電位器測角度msp430149程序
- 程序功能:MCU的片內ADC對P6.0端口的電壓進行轉換
- 將模擬電壓值顯示在1602液晶上。
- #include <msp430x14x.h>
- #include "cry1602.h"
- #include "cryfucns.h"
- #define uchar unsigned char
- #define uint unsigned int
- #define Num_of_Results 32
- uchar shuzi[] = {"0123456789."};
- uchar tishi[] = {"The volt is:"};
- static uint results[Num_of_Results]; //保存ADC轉換結果的數(shù)組 // is not used for anything.
- void Trans_val(uint Hex_Val);
- /************************主函數(shù)****************************/
- void main(void)
- WDTCTL = WDTPW+WDTHOLD; //關閉看門狗
- //LcdReset(); //復位1602液晶
- //DispNChar(2,0,12,tishi); //顯示提示信息
- // Disp1Char(11,1,'V'); //顯示電壓單位
- Ini_Lcd(); //初始化液晶
- P6SEL |= 0x01; // 使能ADC通道
- ADC12CTL0 = ADC12ON+SHT0_8+MSC; // 打開ADC,設置采樣時間
- ADC12CTL1 = SHP+CONSEQ_2; // 使用采樣定時器
- ADC12IE = 0x01; // 使能ADC中斷
- ADC12CTL0 |= ENC; // 使能轉換
- ADC12CTL0 |= ADC12SC; // 開始轉換
- _EINT();
- LPM0;
- 函數(shù)名稱:ADC12ISR
- 功 能:ADC中斷服務函數(shù),在這里用多次平均的
- 計算P6.0口的模擬電壓數(shù)值
- 參 數(shù):無
- 返回值 :無
- #pragma vector=ADC_VECTOR
- __interrupt void ADC12ISR (void)
- static uint index = 0;
- results[index++] = ADC12MEM0; // Move results
- if(index == Num_of_Results)
- uchar i;
- unsigned long sum = 0;
- index = 0;
- for(i = 0; i < Num_of_Results; i++)
- sum += results[i];
- sum >>= 5; //除以32
- Trans_val(sum);
- 函數(shù)名稱:Trans_val
- 功 能:將16進制ADC轉換數(shù)據(jù)變換成三位10進制
- 真實的模擬電壓數(shù)據(jù),并在液晶上顯示
- 參 數(shù):Hex_Val--16進制數(shù)據(jù)
- n--變換時的分母等于2的n次方
- 返回值 :無
- unsigned long caltmp;
- uint Curr_Volt;
- uchar t1,i;
- uchar ptr[4];
- caltmp = Hex_Val;
- caltmp = (caltmp << 5) + Hex_Val; //caltmp = Hex_Val * 33
- caltmp = (caltmp << 3) + (caltmp << 1); //caltmp = caltmp * 10
- Curr_Volt = caltmp >> 12; //Curr_Volt = caltmp / 2^n
- ptr[0] = Curr_Volt / 100; //Hex->Dec變換,百
- t1 = Curr_Volt - (ptr[0] * 100);
- ptr[2] = t1 / 10;//十
- ptr[3] = t1 - (ptr[2] * 10);
- ptr[1] = 10; //shuzi表中第10位對應符號"."
- //在液晶上顯示變換后的結果
- Send(0,0x80); //顯示的起始地址
- for(i = 0;i < 4;i++)
- Send(1,shuzi[ptr[i]]);
- //Disp1Char((6 + i),1,shuzi[ptr[i]]);
電位器AD轉換.zip
(343.66 KB, 下載次數(shù): 21)
2018-7-14 14:56 上傳
下載積分: 黑幣 -5
