查看: 6748|回復(fù): 2
FDC2214的Arduino源碼+原理圖PCB圖+封裝庫(kù)等資料下載
ID:376190 發(fā)表于 2018-7-20 20:28 | 顯示全部樓層 |閱讀模式
Altium Designer畫的FDC2214原理圖和PCB圖如下:(51hei附件中可下載工程文件)
FDC2214封裝庫(kù):
資料列表:
1.基于Arduino程序(測(cè)試通過)\
FDC2214-OLED測(cè)試程序
FDC2214串口測(cè)試程序
2.原理圖&PCB圖(AD10可以打開-根據(jù)官方優(yōu)化-改為兩層板)\
參考電路圖\
官方修改版本-兩層板.PcbDoc
3.技術(shù)手冊(cè)(重要內(nèi)容中文翻譯)\
MK_FDC2214-技術(shù)手冊(cè).pdf
4.WEBENCH教程(設(shè)計(jì)必備技能)\
5.官方資料(經(jīng)過整理的)\
FDC2214增強(qiáng)板子資料.pdf
FDC2214官方評(píng)估板說明.pdf
FDC2214計(jì)算器.xlsx
6.封裝庫(kù)\
FDC2214.IntLib
FDC2214的arduino串口測(cè)試程序:
  1. // FDC2x1x hardware configuration:
  2. // Component value as in default circuit form datasheet. (18uH inductor and 33pF cap)
  3. //
  4. // SD and ADDR pins tied to GND
  5. // INTB pin not used
  6. //
  7. // ARDUINO <--> FDC
  8. // A4 <-------> SDA
  9. // A5 <-------> SCL
  10. //
  11. // !!!!!! Arduinos are mostly 5V. FDC chips are 3.3V, so either use 3.3V version of Arduino, like pro mini, or use level shifter on I2C bus.
  12. //
  13. // ### FDC
  14. #include <Wire.h>
  15. #include "FDC2214.h"
  16. FDC2214 capsense(FDC2214_I2C_ADDR_0); // Use FDC2214_I2C_ADDR_1
  17. // ###
  18. void setup() {
  19.
  20.   // ### Start I2C
  21.   Wire.begin();
  22. //  Wire.setClock(400000L);
  23.
  24.   // ### Start serial
  25.   Serial.begin(115200);
  26.   Serial.println("\nFDC2x1x test");
  27.
  28.   // ### Start FDC
  29.   // Start FDC2212 with 2 channels init
  30.   bool capOk = capsense.begin(0x3, 0x4, 0x5); //setup first two channels, autoscan with 2 channels, deglitch at 10MHz
  31.   // Start FDC2214 with 4 channels init
  32.   //bool capOk = capsense.begin(0xF, 0x4, 0x5); //setup all four channels, autoscan with 2 channels, deglitch at 10MHz
  33.   if (capOk) Serial.println("Sensor OK");
  34.   else Serial.println("Sensor Fail");
  35. }
  36. // ### Tell aplication how many chanels will be smapled in main loop
  37. #define CHAN_COUNT 2
  38. // ###
  39. void loop() {
  40.   unsigned long capa[CHAN_COUNT]; // variable to store data from FDC
  41.   for (int i = 0; i < CHAN_COUNT; i++){ // for each channel
  42.     // ### read 28bit data
  43.     capa[i]= capsense.getReading28(i);//
  44.     // ### Transmit data to serial in simple format readable by SerialPlot application.
  45.     Serial.print(capa[i]);
  46.     if (i < CHAN_COUNT-1) Serial.print(", ");
  47.     else Serial.println("");
  48.   }
  49.   // No point in sleeping
  50.   //delay(100);
  51. }
全部資料51hei下載地址:
FDC2214資料.zip (15.5 MB, 下載次數(shù): 102)
ID:386837 發(fā)表于 2018-8-18 11:57 | 顯示全部樓層
感謝,非常有用
ID:378717 發(fā)表于 2019-8-11 17:46 | 顯示全部樓層
no matching function for call to 'FDC2214::begin(int, int, int)'
下載了文件,上傳示例程序
出現(xiàn)這種錯(cuò)誤是怎么回事呢?
