- #include <msp430x14x.h>
- #include "Keypad.h"
- #include "cry1602.h"
- #include "x9c103.h"
- #define uchar unsigned char
- #define uint unsigned int
- #define Num_of_Results 128
- extern uchar num[];
- uchar tishi[] = {"Vout:"};
- static uint results[Num_of_Results]; //保存ADC轉(zhuǎn)換結(jié)果的數(shù)組 // is not used for anything.
- void Trans_val(uint Hex_Val);
- void keytest();
- /************************主函數(shù)****************************/
- void main(void)
- WDTCTL = WDTPW+WDTHOLD; //關(guān)閉看門(mén)狗
- LcdReset(); //復(fù)位1602液晶
- DispNChar(0,0,5,tishi);
- DispNChar(0,1,4,"set:"); //顯示提示信息
- Init_Keypad(); //初始化鍵盤(pán)端口
- P1DIR|=0X07;
- x9c_init();
- P6SEL |= 0x01; // 使能ADC通道
- ADC12CTL0 = ADC12ON+SHT1_8+MSC; // 打開(kāi)ADC,設(shè)置采樣時(shí)間
- ADC12CTL1 = SHP+CONSEQ_2; // 使用采樣定時(shí)器
- ADC12IE = 0x01; // 使能ADC中斷
- ADC12CTL0 |= ENC; // 使能轉(zhuǎn)換
- ADC12CTL0 |= ADC12SC; // 開(kāi)始轉(zhuǎn)換
- _EINT();
- LPM0;
- 函數(shù)名稱:ADC12ISR
- 功 能:ADC中斷服務(wù)函數(shù),在這里用多次平均的
- 計(jì)算P6.0口的模擬電壓數(shù)值
- 參 數(shù):無(wú)
- 返回值 :無(wú)
- #pragma vector=ADC12_VECTOR
- __interrupt void ADC12ISR (void)
- static uint index = 0;
- results[index++] = ADC12MEM0; // Move results
- if(index == Num_of_Results)
- uchar i;
- unsigned long sum = 0;
- index = 0;
- for(i = 0; i < Num_of_Results; i++)
- sum += results[i];
- sum >>= 7; //除以512
- Trans_val(sum);
- keytest();
- 函數(shù)名稱:Trans_val
- 功 能:將16進(jìn)制ADC轉(zhuǎn)換數(shù)據(jù)變換成三位10進(jìn)制
- 真實(shí)的模擬電壓數(shù)據(jù),并在液晶上顯示
- 參 數(shù):Hex_Val--16進(jìn)制數(shù)據(jù)
- n--變換時(shí)的分母等于2的n次方
- 返回值 :無(wú)
- unsigned long caltmp;
- uint Curr_Volt;
- uchar t1,i;
- uchar ptr[4];
- caltmp = Hex_Val;
- caltmp = (caltmp << 5) + Hex_Val; //caltmp = Hex_Val * 33
- caltmp = (caltmp << 3) + (caltmp << 1); //caltmp = caltmp * 10
- caltmp = (caltmp << 1) + caltmp;
- Curr_Volt = caltmp >> 11; //Curr_Volt = caltmp / 2^n
- Curr_Volt+=60;
- ptr[0] = (Curr_Volt-(Curr_Volt/1000)*1000) / 100; //Hex->Dec變換
- t1 = Curr_Volt -(Curr_Volt/1000)*1000- (ptr[0] * 100);
- ptr[2] = t1 / 10;
- ptr[3] = t1 - (ptr[2] * 10);
- ptr[1] = -2; //shuzi表中第10位對(duì)應(yīng)符號(hào)"."
- //在液晶上顯示變換后的結(jié)果
- Disp1Char(5,0,'1');
- for(i = 0;i < 4;i++)
- Disp1Char((6 + i),0,ptr[i]+48);
double_test.rar
2018-7-14 16:04 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
65.59 KB, 下載次數(shù): 18, 下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
