查看: 8420|回復(fù): 6
基于verilog語言的交通信號(hào)燈設(shè)計(jì)分享
一、對(duì)一個(gè)南北向和東西向十字路口車輛信號(hào)燈和人行道信號(hào)燈的顯示進(jìn)行控制,車輛信號(hào)燈為紅黃綠三色,顯示順序?yàn)榫G黃紅循環(huán)顯示,人行道信號(hào)燈為紅綠兩色。南北向?yàn)橹鞲傻溃囕v信號(hào)燈顯示時(shí)間依次為綠燈90秒,黃燈5秒,紅燈40秒,交通燈點(diǎn)亮的同時(shí)2LED燈倒計(jì)數(shù)顯示該等剩余秒數(shù),當(dāng)車輛信號(hào)燈點(diǎn)亮綠燈時(shí)同時(shí)點(diǎn)亮人行道信號(hào)燈的綠燈,點(diǎn)亮?xí)r間為80秒,接著綠燈閃爍10秒,閃爍頻率1Hz,然后點(diǎn)亮紅燈45秒,如此依次進(jìn)行。東西向車輛信號(hào)燈顯示時(shí)間依次為綠燈35秒,黃燈5秒,紅燈95秒,交通燈點(diǎn)亮的同時(shí)2LED燈倒計(jì)數(shù)顯示該等剩余秒數(shù),當(dāng)車輛信號(hào)燈點(diǎn)亮綠燈時(shí)同時(shí)點(diǎn)亮人行道信號(hào)燈的綠燈,點(diǎn)亮?xí)r間為25秒,接著綠燈閃爍10秒,閃爍頻率1Hz,然后點(diǎn)亮紅燈100秒,如此依次進(jìn)行。
二、實(shí)驗(yàn)環(huán)境:
本次實(shí)驗(yàn)采用Cyclone IV EP4CE115F29芯片,系統(tǒng)時(shí)鐘為50MHz實(shí)驗(yàn)環(huán)境為:1PC機(jī)一臺(tái)。2AlteraQuartus軟件一套。3、主芯片為Altera公司的DE2-115EDA開發(fā)板一套。
verilog源碼:
  1. module traffic_led(clkin,con11,con12,con21,con22,t11,t12,t21,t22);
  2. input clkin;
  3. output con11,con12,con21,con22,t11,t12,t21,t22;
  4. reg [1:0] con11,con12,con21,con22;
  5. reg [3:0] t11,t12,t21,t22;
  6. reg [7:0] tcont,tout1,tout2;                             //剩余時(shí)間: t11:高位南北,t12:低位南北,t21:高位東西,t22:低位東西//        //con11:南北車道,con12:南北人行,con21:東西車道,con22:東西人行//
  7. always@(posedge clkin)
  8.         begin
  9.                 tcont<=tcont+1;
  10.                 if(tcont<=80)
  11.                         begin
  12.                                 con11<=0;
  13.                                 con12<=0;
  14.                                 con21<=2;
  15.                                 con22<=2;
  16.                                 t11<=tout1/10;
  17.                                 t12<=tout1-(tout1/10)*10;
  18.                                 t21<=tout2/10;
  19.                                 t22<=tout2-(tout2/10)*10;
  20.                         end
  21.                 else if(tcont<=90)
  22.                         begin
  23.                                 con11<=0;
  24.                                 con12<=1;
  25.                                 con21<=2;
  26.                                 con22<=2;
  27.                                 t11<=tout1/10;
  28.                                 t12<=tout1-(tout1/10)*10;
  29.                                 t21<=tout2/10;
  30.                                 t22<=tout2-(tout2/10)*10;
  31.                         end
  32.                 else if(tcont<=95)
  33.                         begin
  34.                                 con11<=1;
  35.                                 con12<=2;
  36.                                 con21<=2;
  37.                                 con22<=2;
  38.                                 t11<=tout1/10;
  39.                                 t12<=tout1-(tout1/10)*10;
  40.                                 t21<=tout2/10;
  41.                                 t22<=tout2-(tout2/10)*10;
  42.                         end
  43.                 else if(tcont<=120)
  44.                         begin
  45.                                 con11<=2;
  46.                                 con12<=2;
  47.                                 con21<=0;
  48.                                 con22<=0;
  49.                                 t11<=tout1/10;
  50.                                 t12<=tout1-(tout1/10)*10;
  51.                                 t21<=tout2/10;
  52.                                 t22<=tout2-(tout2/10)*10;
  53.                         end
  54.                 else if(tcont<=130)
  55.                         begin
  56.                                 con11<=2;
  57.                                 con12<=2;
  58.                                 con21<=0;
  59.                                 con22<=1;
  60.                                 t11<=tout1/10;
  61.                                 t12<=tout1-(tout1/10)*10;
  62.                                 t21<=tout2/10;
  63.                                 t22<=tout2-(tout2/10)*10;
  64.                         end
  65.                 else if(tcont<=135)
  66.                         begin
  67.                                 con11<=2;
  68.                                 con12<=2;
  69.                                 con21<=1;
  70.                                 con22<=2;
  71.                                 t11<=tout1/10;
  72.                                 t12<=tout1-(tout1/10)*10;
  73.                                 t21<=tout2/10;
  74.                                 t22<=tout2-(tout2/10)*10;
  75.                         end
  76.                 else
  77.                         tcont<=0;
  78.         end
  79.
  80. always@(posedge clkin)
  81.         begin
  82.                 if(tcont<=90)
  83.                         begin
  84.                                 tout1<=90-tcont;
  85.                                 tout2<=95-tcont;
  86.                         end
  87.                 else if(tcont<=95)
  88.                         begin
  89.                                 tout1<=95-tcont;
  90.                                 tout2<=95-tcont;
  91.                         end
  92.                 else if(tcont<=130)
  93.                         begin
  94.                            tout1<=135-tcont;
  95.                                 tout2<=130-tcont;
  96.                         end
  97.                 else if(tcont<=135)
  98.                         begin
  99.                                 tout1<=135-tcont;
  100.                                 tout2<=135-tcont;
  101.                         end
  102.         end
  103.
  104. endmodule
全部資料51hei下載地址:
traffic_led.zip (3.68 MB, 下載次數(shù): 110)
ID:582212 發(fā)表于 2019-7-16 14:53 | 只看該作者
代碼用不了啊
ID:377043 發(fā)表于 2019-8-1 22:45 | 只看該作者
一共有3個(gè)模塊組成,分頻,顯示,交通時(shí)序,朋友是不是沒用全?
ID:619739 發(fā)表于 2019-12-8 00:11 來自觸屏版 | 只看該作者
862422207 發(fā)表于 2019-7-16 14:53
代碼用不了啊
不能運(yùn)行嗎
ID:574789 發(fā)表于 2020-4-1 21:12 | 只看該作者
兄弟,能不能進(jìn)行時(shí)序仿真
ID:574789 發(fā)表于 2020-4-1 21:17 | 只看該作者
這個(gè)是沒有寫testbench嗎
ID:832470 發(fā)表于 2020-12-20 20:48 | 只看該作者
作者看到能會(huì)復(fù)一下嗎
