#include<reg52.h>
#include"lcd1602.h"
unsigned char print
sfr T2MOD = 0x0c9;
sbit Q0 = P2^4;
sbit Q1 = P2^5;
sbit Q2 = P2^6;
sbit Q3 = P2^7;
sbit PWM = P1^7;
sbit UP = P1^0;
sbit DOWM = P1^1;
sbit GORB = P2^3; //換相
sbit ADDSPEED = P1^2;
sbit SUBSPEED = P1^3;
uint tuint = 65535;
uint tpwm = 1; //pwm周期為10000us tpwm變量表示pwm高電平時間,也相當(dāng)于占空比 (仿真時,頻率高時,電機(jī)反應(yīng)慢。在實(shí)物上要加大頻率)
uchar t1_flag = 0;
uint pulse = 0;
uint t0_flag = 0;
uchar t2_flag = 0;
bit t2_over = 0;
bit Just_Get = 1;
#define ZZ { Q0 = 0;Q1 = 0;Q2 = 1;Q3 = 1;} //正轉(zhuǎn)
#define FZ { Q0 = 1;Q1 = 1;Q2 = 0;Q3 = 0;} //反轉(zhuǎn)
#define STOP { Q0 = 1;Q1 = 0;Q2 = 1;Q3 = 0;} //停止
//禁止出現(xiàn) Q0 = 0;Q1 = 1;Q2 = 0;Q3 = 1; 不然會燒掉mos管
//************************ PID *************************************
float now = 0,bef = 0,bbef = 0; //本次采樣值,上次采樣值,上上次采樣值
float err_now,err_bef,err_bbef; //當(dāng)前偏差,上次偏差,上上次偏差
float error_add = 0; //所有偏差之和
float set = 25; //設(shè)定值
float kp = 25;
float ki = 25;
float kd = 0;
void delayms(uint ms)//延時?個 ms
uchar a,b,c;
while(ms--)
for(c=1;c>0;c--)
for(b=142;b>0;b--)
for(a=2;a>0;a--);
void timer_init()
EA = 1;
ET0 = 1;
ET1 = 1;
ET2 = 1;
TMOD = 0x15; //定時器0 計數(shù)模式 定時器1模式1
T2MOD = 0x01;
TH0 = TL0 = 255;
TH2 = 0x3C;
TL2 = 0xB0; //50MS
void timer1() interrupt 3
if(t1_flag == 0)
t1_flag = 1;
PWM = 1;
TH1 = (tuint - tpwm + 1)/256;
TL1 = (tuint - tpwm + 1)%256;
t1_flag = 0;
PWM = 0;
TH1 = (tuint - 10000 + tpwm + 1)/256;
TL1 = (tuint - 10000 + tpwm + 1)%256;
void timer0() interrupt 1
TH0 = TL0 = 255;
t0_flag++;
void timer2() interrupt 5
TF2 = 0;
TH2 = 0x3C;
TL2 = 0xB0; //50MS
t2_flag++;
if(t2_flag == 2)
TR0 = 0;
TR2 = 0;
t2_flag = 0;
t2_over = 1; //表示100ms時間到
void GetPulse()
t0_flag = 0;
t2_flag = 0;
TH0 = TL0 = 255;
TH2 = 0x3C;
TL2 = 0xB0; //50MS
TR0 = 1;
TR2 = 1;
int PID() //增量式PID
int change;
err_now = set - now;
err_bef = set - bef;
err_bbef = set - bbef;
change = kp*(err_now - err_bef) + ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
if(set >= now)
if(set - now > 1)
change = 0.2*kp*(err_now - err_bef) + 0.5*ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
else if(now > set)
if(now - set > 1)
//change = (kp + ki + kd)*(set - now) + (-kp - 2*kd)*(set - bef) + kd*(set - bbef);
//change = kp*(set - now) + ki*(set - bef) + kd*(set - bbef);
if(change > 0)
printchar(1,10,'+');
printuint(1,11,4,change);
else if(change < 0)
printchar(1,10,'-');
printuint(1,11,4,-change);
else if(change == 0)
printchar(1,10,' ');
printword(1,11," 0 ");
return(change);
int PID2() //位置式PID
int num = 0;
static num_bef = 0;
error_add = error_add + err_now; //誤差累加。一旦誤差為0則error_add的值不變,PID輸出值不變
num = kp*err_now + ki*error_add + kd*(err_now - err_bef);
if(set - now >= 0)
if(set - now > 1)
num = 0.1*kp*err_now + ki*error_add + kd*(err_now - err_bef);
if(now - set > 1)
if(num > num_bef)
printuint(1,11,4,num - num_bef);
else if(num < num_bef)
printuint(1,11,4,num_bef - num);
printuint(1,11,4,0);
num_bef = num;
return((uint)num);
lcd_init();
timer_init();
TH1 = TL1 = 255;
printword(0,0,"P:"); //比例系數(shù)
printword(0,5,"S:"); //設(shè)定值
printword(1,0,"TPWM:"); //當(dāng)前占空比
printword(0,10,"PS:"); //當(dāng)前電機(jī)反饋的每秒脈沖數(shù)
if(GORB == 1)
{ ZZ; }
{ FZ; }
if(ADDSPEED == 0)
set++;
if(SUBSPEED == 0)
set--;
if(Just_Get == 1)
Just_Get = 0;
GetPulse();
else if(t2_over == 1)
t2_over = 0;
Just_Get = 1;
pulse = t0_flag;
bbef = bef;
bef = now;
now = t0_flag;
if(set != 0)
TR1 = 1;
TR1 = 0;
PWM = 0;
// tpwm = tpwm + PID(); //增量式PID
tpwm = PID2(); //位置式PID
if(UP == 0)
kp = kp + 1;
if(DOWM == 0)
kp = kp - 1;
printuint(0,2,3,kp);
printuint(0,7,3,set);
printuint(1,5,4,tpwm);
printuint(0,13,5,pulse);
