查看: 25957|回復(fù): 0
D類放大器IRS2092引腳圖電路圖與資料手冊下載
D 類放大器又可稱數(shù)字式功率放大,基本架構(gòu)如圖 2 所示,輸入訊號經(jīng)由脈波寬度調(diào)變器(Pulse Width Modulation)將音頻信號調(diào)制成數(shù)字信號后,由功率晶體管(Q1,Q2)放大輸出,再經(jīng)由低通濾波器(Lf,Cf)取出原輸入端的音頻訊號送至喇叭輸出。
IRS2092引腳圖:
IRS2092管腳功能定義:
IRS2092應(yīng)用電路圖:
IRS2092框圖:
Note 1:  Logic operational for Vs equal to –5 V to +200 V. Logic state held for Vs equal to –5 V to –VBS.
Note 2:  Nominal voltage for VREF is 5.1 V.  IOREF of 0.3 – 0.8 mA dictates total external resistor value on VREF to be 6.3 kΩ to
16.7 kΩ.
Note 3:  GND input voltage is limited by IAAZ and ISSZ.
Note 4:  VSS ramps up from 0 V to 200 V.
Note 5:  Output logic status may not respond correctly if input pulse width is smaller than the minimum pulse width.
[10]IRAUDAMP7D.pdf
644.02 KB, 下載次數(shù): 64, 下載積分: 黑幣 -5
IRS2092.pdf
231.23 KB, 下載次數(shù): 52, 下載積分: 黑幣 -5
[02]IRS2092.pdf
375.04 KB, 下載次數(shù): 53, 下載積分: 黑幣 -5
2092數(shù)字板.pdf
79.96 KB, 下載次數(shù): 82, 下載積分: 黑幣 -5
