查看: 6084|回復(fù): 8
stm32STM32F407_FFTDSP庫(kù)_ADC+DMA源碼
ID:374402 發(fā)表于 2018-7-21 20:52 | 顯示全部樓層 |閱讀模式
stm32f407dma和adc
單片機(jī)源程序如下:
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "key.h"
  6. #include "lcd.h"
  7. #include "timer.h"
  8. #include "math.h"
  9. #include "arm_math.h"
  10. #include "adc.h"
  11. #define FFT_LENGTH                         1024        //FFT長(zhǎng)度,默認(rèn)是1024點(diǎn)FFT
  12. float fft_inputbuf[FFT_LENGTH*2];        //FFT輸入數(shù)組
  13. float fft_outputbuf[FFT_LENGTH];        //FFT輸出數(shù)組
  14. u8 timeout;//定時(shí)器溢出次數(shù)
  15. extern u16 AD_Value[1024];
  16. extern u16 After_filter[3];
  17. u16 AD_FFT[1024];
  18. int main(void)
  19. {
  20.   arm_cfft_radix4_instance_f32 scfft;
  21.         u8 key,t=0;
  22.         float time;
  23.         u8 buf[50];
  24.         u16 i,tt;
  25.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級(jí)分組2
  26.         delay_init(168);  //初始化延時(shí)函數(shù)
  27.         uart_init(115200);                //初始化串口波特率為115200
  28.
  29.         LED_Init();                                        //初始化LED
  30.         KEY_Init();                                        //初始化按鍵
  31.         LCD_Init();                                        //初始化LCD
  32.
  33.         DMA_Configuration();
  34.         ADC1_Configuration();
  35.
  36.         TIM3_Int_Init(65535,84-1);        //1Mhz計(jì)數(shù)頻率,最大計(jì)時(shí)65ms左右超出
  37.           POINT_COLOR=RED;
  38.         LCD_ShowString(30,50,200,16,16,"Explorer STM32F4");
  39.         LCD_ShowString(30,70,200,16,16,"DSP FFT TEST");
  40.         LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK");
  41.         LCD_ShowString(30,110,200,16,16,"2014/7/2");
  42.         LCD_ShowString(30,130,200,16,16,"KEY0:Run FFT");//顯示提示信息
  43.         LCD_ShowString(30,160,200,16,16,"FFT runtime:");//顯示FFT執(zhí)行時(shí)間
  44.         POINT_COLOR=BLUE;        //設(shè)置字體為藍(lán)色
  45.         arm_cfft_radix4_init_f32(&scfft,FFT_LENGTH,0,1);//初始化scfft結(jié)構(gòu)體,設(shè)定FFT相關(guān)參數(shù)
  46.         while(1)
  47.         {
  48.                 key=KEY_Scan(0);
  49.                 if(key==KEY0_PRES)
  50.                 {
  51.                         for(i=0;i<FFT_LENGTH;i++)
  52.                                 AD_FFT[i]=AD_Value[i];
  53.                         for(i=0,tt=0;i<FFT_LENGTH;i++)//來(lái)自ADC信號(hào)序列
  54.                         {
  55.                                  fft_inputbuf[2*i] = AD_FFT[tt];
  56.                                  fft_inputbuf[2*i+1]=0;//虛部全部為0
  57.                                  tt++;
  58.                         }
  59. //                        for(i=0;i<FFT_LENGTH;i++)//手動(dòng)生成信號(hào)序列
  60. //                        {
  61. //                                 fft_inputbuf[2*i]=100+
  62. //                                                   10*arm_sin_f32(2*PI*i/FFT_LENGTH)+50*arm_cos_f32(2*PI*i*128/FFT_LENGTH)+
  63. //        30*arm_sin_f32(2*PI*i*4/FFT_LENGTH)+
  64. //                                                   50*arm_cos_f32(2*PI*i*8/FFT_LENGTH);        //生成輸入信號(hào)實(shí)部
  65. //                                 fft_inputbuf[2*i+1]=0;//虛部全部為0
  66. //                        }
  67.                         TIM_SetCounter(TIM3,0);//重設(shè)TIM3定時(shí)器的計(jì)數(shù)器值
  68.                         timeout=0;
  69.
  70.                         arm_cfft_radix4_f32(&scfft,fft_inputbuf);        //FFT計(jì)算(基4)
  71.
  72.                         time=TIM_GetCounter(TIM3)+(u32)timeout*65536;                         //計(jì)算所用時(shí)間
  73.                         sprintf((char*)buf,"%0.3fms\r\n",time/1000);
  74.                         LCD_ShowString(30+12*8,160,100,16,16,buf);        //顯示運(yùn)行時(shí)間
  75.
  76.                         arm_cmplx_mag_f32(fft_inputbuf,fft_outputbuf,FFT_LENGTH);        //把運(yùn)算結(jié)果復(fù)數(shù)求模得幅值
  77.
  78.                         printf("\r\n%d point FFT runtime:%0.3fms\r\n",FFT_LENGTH,time/1000);
  79.                         printf("FFT Result:\r\n");
  80.                         for(i=0;i<FFT_LENGTH;i++)
  81.                         {
  82.                                 printf("fft_outputbuf[%d]:%f\r\n",i,fft_outputbuf[i]);
  83.                                 LCD_DrawLine(i, 0,i,fft_outputbuf[i]/10000);
  84.                                 LCD_ShowxNum(30,5+i*20,fft_outputbuf[i],8,16,0);
  85.                         }
  86.                 }else delay_ms(10);
  87.                 t++;
  88.                 if((t%10)==0)LED0=!LED0;
  89.         }
  90. }
DSP-FFT-ADC我的(好的).rar (1.09 MB, 下載次數(shù): 221)
ID:224494 發(fā)表于 2018-7-21 23:45 | 顯示全部樓層
請(qǐng)問這個(gè)可以測(cè)得頻率嗎 咳咳 老哥
ID:377059 發(fā)表于 2018-7-23 00:31 | 顯示全部樓層
謝謝分享
ID:377442 發(fā)表于 2018-7-27 10:28 | 顯示全部樓層
謝謝分享
ID:298777 發(fā)表于 2018-10-15 19:52 | 顯示全部樓層
1024個(gè)點(diǎn)做完大概用時(shí)多少?
ID:700459 發(fā)表于 2020-3-19 21:11 | 顯示全部樓層
where is please the schematic ?
ID:467843 發(fā)表于 2020-6-3 22:41 | 顯示全部樓層
這代碼有點(diǎn)問題啊,adc壓根沒用到,fftoutput出來(lái)的都是一些隨機(jī)數(shù),keil仿真里 看就知道了。
ID:814008 發(fā)表于 2020-8-13 22:27 | 顯示全部樓層
問一下各位,這個(gè)是干什么的
ID:206695 發(fā)表于 2021-8-1 14:53 | 顯示全部樓層
有沒有頻率
