查看: 1304|回復: 0
簡單的PWM 電機調速器
#include <reg51.h>
#include <stdio.h>
uchar cycle=100;
uchar speed=50;
sbit IN1=P2^0;
sbit IN2=P2^1;
sbit ENA=P2^2;
void zz()
   IN1=1;
   IN2=0;
void fz()
   IN1=0;
   IN2=1;
void stop()
   IN1=0;
   IN2=0;
void to(void) interrupt 1 using 1
   if(cycle>100)
      cycle=0;
   if(cycle>speed)
      ENA=0;
      ENA=1;
   cycle++;
void speedup()
   if(speed>99)
      speed=100;
      speed++;
void speeddown()
   if(speed<1)
      speed=0;
      speed--;
void main(void)
   EA=1;
   EX0=1;
   IT0=1;
   TMOD=0x12;
   TH0=0x06;
   TL0=0x06;
   TR0=1;
   ET0=1;
   PX0=1;
   P1=0xff;
void int0(void) interrupt 0 using 0
   switch(P1)
      case 0xfe:zz();break;
      case 0xfd:fz();break;
      case 0xfb:stop();break;
      case 0xf7:speedup();break;
      case 0xef:speeddown();break;
      default:P1=0xff;break;
