只需一步,快速開(kāi)始
查看: 4147|回復(fù): 1
Keil stm32的12864液晶顯示程序
ID:249298 發(fā)表于 2018-7-25 14:30 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
分享一個(gè)基于Keil STM32的12864液晶模塊顯示程序。
單片機(jī)源程序如下:
  1. #include "stm32f10x.h"
  2. #include "integer.h"
  3. #include "lcd12864_chuan.H"
  4. //12864 STM32驅(qū)動(dòng)程序
  5. void delay(u32 delaytime);
  6. void NVIC_Configuration(void);
  7. void RCC_Configuration(void);
  8. void GPIO_init(void);
  9. void delay(u32 delaytime){
  10.         while(delaytime>1)delaytime--;
  11. }
  12. void NVIC_Configuration(void){
  13.         #ifdef  VECT_TAB_RAM
  14.           /* Set the Vector Table base location at 0x20000000 */
  15.           NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
  16.         #else  /* VECT_TAB_FLASH  */
  17.           /* Set the Vector Table base location at 0x08000000 */
  18.           NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
  19.         #endif
  20.           /* Configure one bit for preemption priority */
  21. }
  22. //配置系統(tǒng)時(shí)鐘,使能各外設(shè)時(shí)鐘
  23. void RCC_Configuration(void){
  24.         SystemInit();
  25.         RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA
  26.                            |RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
  27.                            |RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE
  28.                                                    | RCC_APB2Periph_AFIO |RCC_APB2Periph_SPI1
  29.                             , ENABLE );
  30. }
  31. void GPIO_init(void){
  32.         GPIO_InitTypeDef GPIO_InitStructure;
  33.         /* Configure PC13 as input floating (EXTI Line0) */
  34. //        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12;
  35. //        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  36. //        GPIO_Init(GPIOA, &GPIO_InitStructure);
  37. //        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
  38. //        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  39. //        GPIO_Init(GPIOB, &GPIO_InitStructure);
  40.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3;
  41.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  42.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  43.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  44.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2;  //12864控制腳 OD輸出
  45.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  46.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  47.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  48. }
  49. void Init_All_Periph(void){
  50.         RCC_Configuration();
  51.         NVIC_Configuration();
  52.         GPIO_init();
  53. //        SPI_Configuration();
  54. //    SD_Init();
  55.         lcd_init();
  56. }
  57. int main(void){
  58.                 Init_All_Periph();
  59.         while(1)
  60.         {
  61. Chshow(2,2,"xxxxxx aa");
  62. delay(10000000);
  63. Chshow(2,2,"feasfas");
  64. delay(10000000);
  65. //Draw_circle(64,32,30)
  66. //            f_mount(0,&fs);  //開(kāi)辟一個(gè)新的工作區(qū)
  67. //                window();
  68. //                f_mount(0,NULL);  //注銷工作區(qū)
  69.         }
  70. }
STM32_12864_原創(chuàng)顯示程序.rar (327.87 KB, 下載次數(shù): 58)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
ID:416242 發(fā)表于 2018-10-27 12:30 | 只看該作者
沒(méi)黑幣下載
無(wú)效樓層,該帖已經(jīng)被刪除
