param[in] int_param Platform-specific parameters to interrupt API.
- int mpu_init(void)
- unsigned char data[6], rev;
- /* Reset device. */
- data[0] = 0x80;//BIT_RESET;
- if (i2c_write(st.hw->addr, st.reg->pwr_mgmt_1, 1, &(data[0])))
- return -1;
- delay_ms(100);
- /* Wake up chip. */
- data[0] = 0x00;
- return -1;
- /* Check product revision. */
- if (i2c_read(st.hw->addr, st.reg->accel_offs, 6, data))
- return -1;
- rev = ((data[5] & 0x01) << 2) | ((data[3] & 0x01) << 1) |
- (data[1] & 0x01);
- if (rev) {
- /* Congrats, these parts are better. */
- if (rev == 1)
- st.chip_cfg.accel_half = 1;
- else if (rev == 2)
- st.chip_cfg.accel_half = 0;
- else {
- log_e("Unsupported software product rev %d.\n");
- return -1;
- else {
- if (i2c_read(st.hw->addr, st.reg->prod_id, 1, &(data[0])))
- return -1;
- rev = data[0] & 0x0F;
- if (!rev) {
- log_e(" Product ID read as 0 indicates device is either "
- "incompatible or an MPU3050.\n");
- return -1;
- } else if (rev == 4) {
- log_i("Half sensitivity part found.\n");
- } else
- #define MPU6500_MEM_REV_ADDR (0x17)
- if (mpu_read_mem(MPU6500_MEM_REV_ADDR, 1, &rev))
- return -1;
- if (rev == 0x1)
- else {
- log_e("Unsupported software product rev %d.\n", rev);
- return -1;
- /* MPU6500 shares 4kB of memory between the DMP and the FIFO. Since the
- * first 3kB are needed by the DMP, we'll use the last 1kB for the FIFO.
- data[0] = BIT_FIFO_SIZE_1024 | 0x8;
- if (i2c_write(st.hw->addr, st.reg->accel_cfg2, 1, data))
- return -1;
- #endif
- /* Set to invalid values to ensure no I2C writes are skipped. */
- st.chip_cfg.sensors = 0xFF;
- st.chip_cfg.gyro_fsr = 0xFF;
- st.chip_cfg.accel_fsr = 0xFF;
- st.chip_cfg.lpf = 0xFF;
- st.chip_cfg.sample_rate = 0xFFFF;
- st.chip_cfg.fifo_enable = 0xFF;
- st.chip_cfg.bypass_mode = 0xFF;
- st.chip_cfg.compass_sample_rate = 0xFFFF;
- #endif
- /* mpu_set_sensors always preserves this setting. */
- st.chip_cfg.clk_src = INV_CLK_PLL;
- /* Handled in next call to mpu_set_bypass. */
- st.chip_cfg.active_low_int = 1;
- st.chip_cfg.latched_int = 0;
- st.chip_cfg.int_motion_only = 0;
- st.chip_cfg.lp_accel_mode = 0;
- memset(&st.chip_cfg.cache, 0, sizeof(st.chip_cfg.cache));
- st.chip_cfg.dmp_on = 0;
- st.chip_cfg.dmp_loaded = 0;
- st.chip_cfg.dmp_sample_rate = 0;
- if (mpu_set_gyro_fsr(2000))
- return -1;
- if (mpu_set_accel_fsr(2))
- return -1;
- if (mpu_set_lpf(42))
- return -1;
- if (mpu_set_sample_rate(50))
- return -1;
- if (mpu_configure_fifo(0))
- return -1;
- /*if (int_param)
- reg_int_cb(int_param);*/
- setup_compass();
- if (mpu_set_compass_sample_rate(10))
- return -1;
- #else
- /* Already disabled by setup_compass. */
- if (mpu_set_bypass(0))
- return -1;
- #endif
- mpu_set_sensors(0);
- return 0;
- * @brief Enter low-power accel-only mode.
- * In low-power accel mode, the chip goes to sleep and only wakes up to sample
- * the accelerometer at one of the following frequencies:
- * \n MPU6050: 1.25Hz, 5Hz, 20Hz, 40Hz
- * \n MPU6500: 1.25Hz, 2.5Hz, 5Hz, 10Hz, 20Hz, 40Hz, 80Hz, 160Hz, 320Hz, 640Hz
- * \n If the requested rate is not one listed above, the device will be set to
- * the next highest rate. Requesting a rate above the maximum supported
- * frequency will result in an error.
- * \n To select a fractional wake-up frequency, round down the value passed to
- * @e rate.
- * @param[in] rate Minimum sampling rate, or zero to disable LP
- * accel mode.
- int mpu_lp_accel_mode(unsigned char rate)
- unsigned char tmp[2];
- if (rate > 40)
- return -1;
- if (!rate) {
- mpu_set_int_latched(0);
- tmp[0] = 0;
- tmp[1] = BIT_STBY_XYZG;
- if (i2c_write(st.hw->addr, st.reg->pwr_mgmt_1, 2, tmp))
- return -1;
- return 0;
- /* For LP accel, we automatically configure the hardware to produce latched
- * interrupts. In LP accel mode, the hardware cycles into sleep mode before
- * it gets a chance to deassert the interrupt pin; therefore, we shift this
- * responsibility over to the MCU.
- * Any register read will clear the interrupt.
- mpu_set_int_latched(1);
- tmp[0] = BIT_LPA_CYCLE;
- if (rate == 1) {
- tmp[1] = INV_LPA_1_25HZ;
- mpu_set_lpf(5);
- } else if (rate <= 5) {
- tmp[1] = INV_LPA_5HZ;
- mpu_set_lpf(5);
- } else if (rate <= 20) {
- tmp[1] = INV_LPA_20HZ;
- mpu_set_lpf(10);
- } else {
- tmp[1] = INV_LPA_40HZ;
- mpu_set_lpf(20);
- tmp[1] = (tmp[1] << 6) | BIT_STBY_XYZG;
- return -1;
- /* Set wake frequency. */
- if (rate == 1)
- tmp[0] = INV_LPA_1_25HZ;
- else if (rate == 2)
- tmp[0] = INV_LPA_2_5HZ;
- else if (rate <= 5)
- tmp[0] = INV_LPA_5HZ;
- else if (rate <= 10)
- tmp[0] = INV_LPA_10HZ;
- else if (rate <= 20)
- tmp[0] = INV_LPA_20HZ;
- else if (rate <= 40)
- tmp[0] = INV_LPA_40HZ;
- else if (rate <= 80)
- tmp[0] = INV_LPA_80HZ;
- else if (rate <= 160)
- tmp[0] = INV_LPA_160HZ;
- else if (rate <= 320)
- tmp[0] = INV_LPA_320HZ;
- else
- tmp[0] = INV_LPA_640HZ;
- if (i2c_write(st.hw->addr, st.reg->lp_accel_odr, 1, tmp))
- return -1;
- if (i2c_write(st.hw->addr, st.reg->pwr_mgmt_1, 1, tmp))
- return -1;
- #endif
- st.chip_cfg.sensors = INV_XYZ_ACCEL;
- st.chip_cfg.clk_src = 0;
- st.chip_cfg.lp_accel_mode = 1;
- mpu_configure_fifo(0);
- return 0;
- * @brief Read raw gyro data directly from the registers.
- * @param[out] data Raw data in hardware units.
- * @param[out] timestamp Timestamp in milliseconds. Null if not needed.
- int mpu_get_gyro_reg(short *data, unsigned long *timestamp)
- unsigned char tmp[6];
- if (!(st.chip_cfg.sensors & INV_XYZ_GYRO))
- return -1;
- if (i2c_read(st.hw->addr, st.reg->raw_gyro, 6, tmp))
- return -1;
- data[0] = (tmp[0] << 8) | tmp[1];
- data[1] = (tmp[2] << 8) | tmp[3];
- data[2] = (tmp[4] << 8) | tmp[5];
- if (timestamp)
- get_ms(timestamp);
- return 0;
- * @brief Read raw accel data directly from the registers.
- int mpu_get_accel_reg(short *data, unsigned long *timestamp)
- if (!(st.chip_cfg.sensors & INV_XYZ_ACCEL))
- return -1;
- if (i2c_read(st.hw->addr, st.reg->raw_accel, 6, tmp))
- return -1;
- if (timestamp)
- return 0;
- * @brief Read temperature data directly from the registers.
- * @param[out] data Data in q16 format.
- int mpu_get_temperature(long *data, unsigned long *timestamp)
- short raw;
- if (!(st.chip_cfg.sensors))
- return -1;
- if (i2c_read(st.hw->addr, st.reg->temp, 2, tmp))
- return -1;
- raw = (tmp[0] << 8) | tmp[1];
- if (timestamp)
- data[0] = (long)((35 + ((raw - (float)st.hw->temp_offset) / st.hw->temp_sens)) * 65536L);
- return 0;
- * @brief Push biases to the accel bias registers.
- * This function expects biases relative to the current sensor output, and
- * these biases will be added to the factory-supplied values.
- * @param[in] accel_bias New biases.
- int mpu_set_accel_bias(const long *accel_bias)
- unsigned char data[6];
- short accel_hw[3];
- short got_accel[3];
- short fg[3];
- if (!accel_bias)
- return -1;
- if (!accel_bias[0] && !accel_bias[1] && !accel_bias[2])
- return 0;
- if (i2c_read(st.hw->addr, 3, 3, data))
- return -1;
- fg[0] = ((data[0] >> 4) + 8) & 0xf;
- fg[1] = ((data[1] >> 4) + 8) & 0xf;
- fg[2] = ((data[2] >> 4) + 8) & 0xf;
- accel_hw[0] = (short)(accel_bias[0] * 2 / (64 + fg[0]));
- accel_hw[1] = (short)(accel_bias[1] * 2 / (64 + fg[1]));
- accel_hw[2] = (short)(accel_bias[2] * 2 / (64 + fg[2]));
- if (i2c_read(st.hw->addr, 0x06, 6, data))
- return -1;
- got_accel[0] = ((short)data[0] << 8) | data[1];
- got_accel[1] = ((short)data[2] << 8) | data[3];
- got_accel[2] = ((short)data[4] << 8) | data[5];
- accel_hw[0] += got_accel[0];
- accel_hw[1] += got_accel[1];
- accel_hw[2] += got_accel[2];
- data[0] = (accel_hw[0] >> 8) & 0xff;
- data[1] = (accel_hw[0]) & 0xff;
- data[2] = (accel_hw[1] >> 8) & 0xff;
- data[3] = (accel_hw[1]) & 0xff;
- data[4] = (accel_hw[2] >> 8) & 0xff;
- data[5] = (accel_hw[2]) & 0xff;
- if (i2c_write(st.hw->addr, 0x06, 6, data))
- return -1;
- return 0;
- * @brief Reset FIFO read/write pointers.
- int mpu_reset_fifo(void)
- return -1;
- data = 0;
- if (i2c_write(st.hw->addr, st.reg->int_enable, 1, &data))
- return -1;
- if (i2c_write(st.hw->addr, st.reg->fifo_en, 1, &data))
- return -1;
- if (i2c_write(st.hw->addr, st.reg->user_ctrl, 1, &data))
- return -1;
- data = BIT_FIFO_RST | BIT_DMP_RST;
- return -1;
- delay_ms(50);
- data = BIT_DMP_EN | BIT_FIFO_EN;
- if (st.chip_cfg.sensors & INV_XYZ_COMPASS)
- data |= BIT_AUX_IF_EN;
- return -1;
- if (st.chip_cfg.int_enable)
- data = BIT_DMP_INT_EN;
- else
- data = 0;
- return -1;
- data = 0;
- return -1;
- } else {
- data = BIT_FIFO_RST;
- return -1;
- if (st.chip_cfg.bypass_mode || !(st.chip_cfg.sensors & INV_XYZ_COMPASS))
- data = BIT_FIFO_EN;
- else
- data = BIT_FIFO_EN | BIT_AUX_IF_EN;
- return -1;
- delay_ms(50);
- data = BIT_DATA_RDY_EN;
- else
- data = 0;
- return -1;
- if (i2c_write(st.hw->addr, st.reg->fifo_en, 1, &st.chip_cfg.fifo_enable))
- return -1;
- return 0;
- * @brief Get the gyro full-scale range.
- * @param[out] fsr Current full-scale range.
- int mpu_get_gyro_fsr(unsigned short *fsr)
- switch (st.chip_cfg.gyro_fsr) {
- case INV_FSR_250DPS:
- fsr[0] = 250;
- break;
- case INV_FSR_500DPS:
- fsr[0] = 500;
- break;
- case INV_FSR_1000DPS:
- fsr[0] = 1000;
- break;
- case INV_FSR_2000DPS:
- fsr[0] = 2000;
- break;
- default:
- fsr[0] = 0;
- break;
- return 0;
- * @brief Set the gyro full-scale range.
- * @param[in] fsr Desired full-scale range.
- int mpu_set_gyro_fsr(unsigned short fsr)
- return -1;
- switch (fsr) {
- case 250:
- data = INV_FSR_250DPS << 3;
- break;
- case 500:
- data = INV_FSR_500DPS << 3;
- break;
- case 1000:
- data = INV_FSR_1000DPS << 3;
- break;
- case 2000:
- data = INV_FSR_2000DPS << 3;
- break;
- default:
- return -1;
- if (st.chip_cfg.gyro_fsr == (data >> 3))
- return 0;
- if (i2c_write(st.hw->addr, st.reg->gyro_cfg, 1, &data))
- return -1;
- st.chip_cfg.gyro_fsr = data >> 3;
- return 0;
- * @brief Get the accel full-scale range.
- int mpu_get_accel_fsr(unsigned char *fsr)
- switch (st.chip_cfg.accel_fsr) {
- case INV_FSR_2G:
- fsr[0] = 2;
- break;
- case INV_FSR_4G:
- fsr[0] = 4;
- break;
- case INV_FSR_8G:
- fsr[0] = 8;
- break;
- case INV_FSR_16G:
- fsr[0] = 16;
- break;
- default:
- return -1;
- if (st.chip_cfg.accel_half)
- fsr[0] <<= 1;
- return 0;
- * @brief Set the accel full-scale range.
- int mpu_set_accel_fsr(unsigned char fsr)
- return -1;
- switch (fsr) {
- case 2:
- data = INV_FSR_2G << 3;
- break;
- case 4:
- data = INV_FSR_4G << 3;
- break;
- case 8:
- data = INV_FSR_8G << 3;
- break;
- case 16:
- data = INV_FSR_16G << 3;
- break;
- default:
- return -1;
- if (st.chip_cfg.accel_fsr == (data >> 3))
- return 0;
- if (i2c_write(st.hw->addr, st.reg->accel_cfg, 1, &data))
- return -1;
- st.chip_cfg.accel_fsr = data >> 3;
- return 0;
- * @brief Get the current DLPF setting.
- * @param[out] lpf Current LPF setting.
- * 0 if successful.
- int mpu_get_lpf(unsigned short *lpf)
- switch (st.chip_cfg.lpf) {
- case INV_FILTER_188HZ:
- lpf[0] = 188;
- break;
- case INV_FILTER_98HZ:
- lpf[0] = 98;
- break;
- case INV_FILTER_42HZ:
- lpf[0] = 42;
- break;
- case INV_FILTER_20HZ:
- lpf[0] = 20;
- break;
- case INV_FILTER_10HZ:
- lpf[0] = 10;
- break;
- case INV_FILTER_5HZ:
- lpf[0] = 5;
- break;
- case INV_FILTER_256HZ_NOLPF2:
- case INV_FILTER_2100HZ_NOLPF:
- default:
- lpf[0] = 0;
- break;
- return 0;
- * @brief Set digital low pass filter.
- * The following LPF settings are supported: 188, 98, 42, 20, 10, 5.
- * @param[in] lpf Desired LPF setting.
- int mpu_set_lpf(unsigned short lpf)
- return -1;
- if (lpf >= 188)
- data = INV_FILTER_188HZ;
- else if (lpf >= 98)
- data = INV_FILTER_98HZ;
- else if (lpf >= 42)
- data = INV_FILTER_42HZ;
- else if (lpf >= 20)
- data = INV_FILTER_20HZ;
- else if (lpf >= 10)
- data = INV_FILTER_10HZ;
- else
- data = INV_FILTER_5HZ;
- if (st.chip_cfg.lpf == data)
- return 0;
- if (i2c_write(st.hw->addr, st.reg->lpf, 1, &data))
- return -1;
- st.chip_cfg.lpf = data;
- return 0;
- * @brief Get sampling rate.
- * @param[out] rate Current sampling rate (Hz).
- int mpu_get_sample_rate(unsigned short *rate)
- return -1;
- else
- rate[0] = st.chip_cfg.sample_rate;
- return 0;
- * @brief Set sampling rate.
- * Sampling rate must be between 4Hz and 1kHz.
- * @param[in] rate Desired sampling rate (Hz).
- int mpu_set_sample_rate(unsigned short rate)
- return -1;
- return -1;
- else {
- if (st.chip_cfg.lp_accel_mode) {
- if (rate && (rate <= 40)) {
- /* Just stay in low-power accel mode. */
- mpu_lp_accel_mode(rate);
- return 0;
- /* Requested rate exceeds the allowed frequencies in LP accel mode,
- * switch back to full-power mode.
- mpu_lp_accel_mode(0);
- if (rate < 4)
- rate = 4;
- else if (rate > 1000)
- rate = 1000;
- data = 1000 / rate - 1;
- if (i2c_write(st.hw->addr, st.reg->rate_div, 1, &data))
- return -1;
- st.chip_cfg.sample_rate = 1000 / (1 + data);
- mpu_set_compass_sample_rate(min(st.chip_cfg.compass_sample_rate, MAX_COMPASS_SAMPLE_RATE));
- #endif
- /* Automatically set LPF to 1/2 sampling rate. */
- mpu_set_lpf(st.chip_cfg.sample_rate >> 1);
- return 0;
- * @brief Get compass sampling rate.
- * @param[out] rate Current compass sampling rate (Hz).
- int mpu_get_compass_sample_rate(unsigned short *rate)
- rate[0] = st.chip_cfg.compass_sample_rate;
- return 0;
- #else
- rate[0] = 0;
- return -1;
- #endif
- * @brief Set compass sampling rate.
- * The compass on the auxiliary I2C bus is read by the MPU hardware at a
- * maximum of 100Hz. The actual rate can be set to a fraction of the gyro
- * sampling rate.
- * \n WARNING: The new rate may be different than what was requested. Call
- * mpu_get_compass_sample_rate to check the actual setting.
- * @param[in] rate Desired compass sampling rate (Hz).
- int mpu_set_compass_sample_rate(unsigned short rate)
- unsigned char div;
- if (!rate || rate > st.chip_cfg.sample_rate || rate > MAX_COMPASS_SAMPLE_RATE)
- return -1;
- div = st.chip_cfg.sample_rate / rate - 1;
- if (i2c_write(st.hw->addr, st.reg->s4_ctrl, 1, &div))
- return -1;
- st.chip_cfg.compass_sample_rate = st.chip_cfg.sample_rate / (div + 1);
- return 0;
- #else
- return -1;
- #endif
- * @brief Get gyro sensitivity scale factor.
- * @param[out] sens Conversion from hardware units to dps.
- int mpu_get_gyro_sens(float *sens)
- sens[0] = 131.f;
- break;
- sens[0] = 65.5f;
- break;
- sens[0] = 32.8f;
- break;
- sens[0] = 16.4f;
- break;
- default:
- return -1;
- return 0;
- * @brief Get accel sensitivity scale factor.
- * @param[out] sens Conversion from hardware units to g's.
- int mpu_get_accel_sens(unsigned short *sens)
- case INV_FSR_2G:
- sens[0] = 16384;
- break;
- case INV_FSR_4G:
- sens[0] = 8092;
- break;
- case INV_FSR_8G:
- sens[0] = 4096;
- break;
- case INV_FSR_16G:
- sens[0] = 2048;
- break;
- default:
- return -1;
- sens[0] >>= 1;
- return 0;
- * @brief Get current FIFO configuration.
- * @e sensors can contain a combination of the following flags:
- * \n INV_X_GYRO, INV_Y_GYRO, INV_Z_GYRO
- * \n INV_XYZ_GYRO
- * \n INV_XYZ_ACCEL
- * @param[out] sensors Mask of sensors in FIFO.
- int mpu_get_fifo_config(unsigned char *sensors)
- sensors[0] = st.chip_cfg.fifo_enable;
- return 0;
- * @brief Select which sensors are pushed to FIFO.
- * \n INV_XYZ_GYRO
- * @param[in] sensors Mask of sensors to push to FIFO.
- int mpu_configure_fifo(unsigned char sensors)
- unsigned char prev;
- int result = 0;
- /* Compass data isn't going into the FIFO. Stop trying. */
- sensors &= ~INV_XYZ_COMPASS;
- return 0;
- else {
- return -1;
- prev = st.chip_cfg.fifo_enable;
- st.chip_cfg.fifo_enable = sensors & st.chip_cfg.sensors;
- if (st.chip_cfg.fifo_enable != sensors)
- /* You're not getting what you asked for. Some sensors are
- * asleep.
- result = -1;
- else
- result = 0;
- if (sensors || st.chip_cfg.lp_accel_mode)
- set_int_enable(1);
- else
- set_int_enable(0);
- if (sensors) {
- if (mpu_reset_fifo()) {
- st.chip_cfg.fifo_enable = prev;
- return -1;
- return result;
- * @brief Get current power state.
- * @param[in] power_on 1 if turned on, 0 if suspended.
- int mpu_get_power_state(unsigned char *power_on)
- if (st.chip_cfg.sensors)
- power_on[0] = 1;
- else
- power_on[0] = 0;
- return 0;
- * @brief Turn specific sensors on/off.
- * \n INV_XYZ_GYRO
- * \n INV_XYZ_COMPASS
- * @param[in] sensors Mask of sensors to wake.
- int mpu_set_sensors(unsigned char sensors)
- #endif
- if (sensors & INV_XYZ_GYRO)
- data = INV_CLK_PLL;
- else if (sensors)
- data = 0;
- else
- data = BIT_SLEEP;
- if (i2c_write(st.hw->addr, st.reg->pwr_mgmt_1, 1, &data)) {
- st.chip_cfg.sensors = 0;
- return -1;
- st.chip_cfg.clk_src = data & ~BIT_SLEEP;
- data = 0;
- if (!(sensors & INV_X_GYRO))
- data |= BIT_STBY_XG;
- if (!(sensors & INV_Y_GYRO))
- data |= BIT_STBY_YG;
- if (!(sensors & INV_Z_GYRO))
- data |= BIT_STBY_ZG;
- if (!(sensors & INV_XYZ_ACCEL))
- data |= BIT_STBY_XYZA;
- if (i2c_write(st.hw->addr, st.reg->pwr_mgmt_2, 1, &data)) {
- return -1;
- if (sensors && (sensors != INV_XYZ_ACCEL))
- /* Latched interrupts only used in LP accel mode. */
- #ifdef AK89xx_BYPASS
- if (sensors & INV_XYZ_COMPASS)
- mpu_set_bypass(1);
- else
- mpu_set_bypass(0);
- #else
- if (i2c_read(st.hw->addr, st.reg->user_ctrl, 1, &user_ctrl))
- return -1;
- /* Handle AKM power management. */
- if (sensors & INV_XYZ_COMPASS) {
- data = AKM_SINGLE_MEASUREMENT;
- user_ctrl |= BIT_AUX_IF_EN;
- } else {
- data = AKM_POWER_DOWN;
- user_ctrl &= ~BIT_AUX_IF_EN;
- user_ctrl |= BIT_DMP_EN;
- else
- user_ctrl &= ~BIT_DMP_EN;
- if (i2c_write(st.hw->addr, st.reg->s1_do, 1, &data))
- return -1;
- /* Enable/disable I2C master mode. */
- if (i2c_write(st.hw->addr, st.reg->user_ctrl, 1, &user_ctrl))
- return -1;
- #endif
- #endif
- st.chip_cfg.sensors = sensors;
- delay_ms(50);
- return 0;
- * @brief Read the MPU interrupt status registers.
- * @param[out] status Mask of interrupt bits.
- int mpu_get_int_status(short *status)
- return -1;
- if (i2c_read(st.hw->addr, st.reg->dmp_int_status, 2, tmp))
- return -1;
- status[0] = (tmp[0] << 8) | tmp[1];
- return 0;
- * @brief Get one packet from the FIFO.
- * If @e sensors does not contain a particular sensor, disregard the data
- * returned to that pointer.
- * \n @e sensors can contain a combination of the following flags:
- * \n INV_XYZ_GYRO
- * \n If the FIFO has no new data, @e sensors will be zero.
- * \n If the FIFO is disabled, @e sensors will be zero and this function will
- * return a non-zero error code.
- * @param[out] gyro Gyro data in hardware units.
- * @param[out] accel Accel data in hardware units.
- * @param[out] sensors Mask of sensors read from FIFO.
- * @param[out] more Number of remaining packets.
- int mpu_read_fifo(short *gyro, short *accel, unsigned long *timestamp,
- unsigned char *sensors, unsigned char *more)
- /* Assumes maximum packet size is gyro (6) + accel (6). */
- unsigned char data[MAX_PACKET_LENGTH];
- unsigned char packet_size = 0;
- unsigned short fifo_count, index = 0;
- return -1;
- sensors[0] = 0;
- return -1;
- if (!st.chip_cfg.fifo_enable)
- return -1;
- if (st.chip_cfg.fifo_enable & INV_X_GYRO)
- packet_size += 2;
- if (st.chip_cfg.fifo_enable & INV_Y_GYRO)
- packet_size += 2;
- if (st.chip_cfg.fifo_enable & INV_Z_GYRO)
- packet_size += 2;
- if (st.chip_cfg.fifo_enable & INV_XYZ_ACCEL)
- packet_size += 6;
- if (i2c_read(st.hw->addr, st.reg->fifo_count_h, 2, data))
- return -1;
- fifo_count = (data[0] << 8) | data[1];
- if (fifo_count < packet_size)
- return 0;
- // log_i("FIFO count: %hd\n", fifo_count);
- if (fifo_count > (st.hw->max_fifo >> 1)) {
- /* FIFO is 50% full, better check overflow bit. */
- if (i2c_read(st.hw->addr, st.reg->int_status, 1, data))
- return -1;
- if (data[0] & BIT_FIFO_OVERFLOW) {
- mpu_reset_fifo();
- return -2;
- get_ms((unsigned long*)timestamp);
- if (i2c_read(st.hw->addr, st.reg->fifo_r_w, packet_size, data))
- return -1;
- more[0] = fifo_count / packet_size - 1;
- sensors[0] = 0;
- if ((index != packet_size) && st.chip_cfg.fifo_enable & INV_XYZ_ACCEL) {
- accel[0] = (data[index+0] << 8) | data[index+1];
- accel[1] = (data[index+2] << 8) | data[index+3];
- accel[2] = (data[index+4] << 8) | data[index+5];
- sensors[0] |= INV_XYZ_ACCEL;
- index += 6;
- if ((index != packet_size) && st.chip_cfg.fifo_enable & INV_X_GYRO) {
- gyro[0] = (data[index+0] << 8) | data[index+1];
- sensors[0] |= INV_X_GYRO;
- index += 2;
- if ((index != packet_size) && st.chip_cfg.fifo_enable & INV_Y_GYRO) {
- gyro[1] = (data[index+0] << 8) | data[index+1];
- sensors[0] |= INV_Y_GYRO;
- index += 2;
- if ((index != packet_size) && st.chip_cfg.fifo_enable & INV_Z_GYRO) {
- gyro[2] = (data[index+0] << 8) | data[index+1];
- sensors[0] |= INV_Z_GYRO;
- index += 2;
- return 0;
- * @brief Get one unparsed packet from the FIFO.
- * This function should be used if the packet is to be parsed elsewhere.
- * @param[in] length Length of one FIFO packet.
- * @param[in] data FIFO packet.
- * @param[in] more Number of remaining packets.
- int mpu_read_fifo_stream(unsigned short length, unsigned char *data,
- unsigned char *more)
- unsigned short fifo_count;
- if (!st.chip_cfg.dmp_on)
- return -1;
- return -1;
- if (i2c_read(st.hw->addr, st.reg->fifo_count_h, 2, tmp))
- return -1;
- fifo_count = (tmp[0] << 8) | tmp[1];
- if (fifo_count < length) {
- more[0] = 0;
- return -1;
- if (i2c_read(st.hw->addr, st.reg->int_status, 1, tmp))
- return -1;
- if (tmp[0] & BIT_FIFO_OVERFLOW) {
- mpu_reset_fifo();
- return -2;
- if (i2c_read(st.hw->addr, st.reg->fifo_r_w, length, data))
- return -1;
- more[0] = fifo_count / length - 1;
- return 0;
- * @brief Set device to bypass mode.
- * @param[in] bypass_on 1 to enable bypass mode.
- int mpu_set_bypass(unsigned char bypass_on)
- if (st.chip_cfg.bypass_mode == bypass_on)
- return 0;
- if (bypass_on) {
- if (i2c_read(st.hw->addr, st.reg->user_ctrl, 1, &tmp))
- return -1;
- tmp &= ~BIT_AUX_IF_EN;
- if (i2c_write(st.hw->addr, st.reg->user_ctrl, 1, &tmp))
- return -1;
- delay_ms(3);
- tmp = BIT_BYPASS_EN;
- if (st.chip_cfg.active_low_int)
- tmp |= BIT_ACTL;
- if (st.chip_cfg.latched_int)
- tmp |= BIT_LATCH_EN | BIT_ANY_RD_CLR;
- if (i2c_write(st.hw->addr, st.reg->int_pin_cfg, 1, &tmp))
- return -1;
- } else {
- /* Enable I2C master mode if compass is being used. */
- return -1;
- tmp |= BIT_AUX_IF_EN;
- else
- return -1;
- delay_ms(3);
- tmp = BIT_ACTL;
- else
- tmp = 0;
- return -1;
- st.chip_cfg.bypass_mode = bypass_on;
- return 0;
- * @brief Set interrupt level.
- * @param[in] active_low 1 for active low, 0 for active high.
- int mpu_set_int_level(unsigned char active_low)
- st.chip_cfg.active_low_int = active_low;
- return 0;
- * @brief Enable latched interrupts.
- * Any MPU register will clear the interrupt.
- * @param[in] enable 1 to enable, 0 to disable.
- int mpu_set_int_latched(unsigned char enable)
- if (st.chip_cfg.latched_int == enable)
- return 0;
- if (enable)
- tmp = BIT_LATCH_EN | BIT_ANY_RD_CLR;
- else
- tmp = 0;
- if (st.chip_cfg.bypass_mode)
- tmp |= BIT_BYPASS_EN;
- tmp |= BIT_ACTL;
- return -1;
- st.chip_cfg.latched_int = enable;
- return 0;
- #ifdef MPU6050
- static int get_accel_prod_shift(float *st_shift)
- unsigned char tmp[4], shift_code[3], ii;
- if (i2c_read(st.hw->addr, 0x0D, 4, tmp))
- return 0x07;
- shift_code[0] = ((tmp[0] & 0xE0) >> 3) | ((tmp[3] & 0x30) >> 4);
- shift_code[1] = ((tmp[1] & 0xE0) >> 3) | ((tmp[3] & 0x0C) >> 2);
- shift_code[2] = ((tmp[2] & 0xE0) >> 3) | (tmp[3] & 0x03);
- for (ii = 0; ii < 3; ii++) {
- if (!shift_code[ii]) {
- st_shift[ii] = 0.f;
- continue;
- /* Equivalent to..
- * st_shift[ii] = 0.34f * powf(0.92f/0.34f, (shift_code[ii]-1) / 30.f)
- st_shift[ii] = 0.34f;
- while (--shift_code[ii])
- st_shift[ii] *= 1.034f;
- return 0;
- static int accel_self_test(long *bias_regular, long *bias_st)
- int jj, result = 0;
- float st_shift[3], st_shift_cust, st_shift_var;
- get_accel_prod_shift(st_shift);
- for(jj = 0; jj < 3; jj++) {
- st_shift_cust = labs(bias_regular[jj] - bias_st[jj]) / 65536.f;
- if (st_shift[jj]) {
- st_shift_var = st_shift_cust / st_shift[jj] - 1.f;
- if (fabs(st_shift_var) > test.max_accel_var)
- result |= 1 << jj;
- } else if ((st_shift_cust < test.min_g) ||
- (st_shift_cust > test.max_g))
- return result;
- static int gyro_self_test(long *bias_regular, long *bias_st)
- unsigned char tmp[3];
- float st_shift, st_shift_cust, st_shift_var;
- if (i2c_read(st.hw->addr, 0x0D, 3, tmp))
- return 0x07;
- tmp[0] &= 0x1F;
- tmp[1] &= 0x1F;
- tmp[2] &= 0x1F;
- for (jj = 0; jj < 3; jj++) {
- if (tmp[jj]) {
- st_shift = 3275.f / test.gyro_sens;
- while (--tmp[jj])
- st_shift *= 1.046f;
- st_shift_var = st_shift_cust / st_shift - 1.f;
- if (fabs(st_shift_var) > test.max_gyro_var)
- } else if ((st_shift_cust < test.min_dps) ||
- (st_shift_cust > test.max_dps))
- return result;
- static int compass_self_test(void)
- unsigned char tries = 10;
- int result = 0x07;
- short data;
- tmp[0] = AKM_POWER_DOWN;
- if (i2c_write(st.chip_cfg.compass_addr, AKM_REG_CNTL, 1, tmp))
- return 0x07;
- tmp[0] = AKM_BIT_SELF_TEST;
- if (i2c_write(st.chip_cfg.compass_addr, AKM_REG_ASTC, 1, tmp))
- goto AKM_restore;
- tmp[0] = AKM_MODE_SELF_TEST;
- goto AKM_restore;
- do {
- delay_ms(10);
- if (i2c_read(st.chip_cfg.compass_addr, AKM_REG_ST1, 1, tmp))
- goto AKM_restore;
- if (tmp[0] & AKM_DATA_READY)
- break;
- } while (tries--);
- if (!(tmp[0] & AKM_DATA_READY))
- goto AKM_restore;
- if (i2c_read(st.chip_cfg.compass_addr, AKM_REG_HXL, 6, tmp))
- goto AKM_restore;
- result = 0;
- data = (short)(tmp[1] << 8) | tmp[0];
- if ((data > 100) || (data < -100))
- result |= 0x01;
- data = (short)(tmp[3] << 8) | tmp[2];
- result |= 0x02;
- data = (short)(tmp[5] << 8) | tmp[4];
- if ((data > -300) || (data < -1000))
- result |= 0x04;
- AKM_restore:
- tmp[0] = 0 | SUPPORTS_AK89xx_HIGH_SENS;
- i2c_write(st.chip_cfg.compass_addr, AKM_REG_ASTC, 1, tmp);
- tmp[0] = SUPPORTS_AK89xx_HIGH_SENS;
- i2c_write(st.chip_cfg.compass_addr, AKM_REG_CNTL, 1, tmp);
- return result;
- #endif
- #endif
- static int get_st_biases(long *gyro, long *accel, unsigned char hw_test)
- unsigned char packet_count, ii;
- data[0] = 0x01;
- data[1] = 0;
- if (i2c_write(st.hw->addr, st.reg->pwr_mgmt_1, 2, data))
- return -1;
- delay_ms(200);
- data[0] = 0;
- if (i2c_write(st.hw->addr, st.reg->int_enable, 1, data))
- return -1;
- if (i2c_write(st.hw->addr, st.reg->fifo_en, 1, data))
- return -1;
- if (i2c_write(st.hw->addr, st.reg->pwr_mgmt_1, 1, data))
- return -1;
- if (i2c_write(st.hw->addr, st.reg->i2c_mst, 1, data))
- return -1;
- if (i2c_write(st.hw->addr, st.reg->user_ctrl, 1, data))
- return -1;
- data[0] = BIT_FIFO_RST | BIT_DMP_RST;
- return -1;
- delay_ms(15);
- data[0] = st.test->reg_lpf;
- if (i2c_write(st.hw->addr, st.reg->lpf, 1, data))
- return -1;
- data[0] = st.test->reg_rate_div;
- if (i2c_write(st.hw->addr, st.reg->rate_div, 1, data))
- return -1;
- if (hw_test)
- data[0] = st.test->reg_gyro_fsr | 0xE0;
- else
- data[0] = st.test->reg_gyro_fsr;
- if (i2c_write(st.hw->addr, st.reg->gyro_cfg, 1, data))
- return -1;
- if (hw_test)
- data[0] = st.test->reg_accel_fsr | 0xE0;
- else
- data[0] = test.reg_accel_fsr;
- if (i2c_write(st.hw->addr, st.reg->accel_cfg, 1, data))
- return -1;
- if (hw_test)
- delay_ms(200);
- /* Fill FIFO for test.wait_ms milliseconds. */
- data[0] = BIT_FIFO_EN;
- return -1;
- data[0] = INV_XYZ_GYRO | INV_XYZ_ACCEL;
- return -1;
- delay_ms(test.wait_ms);
- data[0] = 0;
- return -1;
- return -1;
- packet_count = fifo_count / MAX_PACKET_LENGTH;
- gyro[0] = gyro[1] = gyro[2] = 0;
- accel[0] = accel[1] = accel[2] = 0;
- for (ii = 0; ii < packet_count; ii++) {
- short accel_cur[3], gyro_cur[3];
- if (i2c_read(st.hw->addr, st.reg->fifo_r_w, MAX_PACKET_LENGTH, data))
- return -1;
- accel_cur[0] = ((short)data[0] << 8) | data[1];
- accel_cur[1] = ((short)data[2] << 8) | data[3];
- accel_cur[2] = ((short)data[4] << 8) | data[5];
- accel[0] += (long)accel_cur[0];
- accel[1] += (long)accel_cur[1];
- accel[2] += (long)accel_cur[2];
- gyro_cur[0] = (((short)data[6] << 8) | data[7]);
- gyro_cur[1] = (((short)data[8] << 8) | data[9]);
- gyro_cur[2] = (((short)data[10] << 8) | data[11]);
- gyro[0] += (long)gyro_cur[0];
- gyro[1] += (long)gyro_cur[1];
- gyro[2] += (long)gyro_cur[2];
- #ifdef EMPL_NO_64BIT
- gyro[0] = (long)(((float)gyro[0]*65536.f) / test.gyro_sens / packet_count);
- gyro[1] = (long)(((float)gyro[1]*65536.f) / test.gyro_sens / packet_count);
- gyro[2] = (long)(((float)gyro[2]*65536.f) / test.gyro_sens / packet_count);
- if (has_accel) {
- accel[0] = (long)(((float)accel[0]*65536.f) / test.accel_sens /
- packet_count);
- accel[1] = (long)(((float)accel[1]*65536.f) / test.accel_sens /
- packet_count);
- accel[2] = (long)(((float)accel[2]*65536.f) / test.accel_sens /
- packet_count);
- /* Don't remove gravity! */
- accel[2] -= 65536L;
- #else
- gyro[0] = (long)(((long long)gyro[0]<<16) / test.gyro_sens / packet_count);
- gyro[1] = (long)(((long long)gyro[1]<<16) / test.gyro_sens / packet_count);
- gyro[2] = (long)(((long long)gyro[2]<<16) / test.gyro_sens / packet_count);
- accel[0] = (long)(((long long)accel[0]<<16) / test.accel_sens /
- packet_count);
- accel[1] = (long)(((long long)accel[1]<<16) / test.accel_sens /
- packet_count);
- accel[2] = (long)(((long long)accel[2]<<16) / test.accel_sens /
- packet_count);
- if (accel[2] > 0L)
- else
- accel[2] += 65536L;
- #endif
- return 0;
- * @brief Trigger gyro/accel/compass self-test.
- * On success/error, the self-test returns a mask representing the sensor(s)
- * that failed. For each bit, a one (1) represents a "pass" case; conversely,
- * a zero (0) indicates a failure.
- * \n The mask is defined as follows:
- * \n Bit 0: Gyro.
- * \n Bit 1: Accel.
- * \n Bit 2: Compass.
- * \n Currently, the hardware self-test is unsupported for MPU6500. However,
- * this function can still be used to obtain the accel and gyro biases.
- * \n This function must be called with the device either face-up or face-down
- * (z-axis is parallel to gravity).
- * @param[out] gyro Gyro biases in q16 format.
- * @param[out] accel Accel biases (if applicable) in q16 format.
- * @return Result mask (see above).
- int mpu_run_self_test(long *gyro, long *accel)
- #ifdef MPU6050
- const unsigned char tries = 2;
- long gyro_st[3], accel_st[3];
- unsigned char accel_result, gyro_result;
- unsigned char compass_result;
- #endif
- int ii;
- #endif
- int result;
- unsigned char accel_fsr, fifo_sensors, sensors_on;
- unsigned short gyro_fsr, sample_rate, lpf;
- unsigned char dmp_was_on;
- mpu_set_dmp_state(0);
- dmp_was_on = 1;
- } else
- dmp_was_on = 0;
- /* Get initial settings. */
- mpu_get_gyro_fsr(&gyro_fsr);
- mpu_get_accel_fsr(&accel_fsr);
- mpu_get_lpf(&lpf);
- mpu_get_sample_rate(&sample_rate);
- sensors_on = st.chip_cfg.sensors;
- mpu_get_fifo_config(&fifo_sensors);
- /* For older chips, the self-test will be different. */
- for (ii = 0; ii < tries; ii++)
- if (!get_st_biases(gyro, accel, 0))
- break;
- if (ii == tries) {
- /* If we reach this point, we most likely encountered an I2C error.
- * We'll just report an error for all three sensors.
- result = 0;
- goto restore;
- if (!get_st_biases(gyro_st, accel_st, 1))
- break;
- /* Again, probably an I2C error. */
- result = 0;
- goto restore;
- accel_result = accel_self_test(accel, accel_st);
- gyro_result = gyro_self_test(gyro, gyro_st);
- result = 0;
- if (!gyro_result)
- result |= 0x01;
- if (!accel_result)
- result |= 0x02;
- compass_result = compass_self_test();
- if (!compass_result)
- result |= 0x04;
- #endif
- restore:
- /* For now, this function will return a "pass" result for all three sensors
- * for compatibility with current test applications.
- get_st_biases(gyro, accel, 0);
- result = 0x3;
- #endif
- mpu_set_gyro_fsr(gyro_fsr);
- mpu_set_accel_fsr(accel_fsr);
- mpu_set_lpf(lpf);
- mpu_set_sample_rate(sample_rate);
- mpu_set_sensors(sensors_on);
- mpu_configure_fifo(fifo_sensors);
- if (dmp_was_on)
- mpu_set_dmp_state(1);
- return result;
- * @brief Write to the DMP memory.
- * This function prevents I2C writes past the bank boundaries. The DMP memory
- * is only accessible when the chip is awake.
- * @param[in] mem_addr Memory location (bank << 8 | start address)
- * @param[in] length Number of bytes to write.
- * @param[in] data Bytes to write to memory.
- int mpu_write_mem(unsigned short mem_addr, unsigned short length,
- unsigned char *data)
- if (!data)
- return -1;
- return -1;
- tmp[0] = (unsigned char)(mem_addr >> 8);
- tmp[1] = (unsigned char)(mem_addr & 0xFF);
- /* Check bank boundaries. */
- if (tmp[1] + length > st.hw->bank_size)
- return -1;
- if (i2c_write(st.hw->addr, st.reg->bank_sel, 2, tmp))
- return -1;
- if (i2c_write(st.hw->addr, st.reg->mem_r_w, length, data))
- return -1;
- return 0;
- * @brief Read from the DMP memory.
- * This function prevents I2C reads past the bank boundaries. The DMP memory
- * @param[in] length Number of bytes to read.
- * @param[out] data Bytes read from memory.
- int mpu_read_mem(unsigned short mem_addr, unsigned short length,
- if (!data)
- return -1;
- return -1;
- return -1;
- return -1;
- if (i2c_read(st.hw->addr, st.reg->mem_r_w, length, data))
- return -1;
- return 0;
- * @brief Load and verify DMP image.
- * @param[in] length Length of DMP image.
- * @param[in] firmware DMP code.
- * @param[in] start_addr Starting address of DMP code memory.
- * @param[in] sample_rate Fixed sampling rate used when DMP is enabled.
- int mpu_load_firmware(unsigned short length, const unsigned char *firmware,
- unsigned short start_addr, unsigned short sample_rate)
- unsigned short ii;
- unsigned short this_write;
- /* Must divide evenly into st.hw->bank_size to avoid bank crossings. */
- #define LOAD_CHUNK (16)
- unsigned char cur[LOAD_CHUNK], tmp[2];
- if (st.chip_cfg.dmp_loaded)
- /* DMP should only be loaded once. */
- return -1;
- if (!firmware)
- return -1;
- for (ii = 0; ii < length; ii += this_write) {
- this_write = min(LOAD_CHUNK, length - ii);
- if (mpu_write_mem(ii, this_write, (unsigned char*)&firmware[ii]))
- return -1;
- if (mpu_read_mem(ii, this_write, cur))
- return -1;
- if (memcmp(firmware+ii, cur, this_write))
- return -2;
- /* Set program start address. */
- tmp[0] = start_addr >> 8;
- tmp[1] = start_addr & 0xFF;
- if (i2c_write(st.hw->addr, st.reg->prgm_start_h, 2, tmp))
- return -1;
- st.chip_cfg.dmp_loaded = 1;
- st.chip_cfg.dmp_sample_rate = sample_rate;
- return 0;
- * @brief Enable/disable DMP support.
- * @param[in] enable 1 to turn on the DMP.
- int mpu_set_dmp_state(unsigned char enable)
- if (st.chip_cfg.dmp_on == enable)
- return 0;
- if (enable) {
- if (!st.chip_cfg.dmp_loaded)
- return -1;
- /* Disable data ready interrupt. */
- /* Disable bypass mode. */
- /* Keep constant sample rate, FIFO rate controlled by DMP. */
- mpu_set_sample_rate(st.chip_cfg.dmp_sample_rate);
- /* Remove FIFO elements. */
- tmp = 0;
- i2c_write(st.hw->addr, 0x23, 1, &tmp);
- st.chip_cfg.dmp_on = 1;
- /* Enable DMP interrupt. */
- mpu_reset_fifo();
- } else {
- /* Disable DMP interrupt. */
- /* Restore FIFO settings. */
- tmp = st.chip_cfg.fifo_enable;
- mpu_reset_fifo();
- return 0;
- * @brief Get DMP state.
- * @param[out] enabled 1 if enabled.
- int mpu_get_dmp_state(unsigned char *enabled)
- enabled[0] = st.chip_cfg.dmp_on;
- return 0;
- /* This initialization is similar to the one in ak8975.c. */
- //static int setup_compass(void)
- //#ifdef AK89xx_SECONDARY
- // unsigned char data[4], akm_addr;
- // mpu_set_bypass(1);
- // /* Find compass. Possible addresses range from 0x0C to 0x0F. */
- // for (akm_addr = 0x0C; akm_addr <= 0x0F; akm_addr++) {
- // int result;
- // result = i2c_read(akm_addr, AKM_REG_WHOAMI, 1, data);
- // if (!result && (data[0] == AKM_WHOAMI))
- // break;
- // if (akm_addr > 0x0F) {
- // /* TODO: Handle this case in all compass-related functions. */
- // log_e("Compass not found.\n");
- // return -1;
- // st.chip_cfg.compass_addr = akm_addr;
- // data[0] = AKM_POWER_DOWN;
- // if (i2c_write(st.chip_cfg.compass_addr, AKM_REG_CNTL, 1, data))
- // return -1;
- // delay_ms(1);
- // data[0] = AKM_FUSE_ROM_ACCESS;
- // return -1;
- // delay_ms(1);
- // /* Get sensitivity adjustment data from fuse ROM. */
- // if (i2c_read(st.chip_cfg.compass_addr, AKM_REG_ASAX, 3, data))
- // return -1;
- // st.chip_cfg.mag_sens_adj[0] = (long)data[0] + 128;
- // st.chip_cfg.mag_sens_adj[1] = (long)data[1] + 128;
- // st.chip_cfg.mag_sens_adj[2] = (long)data[2] + 128;
- // return -1;
- // delay_ms(1);
- // mpu_set_bypass(0);
- // /* Set up master mode, master clock, and ES bit. */
- // data[0] = 0x40;
- // if (i2c_write(st.hw->addr, st.reg->i2c_mst, 1, data))
- // return -1;
- // /* Slave 0 reads from AKM data registers. */
- // data[0] = BIT_I2C_READ | st.chip_cfg.compass_addr;
- // if (i2c_write(st.hw->addr, st.reg->s0_addr, 1, data))
- // return -1;
- // /* Compass reads start at this register. */
- // data[0] = AKM_REG_ST1;
- // if (i2c_write(st.hw->addr, st.reg->s0_reg, 1, data))
- // return -1;
- // /* Enable slave 0, 8-byte reads. */
- // data[0] = BIT_SLAVE_EN | 8;
- // if (i2c_write(st.hw->addr, st.reg->s0_ctrl, 1, data))
- // return -1;
- // /* Slave 1 changes AKM measurement mode. */
- // data[0] = st.chip_cfg.compass_addr;
- // if (i2c_write(st.hw->addr, st.reg->s1_addr, 1, data))
- // return -1;
- // /* AKM measurement mode register. */
- // data[0] = AKM_REG_CNTL;
- // if (i2c_write(st.hw->addr, st.reg->s1_reg, 1, data))
- // return -1;
- // /* Enable slave 1, 1-byte writes. */
- // data[0] = BIT_SLAVE_EN | 1;
- // if (i2c_write(st.hw->addr, st.reg->s1_ctrl, 1, data))
- // return -1;
- // /* Set slave 1 data. */
- // data[0] = AKM_SINGLE_MEASUREMENT;
- // if (i2c_write(st.hw->addr, st.reg->s1_do, 1, data))
- // return -1;
- // /* Trigger slave 0 and slave 1 actions at each sample. */
- // data[0] = 0x03;
- // if (i2c_write(st.hw->addr, st.reg->i2c_delay_ctrl, 1, data))
- // return -1;
- //#ifdef MPU9150
- // /* For the MPU9150, the auxiliary I2C bus needs to be set to VDD. */
- // data[0] = BIT_I2C_MST_VDDIO;
- // if (i2c_write(st.hw->addr, st.reg->yg_offs_tc, 1, data))
- // return -1;
- //#endif
- // return 0;
- //#else
- // return -1;
- //#endif
- * @brief Read raw compass data.
- int mpu_get_compass_reg(short *data, unsigned long *timestamp)
- unsigned char tmp[9];
- if (!(st.chip_cfg.sensors & INV_XYZ_COMPASS))
- return -1;
- if (i2c_read(st.chip_cfg.compass_addr, AKM_REG_ST1, 8, tmp))
- return -1;
- tmp[8] = AKM_SINGLE_MEASUREMENT;
- if (i2c_write(st.chip_cfg.compass_addr, AKM_REG_CNTL, 1, tmp+8))
- return -1;
- #else
- if (i2c_read(st.hw->addr, st.reg->raw_compass, 8, tmp))
- return -1;
- #endif
- /* AK8975 doesn't have the overrun error bit. */
- return -2;
- if ((tmp[7] & AKM_OVERFLOW) || (tmp[7] & AKM_DATA_ERROR))
- return -3;
- /* AK8963 doesn't have the data read error bit. */
- if (!(tmp[0] & AKM_DATA_READY) || (tmp[0] & AKM_DATA_OVERRUN))
- return -2;
- if (tmp[7] & AKM_OVERFLOW)
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
全部資料51hei下載地址:
MPU6050.zip
(38.32 KB, 下載次數(shù): 142)
2018-8-12 16:02 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
