查看: 1338|回復: 0
行列式鍵盤
ID:382761 發表于 2018-8-4 09:23 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
#define KeyPort P1
#define DataPort P0
//#define function 1  //0行列逐級掃描,1翻轉掃描
sbit Seg_Latch = P2^2;   //段鎖存
sbit Bit_Latch = P2^3;   //位鎖存
unsigned char KeyPro(void);
unsigned char KeyScan(void);
void DelayMs(unsigned int n);
void DelayUs2x(unsigned int n);
void display(unsigned char firstbit, unsigned char num);
unsigned char TempData[10];
unsigned char code Seg_Code[]=
0x3f,0x06,0x5b,0x4f, //0~3
0x66,0x6d,0x7d,0x07, //4~7
0x7f,0x6f,0x77,0x7c, //8~b
0x39,0x5e,0x79,0x71, //c~f
0x40 //c~f
unsigned char code Bit_Code[] =
  0xfe,0xfd,0xfb,0xf7,
  0xef,0xdf,0xbf,0x7f
                    定時器初始化子程序
void Init_Timer0(void)
TMOD |= 0x01;   //使用模式1,16位定時器,使用"|"符號可以在使用多個定時器時不受影響
// TH0=(65536-2000)/256;       //給定初值
// TL0=(65536-2000)%256;
EA=1;            //總中斷打開
ET0=1;           //定時器中斷打開
TR0=1;           //定時器開關打開
                 定時器中斷子程序
void Timer0_isr(void) interrupt 1
TH0=(65536-2000)/256;    //重新賦值 2ms
display(0,8);       // 調用數碼管掃描
unsigned char num,i,j;
unsigned char temp[8];
Init_Timer0();
  num = KeyPro();
  if(num != 0xff)
    if(i<8)
     temp[i] = Seg_Code[num];
     for(j=0;j<=i;j++)
       TempData[7-i+j]=temp[j];
      i++;
      if(i == 9)
       i = 0;
       for(j=0;j<8;j++)//清屏
       TempData[j]=0;
        按鍵掃描函數,返回掃描鍵值
//#if function
unsigned char KeyScan(void)//行列逐級掃描
unsigned char KeyVal;
KeyPort = 0xf0;
if(KeyPort != 0xf0)//如果有鍵盤按下,則高四位有鍵按下
  DelayMs(10);//去抖
  if(KeyPort != 0xf0)//鍵還在
   KeyPort = 0xfe;//檢測第一行
   if(KeyPort != 0xfe)
     KeyVal = KeyPort & 0xf0;
     KeyVal += 0x0e;
     DelayMs(10);
    while(KeyPort != 0xfe);
    return KeyVal;
   KeyPort = 0xfd;//檢測第二行
   if(KeyPort != 0xfd)
     KeyVal += 0x0d;
     DelayMs(10);
    while(KeyPort != 0xfd);
    return KeyVal;
   KeyPort = 0xfb;//檢測第三行
   if(KeyPort != 0xfb)
     KeyVal += 0x0b;
     DelayMs(10);
    while(KeyPort != 0xfb);
    return KeyVal;
   KeyPort = 0xf7;//檢測第四行
   if(KeyPort != 0xf7)
     KeyVal += 0x07;
     DelayMs(10);
    while(KeyPort != 0xf7);
    return KeyVal;
return 0xff;
//#elif !function
/*unsigned char KeyScan(void)//行列翻轉掃描
unsigned char key_row,key_column;//行列的中間變量
KeyPort = 0x0f;//列為0
key_row = KeyPort & 0x0f;//讀行值
if(key_row != 0x0f)//檢測是否有按鍵按下
  DelayMs(10);
  if((KeyPort & 0x0f) != 0x0f)//鍵還在按下
   KeyPort = key_row | 0xf0;//翻轉掃描
   key_column = KeyPort & 0xf0;//讀列值
   while((KeyPort & 0xf0) != 0xf0);//等待按鍵釋放
   return (key_row+key_column);//返回鍵值,第四位行,高四位列
return 0xff;
#endif
         按鍵值處理函數,返回掃鍵值
switch(KeyScan())
  case 0x7e:return 0;break;//0 按下相應的鍵顯示相對應的碼值
  case 0xbe:return 1;break;//1
  case 0xde:return 2;break;//2
  case 0xee:return 3;break;//3
  case 0x7d:return 4;break;//4
  case 0xbd:return 5;break;//5
  case 0xdd:return 6;break;//6
  case 0xed:return 7;break;//7
  case 0x7b:return 8;break;//8
  case 0xbb:return 9;break;//9
  case 0xdb:return 10;break;//a
  case 0xeb:return 11;break;//b
  case 0x77:return 12;break;//c
  case 0xb7:return 13;break;//d
  case 0xd7:return 14;break;//e
  case 0xe7:return 15;break;//f
  default:return 0xff;break;
  static unsigned char i;
   DataPort = 0;           //清除數據
    Seg_Latch = 1;          //開門
    Seg_Latch = 0;          //關門
    DataPort = Bit_Code[firstbit + i]; //送位碼
    Bit_Latch = 1;          //開門
    Bit_Latch = 0;          //關門
    DataPort = TempData[i] ; //送段碼
    Seg_Latch = 1;          //開門
    Seg_Latch = 0;      //關門
    i++;
   if(i==num)
       i=0;
  while(--n);
  while(n--)
    DelayUs2x(245);
    DelayUs2x(245);
