MLX90614ESF+傳感器+紅外非接觸溫度測(cè)量傳感器模塊程序源代碼,用msp430的單片機(jī)
電路原理圖如下:
2018-7-24 00:50 上傳
單片機(jī)源程序如下:
- // MSP430x42x0 Demo - SD16_A, LCD
- //MLX90614 Pin Config
- //GND-----6.0.....I/O supply the MLX90614
- //SDA-----6.1
- //SCL-----6.2
- //POW-----6.3.....I/O supply the MLX90614
- #include <msp430x42x0.h>
- void LCD_CHECK(void);
- void Init_LCD(void);
- unsigned int A1,A2,A3,A4,A5;
- #define a 0x01
- #define b 0x02
- #define c 0x04
- #define d 0x80
- #define e 0x40
- #define f 0x10
- #define g 0x20
- #define h 0x08
- const char char_gen[] = { // definitions for digits
- a+b+c+d+e+f, // Displays "0"
- b+c, // Displays "1"
- a+b+d+e+g, // Displays "2"
- a+b+c+d+g, // Displays "3"
- b+c+f+g, // Displays "4"
- a+c+d+f+g, // Displays "5"
- a+c+d+e+f+g, // Displays "6"
- a+b+c, // Displays "7"
- a+b+c+d+e+f+g, // Displays "8"
- a+b+c+d+f+g, // Displays "9"
- void Delay(unsigned int n);
- void start_bit();
- void stop_bit();
- void send_bit(unsigned char bit_out);
- unsigned char receive_bit();
- unsigned char slave_ack();
- void TX_byte(unsigned char TX_buffer);
- unsigned char RX_byte(unsigned char ack_nack);
- unsigned char PEC_cal(unsigned char pec[],int n);
- unsigned long int MEM_READ( unsigned char slave_addR, unsigned char cmdR );
- void CALTEMP(unsigned long int TEMP);
- void mlx90614_POW_0() { P6OUT &= ~0x08;} // define P6.3 ---> POW
- void mlx90614_POW_1() { P6OUT |= 0x08;}
- void mlx90614_GND_0() { P6OUT &= ~0x01;} // define P6.0 ---> GND
- void mlx90614_GND_1() { P6OUT |= 0x01;}
- void mlx90614_SCL_0() { P6OUT &= ~0x04;} // define P6.2 ---> SCL
- void mlx90614_SCL_1() { P6OUT |= 0x04;}
- void mlx90614_SDA_0() { P6OUT &= ~0x02;} // define P6.1 ---> SDA
- void mlx90614_SDA_1() { P6OUT |= 0x02;}
- #define _SDA_OUTPUT P6DIR |=0x02; //Set SDA as Output
- #define _SDA_INPUT P6DIR &=~0x02; //Set SDA as Input
- #define SDA ((P6IN & BIT1)>>1) //define input pin
- unsigned int i;
- for(i=0;i<n;i++)
- _NOP();
- //Name: start_bit
- void start_bit()
- _SDA_OUTPUT; //Set SDA as output
- Delay(5);
- mlx90614_SDA_1();
- //Delay(30);
- mlx90614_SCL_1();
- Delay(30);
- mlx90614_SDA_0();
- Delay(30);
- mlx90614_SCL_0();
- Delay(30);
- //Name: stop_bit
- void stop_bit()
- Delay(1);
- //mlx90614_SCL_0();
- mlx90614_SDA_0();
- Delay(2);
- mlx90614_SCL_1();
- Delay(2);
- mlx90614_SDA_1();
- //Name: send_bit
- Delay(5);
- if(bit_out==0) {mlx90614_SDA_0();}else{mlx90614_SDA_1();}
- Delay(5);
- mlx90614_SCL_1();
- Delay(30);
- mlx90614_SCL_0();
- Delay(30);
- //Name: receive_bit
- unsigned char bit_in;
- _SDA_INPUT; //Set SDA as input
- Delay(5);
- mlx90614_SCL_1();
- Delay(5);
- if(SDA==1){bit_in=1;}else{bit_in=0;}
- Delay(10);
- mlx90614_SCL_0();
- Delay(30);
- return bit_in;
- //Name: slave_ack
- //1 - ACK
- //0 -NACK
- unsigned char ack;
- ack=0;
- Delay(5);
- mlx90614_SCL_1();
- Delay(10);
- if(SDA==1){ack=0;}else{ack=1;}
- Delay(10);
- mlx90614_SCL_0();
- Delay(30);
- return ack;
- //Name: TX_byte
- unsigned char Bit_counter;
- unsigned char bit_out;
- for(Bit_counter=8;Bit_counter;Bit_counter--)
- if(TX_buffer&0x80){bit_out=1;}else{bit_out=0;}
- send_bit(bit_out); //Send the current bit on SMBus
- TX_buffer<<=1; //Get next bit to check
- //Name: RX_byte
- //Parameters: unsigned char ack_nack (acknowledgment bit)
- //0 - Master device sends ACK
- //1 - Master device sends NACK
- unsigned char RX_buffer;
- if(receive_bit()==1) //Read a bit from the SDA line
- RX_buffer<<=1; //If the bit is HIGH save 1 in RX_buffer
- RX_buffer|=0x01;
- else //If the bit is LOW save 0 in RX_buffer
- RX_buffer<<=1;
- RX_buffer&=0xfe;
- send_bit(ack_nack); //Sends acknowledgment bit
- return RX_buffer;
- //CALCULATE THE PEC PACKET
- unsigned char crc[6];
- unsigned char Bitposition=47;
- unsigned char shift;
- unsigned char i;
- unsigned char j;
- unsigned char temp;
- do{
- crc[5]=0; //Load CRC value 0x000000000107
- crc[4]=0;
- crc[3]=0;
- crc[2]=0;
- crc[1]=0x01;
- crc[0]=0x07;
- Bitposition=47; //Set maximum bit position at 47
- shift=0; //Find first 1 in the transmitted bytes
- i=5; //Set highest index (package byte index)
- j=0; //Byte bit index, from lowest
- while((pec[i]&(0x80>>j))==0 && (i>0))
- Bitposition--;
- if(j<7){ j++;}
- else {j=0x00;i--;}
- }//the position of highest "1" bit in Bitposition is calculated
- shift=Bitposition-8; //Get shift value for CRC value
- while(shift)
- for(i=5;i<0xFF;i--)
- if((crc[i-1]&0x80) && (i>0)) //Check if the MSB of the byte lower is "1"
- { //Yes - current byte + 1
- temp=1; //No - current byte + 0
- } //So that "1" can shift between bytes
- else { temp=0;}
- crc[i]<<=1;
- crc[i]+=temp;
- shift--;
- //Exclusive OR between pec and crc
- for(i=0;i<=5;i++) { pec[i]^=crc[i]; }
- while(Bitposition>8);
- return pec[0];
- //READ DATA FROM RAM/EEPROM
- unsigned long int MEM_READ(unsigned char slave_addR, unsigned char cmdR)
- unsigned char DataL; //
- unsigned char DataH; //Data packets from MLX90614
- unsigned char PEC; //
- unsigned long int Data; //Register value returned from MLX90614
- unsigned char Pecreg; //Calculated PEC byte storage
- unsigned char arr[6]; //Buffer for the sent bytes
- unsigned char ack_nack;
- unsigned char SLA;
- SLA=(slave_addR<<1);
- begin:
- start_bit(); //Send start bit
- TX_byte(SLA); //Send slave address, write
- if(slave_ack()==0){stop_bit();goto begin;} //Send command
- TX_byte(cmdR);
- if(slave_ack()==0){stop_bit();goto begin;}//Send Repeated start bit
- start_bit(); //Send slave address, read
- TX_byte(SLA+1);
- DataL=RX_byte(0); //
- //Read two bytes data
- DataH=RX_byte(0); //
- PEC=RX_byte(ack_nack); //Read PEC from MLX90614
- if(ack_nack==1) //Master sends ack or nack
- //This depends on the pec calculation,
- //if the PEC is not correct, send nack and goto begin
- {stop_bit();goto begin;} //Send stop bit
- stop_bit();
- arr[5]=(SLA);
- arr[4]=cmdR;
- arr[3]=(SLA+1);
- arr[2]=DataL;
- arr[1]=DataH;
- arr[0]=0;
- Pecreg=PEC_cal(arr,6); //Calculate CRC
- if(PEC==Pecreg){ ack_nack=0;}
- else{ ack_nack=1;}
- Data=(DataH*256)+DataL;
- return Data;
- //Name: CALTEMP
- //Temperature data is T=(Data)*0.02-273.15
- unsigned long int T;
- unsigned int A, B;
- //unsigned int tempb;
- T=TEMP*2;
- if(T>=27315)
- T=T-27315;
- A=T/100;
- B=T-A*100;
- if(A>=100){A1=A/100;A=A%100;A2=A/10;A=A%10;A3=A;}
- else if(A>=10){A1=0;A2=A/10;A=A%10;A3=A;}
- else {A1=0;A2=0;A3=A;}
- if(B>=10){A4=B/10;B=B%10;A5=B;}
- else{A4=0;A5=B;}
- else
- T=27315-T;
- A=T/100;
- B=T-A*100;
- A1=9;
- if(A>=10){A2=A/10;A=A%10;A3=A;}
- else{A2=0;A3=A;}
- if(B>=10){ A4=A/10;B=B%10;A5=B;}
- else{A4=0;A5=B;}
- // LCD Test Code
- void LCD_CHECK() // Clear LCD
- int j;
- for( j = 0; j < 8; j ++) { LCDMEM[j] = 0; }
- // Init_LCD.
- void Init_LCD()
- P5SEL = 0x1C; // Set COM pins for LCD
- LCDACTL = LCDON + LCD4MUX + LCDFREQ_128; // 4mux LCD, ACLK/128
- LCDAPCTL0 = 0x0F; // Segs S0-S15 = outputs
- LCDAVCTL0 = LCDCPEN; // Enable LCDA charge pump
- LCDAVCTL1 = VLCD_3_44; // to 3.26V
- void main(void)
- volatile unsigned int i;
- WDTCTL = WDTPW + WDTHOLD; // Stop WDT
- SCFI0 |= FN_3; // Set DCO operating range
- SCFQCTL = 121; // (121+1) x 32768 x 2 = 7.99 Mhz
- FLL_CTL0 = DCOPLUS + XCAP14PF; // DCO+ set so freq = xtal x D x N+1
- for (i = 0; i < 10000; i++); // Delay for 32 kHz crystal to
- P1OUT = 0; // All P1.x reset
- P1IES = 0xC0; // P1.0, P1.1 hi/low edge
- P1DIR = 0x3F; // P1.0/1 = input (switches)
- P6DIR = 0xFF; // All P6.x outputs
- P6OUT = 0; // All P6.x reset
- mlx90614_GND_0(); //powr supply
- mlx90614_POW_1();
- Init_LCD();
- LCD_CHECK();
- while (1)
- unsigned long int i;
- unsigned long int DATA;
- DATA=MEM_READ(0x5a,0x07);
- CALTEMP(DATA);
- //start_bit();
- //A4=1; A5=2; A6=3; A7=4; A8=5;
- LCDMEM[0] |= a + f + e +d + h;
- LCDMEM[1] = char_gen[A5 & 0x0f];
- LCDMEM[2] = char_gen[A4 & 0x0f];
- LCDMEM[3] = char_gen[A3 & 0x0f];
- LCDMEM[3] |= h;
- LCDMEM[4] = char_gen[A2 & 0x0f];
- LCDMEM[5] = char_gen[A1 & 0x0f];
- for (i = 0; i < 0x20000; i++); // Delay
MLX90614ESF 傳感器 紅外非接觸溫度測(cè)量傳感器模塊1.zip
(14.85 MB, 下載次數(shù): 150)
2018-7-23 23:42 上傳
點(diǎn)擊文件名下載附件
MLX90614紅外測(cè)溫模塊程序源代碼 下載積分: 黑幣 -5
