查看: 1352|回復(fù): 0
STM32 RTc模塊
ID:384719 發(fā)表于 2018-8-9 17:45 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
芯片內(nèi)集成了計(jì)數(shù)器+存儲(chǔ)器  外面接電源+晶振即可代碼表現(xiàn)為一個(gè)init+一個(gè)算法
#include "rtc.h"
void STEP1_RCC(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
void STEP2_NVIC(void)
  NVIC_InitTypeDef NVIC_InitStructure;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
        NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
void Set_alarm(uint32_t AlarmValue)
        if(RTC_GetITStatus(RTC_IT_ALR) != RESET)                                 //alarm interrupt
                RTC_ClearITPendingBit(RTC_IT_ALR);
        RTC_ITConfig(RTC_IT_ALR, ENABLE);
        RTC_WaitForLastTask();
        RTC_SetAlarm(AlarmValue);
void Disable_alarm(void)
  RTC_ITConfig(RTC_IT_ALR , DISABLE);
void RTC_Configuration(void)
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR,ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_BKP,ENABLE);
        //允許訪問(wèn)BKP區(qū)域
        PWR_BackupAccessCmd(ENABLE);
        //復(fù)位BKP
        BKP_DeInit();
        //使能外部低速晶振 32.768K
        RCC_LSEConfig(RCC_LSE_ON);
        //等待外部低速晶振就緒
        while(RCC_GetFlagStatus(RCC_FLAG_LSERDY)==RESET);
        //選擇RTC外部時(shí)鐘為低速晶振 32.768K
        RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
        //使能RTC時(shí)鐘
        RCC_RTCCLKCmd(ENABLE);
        //等待RTC寄存器同步
        RTC_WaitForSynchro();
        //等待寫RTC寄存器完成
        //使能RTC秒中斷
        RTC_ITConfig(RTC_IT_SEC,ENABLE);
        Set_alarm(2);
        //設(shè)置預(yù)分頻
        RTC_SetPrescaler(32767);
        //等待寫RTC寄存器完成
void Clock_Init(void)
        if(BKP_ReadBackupRegister(BKP_DR1)!=0xA5A5)
                 //第一次運(yùn)行  初始化設(shè)置
                //RTC初始化
                RTC_Configuration();
                //等待寫RTC寄存器完成
                //設(shè)置時(shí)間初值
                RTC_SetCounter(0xA442);
                //等待寫RTC寄存器完成
                //寫配置標(biāo)志
                BKP_WriteBackupRegister(BKP_DR1,0xA5A5);
                //等待RTC寄存器同步
                //等待寫RTC寄存器完成
                //使能RTC秒中斷
    //等待寫RTC寄存器完成
          Set_alarm(2);
        RCC_ClearFlag();//清除復(fù)位標(biāo)志;
void RTC_Init(void)
        STEP1_RCC();
        STEP2_NVIC();
        Clock_Init();
/***********************判斷是否為閏年********/
const uint8_t monthTable[12] = {31,28,31,30,31,30,31,31,30,31,30,31};
    函數(shù)功能:判斷是否閏年
    函數(shù)參數(shù):需要判斷的年份
    返回值:    返回1成功 其他失敗
static uint8_t isLeapYear(uint16_t mYear)
    if (((mYear%4 == 0)&&((mYear%100) != 0))||(mYear%400) == 0)
        return 1;
    }else
        return 0;
    函數(shù)功能:日期轉(zhuǎn)換為秒并配置RTC
    函數(shù)參數(shù):年、月、日、時(shí)、分、秒
    返回值:    返回0成功 其他失敗
uint8_t RTC_SetSec(_TM* DATA)
    uint32_t secCount = 0;
    uint16_t i;
          uint16_t year=DATA->year;
          uint8_t month=DATA->mon;
          uint8_t day=DATA->day;
          uint8_t hour=DATA->hour;
          uint8_t minute=DATA->min;
          uint8_t sec=DATA->sec;
    if (year <1970 || year >2099)
        return 1;
    for (i=1970; i<year; i++)
        if (isLeapYear(i))
            secCount += 31622400UL;
            secCount += 31536000UL;
    for (i=0; i<month-1; i++)
        secCount += ((uint32_t)monthTable[i]*86400UL);
        if (isLeapYear(year) && i==1)   //潤(rùn)年 多加一天
            secCount += 86400UL;
    secCount += (uint32_t)(day-1) * 86400UL;
    secCount += (uint32_t)(hour)*3600;
    secCount += (uint32_t)(minute)*60;
    secCount += (uint32_t)(sec);
    /*執(zhí)行以下操作可以使能對(duì)備份寄存器和 RTC 的訪問(wèn):
    1)通過(guò)設(shè)置寄存器 RCC_APB1ENR 的 PWREN 和 BKPEN 位來(lái)打開電源和后備接口的時(shí)鐘
    2)電源控制寄存器(PWR_CR)的 DBP 位來(lái)使能對(duì)后備寄存器和 RTC 的訪問(wèn)
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR|RCC_APB1Periph_BKP, ENABLE);
    RTC_SetCounter(secCount);
    return 0;
    函數(shù)功能:從RTC獲取秒轉(zhuǎn)換為年、月、日、星期、時(shí)、分、秒
                        存入 struct thisDate 中
    函數(shù)參數(shù):struct thisDate
    返回值:    返回0成功 其他失敗
uint8_t RTC_GetDate(_TM* thisDate)
    uint32_t timeCount = 0;
    uint32_t Count ;
    uint16_t tmp = 0;
    timeCount = RTC_GetCounter();
    Count = timeCount/86400UL;  //計(jì)算出天數(shù)
    thisDate->week = (4+Count)%7;
    if (Count !=0)                  //大于一天
        tmp = 1970;                     //從1970年開始
        while(Count>=365)
            if (isLeapYear(tmp))//是閏年
                if (Count>= 366)    //天數(shù)大于366
                    Count -= 366;
                }else
                    tmp++;                  //天數(shù)小于366 最后一年
                    break;
            }else
                Count -= 365;       //平年
                tmp++;
        thisDate->year = tmp;   //獲取到了年
        tmp = 0;
        while(Count>= 28)
            if (isLeapYear(thisDate->year) && tmp == 1)
                if (Count >= 29)
                    Count -= 29;
                    break;  //當(dāng)年是閏年 二月 某時(shí)
            }else
                if (Count >= monthTable[tmp])
                    Count -= monthTable[tmp];
                }else
                    break;
                tmp ++;
        thisDate->mon = tmp+1;    //獲取到月
        thisDate->day = Count+1;    //獲取到日
    Count = timeCount%86400UL;
    thisDate->hour = Count/3600;
    thisDate->min= (Count%3600)/60;
    thisDate->sec = (Count%3600)%60;
    return 0;
_RTC Rtc = {RTC_Init,RTC_GetDate,RTC_SetSec};
_TM  Today={12,27,13,1,8,8,2018};
#ifndef __RTC_H
#define __RTC_H
#include "time.h"//等待研究
#include "stm32f10x_bkp.h"
#include "stm32f10x_rcc.h"
#include "stm32f10x_rtc.h"
#include "stm32f10x_pwr.h"
#include "misc.h"
typedef struct
  u8 sec;
        u8 min;
        u8 hour;
        u8 week;
        u8 day;
        u8 mon;
        u16 year;
}_TM;
typedef struct
        void (*init)(void);
        u8 (*GetTime)(_TM *);
        u8 (*SetTime)(_TM *);
}_RTC;
extern _RTC Rtc;
extern _TM  Today;
#endif
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
