查看: 4248|回復: 4
一個簡單的基于C51,oled的菜單,三個鍵控制
ID:343709 發表于 2018-8-2 17:30 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#ifndef __LQ12864_h
#define __LQ12864_h
#include "reg52.h"
#include "intrins.h"
#include "codetab.h"
sbit SCL=P1^0; //串行時鐘
sbit SDA=P1^1;//串行數據
sbit RES=P1^2;
sbit DC=P1^3;//串行數據
sbit keyup=P2^0;
sbit keyenter=P2^2;
sbit keydown=P2^1;
#define high 1
#define low 0
#define X_WIDTH         128
#define Y_WIDTH         64
void delay(uint z)  //1ms
        unsigned int x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
// 通過SPI總線寫一個字節
void Write_SPI_Data(uchar ucData)
    uchar i = 8;
    DC   = 1;
    SCL  = 0;
    while (i--)
        if (ucData & 0x80)
            SDA = 1;
            SDA = 0;
        SCL = 1;
        _nop_();
        SCL = 0;
        ucData <<= 1;
void Write_SPI_Command(uchar ucCmd)
    unsigned char i = 8;
    DC   = 0;
    SCL  = 0;
    while (i--)
        if (ucCmd & 0x80)
            SDA = 1;
            SDA = 0;
        SCL = 1;
        _nop_();
        SCL = 0;
        ucCmd <<= 1;
/*********************OLED 設置坐標************************************/
void OLED_Set_Pos(uchar x, uchar y)
        Write_SPI_Command(0xb0+y); //設置頁地址
        Write_SPI_Command(((x&0xf0)>>4)|0x10);//設置行高四位地址
        Write_SPI_Command((x&0x0f)|0x01);//設置行低四位地址,最低位為1
/*********************OLED復位************************************/
void OLED_CLS(void)
        unsigned char y,x;
        for(y=0;y<8;y++)
                Write_SPI_Command(0x01);
                Write_SPI_Command(0x10);
                for(x=0;x<X_WIDTH;x++)
                Write_SPI_Data(0);
/*********************OLED初始化************************************/
void OLED_Init(void)
        delay(500);
        Write_SPI_Command(0xAE);   //display off
        Write_SPI_Command(0x20);        //Set Memory Addressing Mode
        Write_SPI_Command(0x10);        //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
        Write_SPI_Command(0xb0);        //Set Page Start Address for Page Addressing Mode,0-7
        Write_SPI_Command(0xc8);        //Set COM Output Scan Direction
        Write_SPI_Command(0x00);//---set low column address
        Write_SPI_Command(0x10);//---set high column address
        Write_SPI_Command(0x40);//--set start line address
        Write_SPI_Command(0x81);//--set contrast control register
        Write_SPI_Command(0x7f);
        Write_SPI_Command(0xa1);//--set segment re-map 0 to 127
        Write_SPI_Command(0xa6);//--set normal display
        Write_SPI_Command(0xa8);//--set multiplex ratio(1 to 64)
        Write_SPI_Command(0x3F);//
        Write_SPI_Command(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
        Write_SPI_Command(0xd3);//-set display offset
        Write_SPI_Command(0x00);//-not offset
        Write_SPI_Command(0xd5);//--set display clock divide ratio/oscillator frequency
        Write_SPI_Command(0xf0);//--set divide ratio
        Write_SPI_Command(0xd9);//--set pre-charge period
        Write_SPI_Command(0x22); //
        Write_SPI_Command(0xda);//--set com pins hardware configuration
        Write_SPI_Command(0x12);
        Write_SPI_Command(0xdb);//--set vcomh
        Write_SPI_Command(0x20);//0x20,0.77xVcc
        Write_SPI_Command(0x8d);//--set DC-DC enable
        Write_SPI_Command(0x14);//
        Write_SPI_Command(0xaf);//--turn on oled panel
        OLED_CLS();
        OLED_Set_Pos(0,0);
/*****************功能描述:顯示16*16點陣  顯示的坐標(x,y),y為頁范圍0~7****************************/
void OLED_P16x16Ch(uchar x, y, N)
        unsigned char wm=0;
        unsigned int adder=32*N;
        OLED_Set_Pos(x , y);
        for(wm = 0;wm < 16;wm++)
                Write_SPI_Data(F16x16[adder]);
                adder += 1;
        OLED_Set_Pos(x,y + 1);
                adder += 1;
#endif
#ifndef __codetab_h
#define __LED_H
/***************************16*16的點陣字體取模方式:共陰——列行式——逆向輸出*********/
unsigned char code F16x16[] =
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
0x20,0x20,0x10,0x10,0x28,0x24,0x22,0x29,0xB2,0x64,0x28,0x10,0x10,0x20,0x20,0x00,
0x00,0x80,0x80,0x9F,0x41,0x41,0x21,0x1D,0x01,0x21,0x21,0x5F,0x40,0x80,0x00,0x00,//貪,1
0x00,0xFC,0x04,0x04,0xFC,0x20,0x10,0x4C,0x4B,0x48,0x48,0x48,0xC8,0x08,0x08,0x00,
0x00,0x0F,0x04,0x04,0x0F,0x00,0x30,0x48,0x44,0x42,0x42,0x41,0x40,0x40,0x70,0x00,//吃,2
0x00,0xF8,0x08,0xFF,0x08,0xF8,0x20,0x18,0xC8,0x08,0x09,0x0E,0x88,0x28,0x18,0x00,
0x20,0x63,0x21,0x1F,0x11,0x19,0x30,0x00,0x3F,0x44,0x42,0x41,0x40,0x40,0x78,0x00,//蛇,3
0x10,0x60,0x02,0x8C,0x00,0x08,0xF9,0x4E,0xC8,0x20,0x58,0x4F,0x48,0xC8,0x08,0x00,
0x04,0x04,0x7E,0x81,0x40,0x30,0x0F,0x40,0x7F,0x00,0x44,0x84,0x7F,0x04,0x04,0x00,//游,4
0x00,0x08,0x48,0x88,0x08,0xC8,0x38,0x40,0x40,0x40,0xFF,0x20,0x22,0xAC,0x20,0x00,
0x00,0x20,0x10,0x0C,0x03,0x04,0x18,0x80,0x40,0x20,0x17,0x18,0x26,0x41,0xF0,0x00,//戲,5
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//" ",6
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//" ",7
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//8
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//一,9
0x80,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0x80,0x00,
0x00,0x80,0x40,0x30,0x0F,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,//開10
0x10,0x10,0xF0,0x1F,0x10,0xF0,0x00,0x40,0xE0,0x58,0x47,0x40,0x50,0x60,0xC0,0x00,
0x40,0x22,0x15,0x08,0x16,0x21,0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,//始11
0x04,0x04,0x7E,0x81,0x40,0x30,0x0F,0x40,0x7F,0x00,0x44,0x84,0x7F,0x04,0x04,0x00,//游12
0x00,0x20,0x10,0x0C,0x03,0x04,0x18,0x80,0x40,0x20,0x17,0x18,0x26,0x41,0xF0,0x00,//戲13
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//   14
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x30,0x0C,0x03,0x00,
0x00,0x00,0x00,0x10,0x08,0x04,0x18,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x00,//√0 15
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//16
0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,0x00,
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x00,//二,17
0x20,0x30,0xAC,0x63,0x20,0x18,0x08,0x48,0x48,0x48,0x7F,0x48,0x48,0x48,0x08,0x00,
0x22,0x67,0x22,0x12,0x12,0x12,0x00,0xFE,0x42,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,//結 18
0x04,0x04,0xE4,0x24,0x24,0x24,0x24,0xFF,0x24,0x24,0x24,0x24,0xE4,0x04,0x04,0x00,
0x40,0x40,0x27,0x22,0x12,0x0A,0x06,0xFF,0x06,0x0A,0x12,0x22,0x27,0x40,0x40,0x00,//束 19
0x04,0x04,0x7E,0x81,0x40,0x30,0x0F,0x40,0x7F,0x00,0x44,0x84,0x7F,0x04,0x04,0x00,//游 20
0x00,0x20,0x10,0x0C,0x03,0x04,0x18,0x80,0x40,0x20,0x17,0x18,0x26,0x41,0xF0,0x00,//戲  21
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//    22
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//    23
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 24
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 25
0x40,0x40,0x42,0xCC,0x00,0x00,0xFC,0x24,0xA4,0x24,0x22,0x22,0xA3,0x62,0x00,0x00,
0x00,0x40,0x20,0x1F,0x20,0x58,0x47,0x50,0x48,0x45,0x42,0x45,0x48,0x50,0x40,0x00,//返26
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//  27
0x00,0x00,0xFE,0x02,0x02,0xF2,0x12,0x12,0x12,0xF2,0x02,0x02,0xFE,0x00,0x00,0x00,
0x00,0x00,0x7F,0x20,0x20,0x27,0x24,0x24,0x24,0x27,0x20,0x20,0x7F,0x00,0x00,0x00,//回28
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 29
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 30
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 31
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//32
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x00,//二,33
0x22,0x67,0x22,0x12,0x12,0x12,0x00,0xFE,0x42,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,//結 34
0x40,0x40,0x27,0x22,0x12,0x0A,0x06,0xFF,0x06,0x0A,0x12,0x22,0x27,0x40,0x40,0x00,//束 35
0x04,0x04,0x7E,0x81,0x40,0x30,0x0F,0x40,0x7F,0x00,0x44,0x84,0x7F,0x04,0x04,0x00,//游 36
0x00,0x20,0x10,0x0C,0x03,0x04,0x18,0x80,0x40,0x20,0x17,0x18,0x26,0x41,0xF0,0x00,//戲  37
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//    38
0x00,0x00,0x00,0x10,0x08,0x04,0x18,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x00,//√0 39
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 40
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 41
0x00,0x40,0x20,0x1F,0x20,0x58,0x47,0x50,0x48,0x45,0x42,0x45,0x48,0x50,0x40,0x00,//返42
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//  43
0x00,0x00,0x7F,0x20,0x20,0x27,0x24,0x24,0x24,0x27,0x20,0x20,0x7F,0x00,0x00,0x00,//回44
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 45
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 46
0x00,0x00,0x00,0x10,0x08,0x04,0x18,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x00,//√0 47
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//48
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//一,49
0x00,0x80,0x40,0x30,0x0F,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,//開,50
0x40,0x22,0x15,0x08,0x16,0x21,0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,//始,51
0x04,0x04,0x7E,0x81,0x40,0x30,0x0F,0x40,0x7F,0x00,0x44,0x84,0x7F,0x04,0x04,0x00,//游,52
0x00,0x20,0x10,0x0C,0x03,0x04,0x18,0x80,0x40,0x20,0x17,0x18,0x26,0x41,0xF0,0x00,//戲.53
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//  54
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //  55
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//   56
0x08,0x04,0x93,0x92,0x96,0x9A,0x92,0xFA,0x94,0x93,0x92,0x96,0xFA,0x02,0x02,0x00,
0x40,0x40,0x47,0x24,0x24,0x14,0x0C,0xFF,0x04,0x04,0x24,0x44,0x24,0x1C,0x00,0x00,//第257
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//    58
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//一3  59
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//    60
0x00,0x00,0x10,0x11,0x16,0x10,0x10,0xF0,0x10,0x10,0x14,0x13,0x10,0x00,0x00,0x00,
0x81,0x81,0x41,0x41,0x21,0x11,0x0D,0x03,0x0D,0x11,0x21,0x41,0x41,0x81,0x81,0x00,//關4  61
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//     62
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //    63
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//  64
0x40,0x40,0x47,0x24,0x24,0x14,0x0C,0xFF,0x04,0x04,0x24,0x44,0x24,0x1C,0x00,0x00,//第2  65
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//    66
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x00,//二   67
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//     68
0x81,0x81,0x41,0x41,0x21,0x11,0x0D,0x03,0x0D,0x11,0x21,0x41,0x41,0x81,0x81,0x00,//關     69
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//       70
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //    71
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 72
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 73
0x00,0x40,0x20,0x1F,0x20,0x58,0x47,0x50,0x48,0x45,0x42,0x45,0x48,0x50,0x40,0x00,//返74
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//  75
0x00,0x00,0x7F,0x20,0x20,0x27,0x24,0x24,0x24,0x27,0x20,0x20,0x7F,0x00,0x00,0x00,//回76
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 77
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 78
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//  79
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//   80
0x40,0x40,0x47,0x24,0x24,0x14,0x0C,0xFF,0x04,0x04,0x24,0x44,0x24,0x1C,0x00,0x00,//第2 81
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//    82
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//一3  83
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//    84
0x81,0x81,0x41,0x41,0x21,0x11,0x0D,0x03,0x0D,0x11,0x21,0x41,0x41,0x81,0x81,0x00,//關4  85
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//     86
0x00,0x00,0x00,0x10,0x08,0x04,0x18,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x00,//√0    87
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//  88
0x40,0x40,0x47,0x24,0x24,0x14,0x0C,0xFF,0x04,0x04,0x24,0x44,0x24,0x1C,0x00,0x00,//第2  89
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//    90
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x00,//二   91
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// ,//     92
0x81,0x81,0x41,0x41,0x21,0x11,0x0D,0x03,0x0D,0x11,0x21,0x41,0x41,0x81,0x81,0x00,//關     93
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//       94
0x00,0x00,0x00,0x10,0x08,0x04,0x18,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x00,//√0    95
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 96
0x40,0x40,0x42,0xCC,0x00,0x50,0x4E,0xC8,0x48,0x7F,0xC8,0x48,0x48,0x40,0x00,0x00,
0x00,0x40,0x20,0x1F,0x20,0x50,0x4C,0x43,0x40,0x40,0x4F,0x50,0x50,0x5C,0x40,0x00,//選97
0x10,0x10,0xFF,0x10,0x00,0x82,0x86,0x4A,0x52,0xA2,0x52,0x4A,0x86,0x80,0x80,0x00,
0x42,0x82,0x7F,0x01,0x00,0x10,0x12,0x12,0x12,0xFF,0x12,0x12,0x12,0x10,0x00,0x00,//擇98
0x81,0x81,0x41,0x41,0x21,0x11,0x0D,0x03,0x0D,0x11,0x21,0x41,0x41,0x81,0x81,0x00,//關99
0x40,0x40,0x40,0x40,0x40,0x40,0xFF,0x44,0x44,0x44,0x44,0x44,0x44,0x40,0x40,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x02,0x04,0x08,0x10,0x00,0x00,0x00,//卡100
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 101
0x00,0x08,0x78,0xE8,0x00,0x00,0x00,0xD8,0xF8,0xC0,0x00,0x00,0xC0,0x38,0x08,0x00,
0x00,0x00,0x00,0x03,0x3F,0x18,0x07,0x00,0x00,0x0F,0x3E,0x0E,0x01,0x00,0x00,0x00,//W  102
0x00,0x00,0x08,0xF8,0xF8,0x08,0x08,0x08,0x08,0x08,0x88,0xC8,0x08,0x18,0x00,0x00,
0x00,0x20,0x20,0x3F,0x3F,0x21,0x21,0x21,0x21,0x21,0x21,0x23,0x20,0x30,0x08,0x00,//E   103
0x00,0x00,0x08,0xF8,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x20,0x20,0x3F,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x30,0x08,0x00,//L   104
0x00,0xC0,0xE0,0x70,0x10,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x18,0x20,0x00,
0x00,0x07,0x0F,0x1C,0x10,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x10,0x10,0x08,0x00,//C   105
0x00,0xC0,0xE0,0xF0,0x10,0x08,0x08,0x08,0x08,0x08,0x08,0x18,0x30,0xE0,0xC0,0x00,
0x00,0x03,0x0F,0x1F,0x10,0x20,0x20,0x20,0x20,0x20,0x20,0x10,0x18,0x0F,0x07,0x00,//O   106
0x00,0x08,0xF8,0x38,0xE0,0x80,0x00,0x00,0x00,0x00,0xE0,0x18,0xF8,0xF8,0x08,0x00,
0x20,0x20,0x3F,0x20,0x01,0x07,0x1E,0x38,0x0C,0x03,0x20,0x20,0x3F,0x3F,0x20,0x20,//M  107
0x00,0x20,0x20,0x3F,0x3F,0x21,0x21,0x21,0x21,0x21,0x21,0x23,0x20,0x30,0x08,0x00,//E 108
#endif
#include "reg52.h"
sbit RES=P1^2;
sbit DC=P1^3;//串行數據
sbit keyup=P3^0;
sbit keyenter=P3^2;
sbit keydown=P3^1;
uchar func_index=0;
void (*current_operation_index)();
void func1();
void func2();
void func3();
void func4();
void func5();
void func6();
void func7();
void func8();
void delay_1ms(uint z)  //1ms
        unsigned int x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
typedef struct
        uchar current;
        uchar up;//向上翻索引號
  uchar down;//向下翻索引號
  uchar enter;//確認索引號
  void (*current_operation)();
} key_table;
key_table code table[]=
        {0,2,1,3,(*func1)},//第一層,開始
        {1,0,2,7,(*func2)},//第一層,結束
  {2,1,3,6,(*func3)},//第一層, 返回
  {3,5,4,3,(*func4)},//第二層,第一關
  {4,3,5,4,(*func5)},//第二層, 第二關
  {5,4,3,0,(*func6)},//第二層, 返回
  {6,0,0,0,(*func7)}, //第0層,welcome
        {7,0,0,0,(*func8)}, //        清屏
        RES=0;
        delay_1ms(10);
        RES=1;
        delay_1ms(10);
        DC=0;
        OLED_Init();
        delay_1ms(5);
                if((keyup==0)||(keydown==0)||(keyenter==0))
      delay_1ms(1);//消抖
      if(keyup==0)
                                delay_1ms(1);
                                if(keyup==0)
                                        func_index=table[func_index].up;    //向上翻
                                        while(!keyup);//松手檢測
      if(keydown==0)
                                delay_1ms(1);
                                if(keydown==0)
                                        func_index=table[func_index].down;    //向下翻
                                        while(!keydown);
                        if(keyenter==0)
                                delay_1ms(1);
                                if(keyenter==0)
                                        func_index=table[func_index].enter;    //確認
                                        while(!keyenter);
                        OLED_Init();
      current_operation_index=table[func_index].current_operation;
     (*current_operation_index)();//執行當前操作函數
#include "LQ12864.h"
void func1()
                unsigned char i;
                OLED_P16x16Ch(24,0,1);  //貪吃蛇游戲
                OLED_P16x16Ch(40,0,2);
                OLED_P16x16Ch(57,0,3);
                OLED_P16x16Ch(74,0,4);
                OLED_P16x16Ch(91,0,5);
                for(i=0; i<8; i++)//通過點整顯示漢字 -- i表示字表數組的位置
                        OLED_P16x16Ch(i*16,2,i+8);  //開始
                        OLED_P16x16Ch(i*16,4,i+16);  //結束
                        OLED_P16x16Ch(i*16,6,i+24);   //返回
void func2()
                unsigned char i;
                OLED_P16x16Ch(24,0,1);  //貪吃蛇射游戲
                        OLED_P16x16Ch(i*16,2,i+48);  //開始
                        OLED_P16x16Ch(i*16,4,i+32);  //結束
void func3()
                unsigned char i;
                        OLED_P16x16Ch(i*16,6,i+40);   //返回
void func4()
                unsigned char i;
                OLED_P16x16Ch(16,0,97);  //選擇關卡
                OLED_P16x16Ch(32,0,98);
                OLED_P16x16Ch(48,0,99);
                OLED_P16x16Ch(64,0,100);
                        OLED_P16x16Ch(i*16,2,i+80);  //第一關√
                        OLED_P16x16Ch(i*16,4,i+64);  //
void func5()
                unsigned char i;
                        OLED_P16x16Ch(i*16,2,i+56);  //第二關√
                        OLED_P16x16Ch(i*16,4,i+88);  //
void func6()
                unsigned char i;
                        OLED_P16x16Ch(i*16,2,i+56);  //返回√
void func7()
                OLED_P16x16Ch(16,0,102);  //WELCOME
                OLED_P16x16Ch(32,0,103);
                OLED_P16x16Ch(48,0,104);
                OLED_P16x16Ch(64,0,105);
                OLED_P16x16Ch(80,0,106);
                OLED_P16x16Ch(96,0,107);
                OLED_P16x16Ch(112,0,108);
void func8()
        delay(400);
        OLED_CLS();
SPI.zip
72.1 KB, 下載次數: 65, 下載積分: 黑幣 -5
keil程序
收藏收藏3 分享淘帖 頂 踩
ID:64765 發表于 2020-8-11 16:16 | 只看該作者
正在學習單片機,雪中送炭。謝謝分享。
ID:795562 發表于 2020-8-20 11:58 | 只看該作者
請教,這個顯示屏是哪種的?0.96寸的4針數據線還是7針數據線接口的那種呢?
ID:246744 發表于 2022-3-15 10:29 | 只看該作者
感謝分享,共同進步
