#include "reg52.h"
#include "main.h"
#include "distance_measure.h"
#define TIMER_DELAY (500) //定時器定時500us=0.5ms
uint counter = 0; //計數
uchar PWM[4]={8,8,8,8};
uchar motor_max=5; //pwm最大值
//四路馬達
// 1 3
// 2 4
sbit ENA = P1^5;
sbit motor1 = P1^4;
sbit motor2 = P1^3;
sbit motor3 = P1^2;
sbit motor4 = P1^1;
sbit ENB = P1^0;
//STC89系列單片機延時1ms
void delay_ms(unsigned int x)
char j=0;
while(x--)
for(j=0;j<125;j++)
//定時器初始化
void timer_init()
//AUXR &= 0x7F; //定時器時鐘12T模式
TMOD &= 0xF0; //設置定時器模式:定時器0方式1
TMOD |= 0x01; //設置定時器模式:定時器0方式1
EA=1; //開總中斷
TH0=(65535-TIMER_DELAY)/256; //設置初值
TL0=(65535-TIMER_DELAY)%256;
ET0=1; //啟用定時器中斷
TR0=1; //開啟
//T0中斷服務子程序
void timer0_isr() interrupt 1
TH0=(65535-TIMER_DELAY)/256; //重新賦值
counter ++;
//計數累加1ms清零
if(counter == 20)
counter = 0;
//比較輸出PWM
motor1 = PWM[0] > counter;
motor2 = PWM[1] > counter;
motor3 = PWM[2] > counter;
motor4 = PWM[3] > counter;
void motor_up() //前進
PWM[0]=motor_max;
PWM[1]=0;
PWM[2]=motor_max;
PWM[3]=0;
void motor_stop() //后退
PWM[0]=0;
PWM[1]=motor_max;
PWM[2]=0;
PWM[3]=motor_max;
void motor_left() //左轉
PWM[0]=motor_max;
PWM[1]=0;
PWM[2]=0;
PWM[3]=0;
void motor_right() //右轉
PWM[0]=0;
PWM[1]=0;
PWM[2]=motor_max;
PWM[3]=0;
timer_init(); //定時器初始化
ENA=1;
ENB=1;
motor_up();
if(get_distance() <= 50) //判斷是否有障礙物
delay_ms(10); //消抖
if(get_distance() <= 50) //確實有障礙物
motor_left();
delay_ms(500);
motor_up();
