查看: 1899|回復(fù): 0
LCD1602字母顯示
ID:372503 發(fā)表于 2018-7-16 14:02 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#define LCD1602_DB  P0      //data bus 數(shù)據(jù)總線
sbit LCD1602_RS = P2^6;
sbit LCD1602_RW = P2^5;
sbit LCD1602_EN = P2^7;
void InitLcd1602();
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str);
    unsigned char str[] = "Welcome To You";
    InitLcd1602();
    LcdShowStr(0,0,str);
    while(1);
void Read_Busy()           //忙檢測函數(shù),判斷bit7是0,允許執(zhí)行;1禁止
    unsigned char sta;      //
    LCD1602_DB = 0xff;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_EN = 1;
        sta = LCD1602_DB;
        LCD1602_EN = 0;    //使能,用完就拉低,釋放總線
    }while(sta & 0x80);
void Lcd1602_Write_Cmd(unsigned char cmd)     //寫命令
    Read_Busy();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_EN = 1;
    LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat)   //寫數(shù)據(jù)
      Read_Busy();
      LCD1602_RS = 1;
      LCD1602_RW = 0;
      LCD1602_DB = dat;
      LCD1602_EN = 1;
      LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y)  //坐標(biāo)顯示
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    Lcd1602_Write_Cmd(addr|0x80);
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str)     //顯示字符串
    LcdSetCursor(x,y);      //當(dāng)前字符的坐標(biāo)
    while(*str != '\0')
        Lcd1602_Write_Data(*str++);
void InitLcd1602()              //1602初始化
    Lcd1602_Write_Cmd(0x38);    //打開,5*8,8位數(shù)據(jù)
    Lcd1602_Write_Cmd(0x0c);
    Lcd1602_Write_Cmd(0x06);
    Lcd1602_Write_Cmd(0x01);    //清屏
