查看: 2018|回復: 2
51單片機12864的圖片顯示
ID:347243 發表于 2018-7-16 13:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#include"st7565.h"
//---存一個圖片--//
unsigned char code pic[]={
/*--  寬度x高度=128x64  --*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,
0x57,0x53,0x57,0x07,0xFF,0x0F,0xE3,0x0F,0xEF,0xFF,0xEF,0xEF,0xEF,0x03,0xEF,0xEF,
0xEF,0x0F,0xE3,0x0F,0xEF,0xFF,0x77,0x77,0x17,0x57,0x57,0x53,0x57,0x57,0x17,0x77,
0x77,0xFF,0xFB,0x8B,0xAB,0x83,0xAB,0x83,0xAB,0x8B,0xFF,0x37,0xDB,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEE,0xF5,
0xFB,0xF4,0xEF,0xE0,0xFF,0xF4,0xFB,0xF4,0xEF,0xFF,0xE0,0xEE,0xEE,0xEE,0xEE,0xE0,
0xFF,0xF4,0xFB,0xF5,0xEC,0xFF,0xE2,0xEF,0xEF,0xE1,0xFD,0xFD,0xFD,0xF9,0xF7,0xEF,
0xEE,0xFF,0xEB,0xF2,0xFA,0xE2,0xEA,0xFA,0xF2,0xEB,0xFF,0xE0,0xFD,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xE3,0x81,0x81,0xE3,0xFF,0xFF,0xDF,0xDD,0xD5,0x4D,0x9D,0x00,
0x9D,0x4D,0xD5,0xDD,0xDF,0xFF,0xFB,0xFB,0x00,0xFB,0xFB,0x9B,0xEB,0xFB,0x0F,0xE9,
0xEE,0xFF,0xEF,0xEE,0x2A,0xAA,0xAA,0xA8,0xA2,0x0A,0xAA,0x6E,0xEF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xFC,0xFF,0xFF,0xFF,0xFD,0xFD,0xFE,0xFF,0x7F,0x78,
0x7F,0x7F,0xFE,0x7D,0x7D,0xBF,0xBB,0xBB,0xBA,0xBA,0x3A,0xBB,0xBB,0xBD,0xBE,0x7D,
0x7B,0xBF,0xBF,0xBF,0x78,0xFA,0xFA,0xFA,0xFA,0xF8,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x87,0xF8,0xFF,0xFF,
0xFF,0x7F,0x7E,0xBD,0xCF,0x73,0xBF,0xDB,0xDD,0xBD,0x7B,0xFE,0x7F,0xBB,0xDD,0xDD,
0xBB,0x7F,0xE7,0x9F,0x5F,0xBE,0x7D,0x73,0xEF,0x9F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xFD,0x0D,0xF2,0xFC,
0xFE,0xFF,0xFF,0xEF,0x1F,0x3E,0xDC,0xE8,0xEB,0xED,0xDE,0xD7,0xD6,0xD4,0x68,0x6B,
0xED,0xF6,0xF7,0xEF,0x1F,0xFE,0xFD,0xF3,0x0E,0xFE,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xC3,0x81,0x3C,0x7E,0xFE,0xFE,0xFD,0xF9,0xFD,0xFE,0xFA,0x66,
0xBD,0x00,0x7E,0xFE,0xFE,0xFD,0xF9,0xFD,0xFE,0xFA,0x66,0xBD,0xC3,0xFF,0xFC,0x73,
0x37,0x2F,0xAF,0xDE,0xDF,0xBF,0xAC,0x9B,0xB7,0xB7,0x6C,0x6C,0x6F,0x6F,0xB6,0xB6,
0xDB,0xCB,0xD5,0xAA,0x2F,0x37,0x7B,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFC,0xF9,0xF3,0xF7,0xFB,0xFD,0xFE,0xFF,
0xFF,0xFF,0xFE,0xFC,0xF9,0xF3,0xF7,0xFB,0xFD,0xFE,0xFF,0xDF,0xDF,0xC1,0xC8,0xDC,
0xFF,0xF8,0xF7,0xEF,0xDF,0xF8,0xF2,0xF2,0xF8,0xFC,0xFE,0xFC,0xFC,0xFE,0xFC,0xF8,
0xF2,0xD2,0xE8,0xF7,0xF8,0xFF,0xDC,0xC8,0xC1,0xC3,0xC7,0xFF,0xFF,0xFF,0xFF,0xFF,
* 函 數 名         : main
* 函數功能                   : 主函數
* 輸    入         : 無
* 輸    出         : 無
void main(void)
        uchar i , j;
        uint n;
        Lcd12864_Init();        //初始化
        Lcd12864_ClearScreen();        //清屏
        for (i=0;i<8;i++)
            //--設置初始顯示開始位置--//
                LcdSt7565_WriteCmd(0x40);
                //--設置Y坐標--//
                LcdSt7565_WriteCmd(0xB0+i);
                //--設置X坐標--//
                LcdSt7565_WriteCmd(0x10);
                LcdSt7565_WriteCmd(0x04);
                for(j=0; j<128; j++)
                        LcdSt7565_WriteData(~pic[n]);
                        n=n+1;
        while (1)
ID:1 發表于 2018-7-16 17:24 | 只看該作者
本文需要補全頭文件和壓縮包后才可獲得積分
ID:97554 發表于 2018-7-16 19:16 | 只看該作者
admin 發表于 2018-7-16 17:24
老大英明
