查看: 11778|回復: 10
RC522的讀寫卡程序,可以讀寫1~16扇區的任意數據塊
ID:173447 發表于 2018-8-8 15:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//讀寫扇區的例子:
#include <SPI.h>
#include <RFID.h>
RFID rfid(53,49);    //D10--讀卡器MOSI引腳、D5--讀卡器RST引腳
//4字節卡序列號,第5字節為校驗字節
unsigned char serNum[5];
//寫卡數據,3為數據塊012,16為長度
unsigned char writeDate[3][16] ={
{'1', '2', '3', '4', '-', '5', '6', '7', '8', '9', 'a', 'b', 'c','d', 'e', 0},
{'1', '1', '3', '4', '-', '5', '6', '7', '8', '9', 'a', 'b', 'c','d', 'e', 0},
{'1', '1', '1', '4', '-', '5', '6', '7', '8', '9', 'a', 'b', 'c','d', 'e', 0},
//原扇區A密碼,16個扇區,每個扇區密碼6Byte
unsigned char sectorKeyA[16][16] = {
  {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF},//0~16扇區原密碼
//新扇區A密碼,16個扇區,每個扇區密碼6Byte,一行代表一個扇區
//改密碼只要改前面6個ff任意一個, 0xff,0x07,0x80,0x69, 千萬不能動否則可能報廢扇區
unsigned char sectorNewKeyA[16][16] = {
        {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xff,0x07,0x80,0x69, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF},//1-16扇區新密碼
//char aa[16];
void setup()
  Serial.begin(9600);
  SPI.begin();
  rfid.init();
void loop()
  //unsigned char i,tmp;//i為數據塊號0.1.2
  unsigned tmp;
  unsigned char status;
  unsigned char str[MAX_LEN];
// unsigned char RC_size;
  unsigned char blockAddr;        //選擇操作的塊地址0~63。但只能寫4的倍數+3;比如7,11,15,19---
  //找卡
  rfid.isCard();
  //讀取卡序列號
  if (rfid.readCardSerial())
    Serial.print("The card's number is  : ");
    Serial.print(rfid.serNum[0],HEX);
    Serial.print(rfid.serNum[1],HEX);
    Serial.print(rfid.serNum[2],HEX);
    Serial.print(rfid.serNum[3],HEX);
    Serial.print(rfid.serNum[4],HEX);
    Serial.println(" ");
  //選卡,返回卡容量(鎖定卡片,防止多次讀寫)
rfid.selectTag(rfid.serNum);
  //寫數據卡
//  for(int i=0;i<3;i++)//循環寫入數據塊012,不循環就單獨寫i值
//  blockAddr = 15;                //扇區3,控制塊3
//  if (rfid.auth(PICC_AUTHENT1A, blockAddr, sectorKeyA[ blockAddr/4], rfid.serNum) == MI_OK)  //認證
////    寫密碼
//    status = rfid.write(blockAddr, sectorNewKeyA[blockAddr/4]);
//    //寫數據
//    blockAddr = blockAddr - 3+i; //數據塊i
//    tmp=(blockAddr+3-i)/4;
//    status = rfid.write(blockAddr, writeDate[i]);
//    if(status == MI_OK)
//      Serial.print("扇區:");
//      Serial.print(tmp,DEC);
//      Serial.print("數據塊:");
//      Serial.println(i);
//      Serial.println("Write card OK!");
  //讀卡
  for(int i=2;i<3;i++)
  blockAddr = 15;                ////扇區3,控制塊3
  status = rfid.auth(PICC_AUTHENT1A, blockAddr, sectorNewKeyA[blockAddr/4], rfid.serNum);
  if (status == MI_OK)  //認證
    //讀數據
    if( rfid.read(blockAddr, str) == MI_OK)
      Serial.print("Read from the card ,the data is : ");
      Serial.println((char *)str);
    Serial.print(blockAddr/4,DEC);
    Serial.println(i);
  rfid.halt();//去掉本行連續讀寫
//驗證密碼+數據后,再對arduino設定的sj進行減5操作
#include <SPI.h>
#include <RFID.h>
//4字節卡序列號,第5字節為校驗字節
//寫卡數據
unsigned char writeDate[16]={'1', '2', '3', '4', '-', '5', '6', '7', '8', '9', 'a', 'b', 'c','d', 0, 0};
unsigned char aa[16]=        {'1', '2', '3', '4', '-', '5', '6', '7', '8', '9', 'a', 'b', 'c','d', 0, 0};
char dy;
unsigned int sj=1000;
// {0x11, 0x11, 0x11, 0x11, 0x11, 0x11},
//改密碼只要改第3行前面6個ff任意一個, 0xff,0x07,0x80,0x69, 千萬不能動負責報廢扇區
        {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xff,0x07,0x80,0x69, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF},//讀改密碼只要改前面6個ff任意一個
        {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xff,0x07,0x80,0x69, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF},//寫改密碼只要改前面6個ff任意一個
void setup()
  Serial.begin(9600);
  SPI.begin();
  rfid.init();
void loop()
  //找卡
  rfid.isCard();
  //讀取卡序列號
  //寫數據卡
  blockAddr = 7;                //數據塊7//報廢扇區2,1,16
//    寫數據
    Serial.print("set the new card password, and can modify the data of the Sector: ");
    Serial.println(blockAddr/4,DEC);
    //寫數據
    blockAddr = blockAddr - 3 ; //數據塊4
    status = rfid.write(blockAddr, writeDate);
    if(status == MI_OK)
  //讀卡
  blockAddr = 7;
    //讀數據
for(int a=0;a<15;a++)
  dy=1;
  if(aa[a]!=str[a])
dy=0;
break;
if(dy==1)
  sj-=5;
  Serial.println(sj);
  rfid.halt();
RFID.zip
9.02 KB, 下載次數: 146, 下載積分: 黑幣 -5
收藏收藏10 分享淘帖 頂 踩
ID:157346 發表于 2018-9-5 16:28 | 只看該作者
怎么那個庫函數一直添加不了
ID:257260 發表于 2019-12-13 15:37 | 只看該作者
好資料
ID:893675 發表于 2021-4-5 22:28 | 只看該作者
是stc89c52能用的嗎
ID:838368 發表于 2021-4-26 21:37 | 只看該作者
兄弟,我也想知道這是用什么板子控制的,你知道了能否也告訴一下我啊,非常感謝!
ID:3802 發表于 2021-6-17 15:48 | 只看該作者
是stc89c52能用的嗎
ID:964308 發表于 2021-9-11 09:54 來自觸屏版 | 只看該作者
水煮涼白開 發表于 2021-4-5 22:28
是stc89c52能用的嗎
不可以,語言不一樣
ID:966423 發表于 2021-9-16 09:33 | 只看該作者
RC522初始化語句太多了,有沒有辦法減小點,減少休眠喚醒時間
ID:235200 發表于 2021-9-16 11:30 | 只看該作者
單片機不能直接用,加一個使用環境說明就好了
ID:964308 發表于 2021-10-27 08:32 來自觸屏版 | 只看該作者
是stc89c52能用的嗎
不能直接用,雖然和c51很像,但很多地方都不一樣,比如入口函數,定時器,函數名
ID:964308 發表于 2021-12-13 00:29 | 只看該作者
白色暴躁 發表于 2021-4-26 21:37
arduino的都能控制,我用的是Arduino Nano v3,自己寫了個讀卡號和計算水卡密碼的,現在差了個把數據寫進去 。不過我看他們都是用UNO
