查看: 3532|回復: 3
精品0.96寸液晶圖形摸擬鐘加摸擬溫度計
ID:358930 發表于 2018-7-14 12:10 來自觸屏版 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
圖片在底部
  1. //A4  SDA
  2. //A5  SCL
  3. //0X57   0X68
  4. #include <Arduino.h>
  5. #include <DS3231.h>
  6. #include <Wire.h>
  7. #include <Adafruit_GFX.h>
  8. #include <Adafruit_SSD1306.h>
  9. int r,xo,yo,a,b,c,z;//動畫變量不能用char型變量無法計算
  10. int sec;//動畫變量不能用char型變量無法計算
  11. DS3231 Clock;
  12. bool Century=false;
  13. bool h12;
  14. bool PM;
  15. byte ADay, AHour, AMinute, ASecond, ABits;
  16. bool ADy, A12h, Apm;
  17. int second,minute,hour,date,month,year,DoW;
  18. byte   temperature;//溫度
  19. #define OLED_RESET 4
  20. Adafruit_SSD1306 display(OLED_RESET);
  21. #define NUMFLAKES 10
  22. #define XPOS 0
  23. #define YPOS 1
  24. #define DELTAY 2
  25. #define LOGO16_GLCD_HEIGHT 16
  26. #define LOGO16_GLCD_WIDTH  16
  27. #if (SSD1306_LCDHEIGHT != 64)
  28. #error("Height incorrect, please fix Adafruit_SSD1306.h!");
  29. #endif
  30. int x;//動畫變量
  31. //顯示一個心形
  32. static const uint8_t PROGMEM Heart_16x16[] = {
  33.   0x00,0x00,0x18,0x18,0x3C,0x3C,0x7E,0x7E,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  34.   0xFF,0xFF,0x7F,0xFE,0x3F,0xFC,0x1F,0xF8,0x0F,0xF0,0x07,0xE0,0x03,0xC0,0x00,0x00//未命名文件0
  35. };
  36. static const uint8_t PROGMEM bbjj_16x16[] ={
  37. 0x00,0x00,0x23,0xF8,0x12,0x08,0x12,0x08,0x83,0xF8,0x42,0x08,0x42,0x08,0x13,0xF8,
  38. 0x10,0x00,0x27,0xFC,0xE4,0xA4,0x24,0xA4,0x24,0xA4,0x24,0xA4,0x2F,0xFE,0x00,0x00,/*"溫",0*/
  39. 0x01,0x00,0x00,0x80,0x3F,0xFE,0x22,0x20,0x22,0x20,0x3F,0xFC,0x22,0x20,0x22,0x20,
  40. 0x23,0xE0,0x20,0x00,0x2F,0xF0,0x24,0x10,0x42,0x20,0x41,0xC0,0x86,0x30,0x38,0x0E,/*"度",1*/
  41. };
  42. void setup()   {
  43. // Serial.begin(115200);
  44.   delay(500);
  45. Wire.begin();
  46.       /*
  47.          //改時間
  48.         Clock.setSecond(10);//Set the second
  49.         Clock.setMinute(40);//Set the minute
  50.         Clock.setHour(1);  //Set the hour
  51.         Clock.setDoW(7);    //Set the day of the week
  52.         Clock.setDate(24);  //Set the date of the month
  53.         Clock.setMonth(6);  //Set the month of the year
  54.         Clock.setYear(18);  //Set the year (Last two digits of the year)
  55.       */
  56.   display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3D (for the 128x64)
  57. }
  58. void ReadDS3231()//讀取時間
  59. {
  60.   second=Clock.getSecond(); //時間
  61.   minute=Clock.getMinute();//時間
  62.   hour=Clock.getHour(h12, PM);//時間
  63.   date=Clock.getDate(); //日期
  64.   month=Clock.getMonth(Century);//日期
  65.   year=Clock.getYear();  //日期
  66.   DoW=Clock.getDoW();//星期
  67.   temperature=Clock.getTemperature();//溫度
  68. }
  69. void loop() {
  70.      ReadDS3231();//讀取時間
  71.
  72.   //1.檢測全屏顯示(看看有沒有大面積壞點)
  73.   display.fillScreen(WHITE);//檢測全屏顯示(看看有沒有大面積壞點)
  74.   display.clearDisplay();   // clears the screen and buffer
  75. /*
  76.    //2.畫點 點坐標(10,10)
  77.   display.drawPixel(20, 20, WHITE);// 列127 行63 畫點 點坐標
  78.
  79.   //3. 畫線 從(0,0)到(50,50)
  80.   display.drawLine(20, 25,20,63, WHITE);//(開始列127  開始行63)( 結束列127 結束行63)
  81.
  82.   //4.畫空心矩形  左上角坐標(x0,y0)  右下角坐標(x1,y1)
  83.   display.drawRect(2,50,10,10,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=列+x  結束大小=行+Y)
  84.
  85.   //5.畫個實心矩形
  86.   display.fillRect(2,35,10,10,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=列+x  結束大小=行+Y)
  87.
  88.    //6.畫空心圓
  89.   display.drawCircle(36,50,6,WHITE);//(控制圓心位置列0/127   控制圓心位置行0/63  )(控制大小=0+x )
  90.
  91.   //7.畫實心圓
  92.   display.fillCircle(36,30,6,WHITE);//(控制圓心位置列0/127   控制圓心位置行0/63  )(控制大小=0+x )
  93.
  94.   //8.畫空心三角形
  95.   display.drawTriangle(60,32,45,43,70,43,WHITE);//(控制三角形A點列0/127 行0/63  控制三角形B點列0/127 行0/63 控制三角形C點列0/127 行0/63)
  96.
  97.   //9.畫實心三角形
  98.   display.fillTriangle(86,32,72,43,100,43,WHITE);//(控制三角形A點列0/127 行0/63  控制三角形B點列0/127 行0/63 控制三角形C點列0/127 行0/63)
  99.   //10.畫空心圓角矩形
  100.   display.drawRoundRect(50,17,15,15,2,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=列+x  結束大小=行+Y  控制圓角=+x)
  101. //11.畫實心圓角矩形
  102.   display.fillRoundRect(70,17,15,15,2,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=列+x  結束大小=行+Y  控制圓角=+x)
  103.   //12.畫心形(自己用取模軟件畫的)相當于一個任意16X16字
  104.   display.drawBitmap(88,17,Heart_16x16,16,16,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=16  結束大小=16)這里只能是16X16因為是16X16字
  105. //13.顯示英文
  106.   display.setTextSize(2);//設置字體大小
  107.   display.setTextColor(WHITE);//設置字體不反白
  108.   display.setCursor(0,0);//列127 行63     坐標
  109.   display.println("bb");
  110.
  111.   //14.顯示數字變量
  112.   display.setTextSize(2);//設置字體大小
  113.   display.setTextColor(BLACK, WHITE); //設置字體反白
  114.   display.setCursor(30,0);//列127 行63     坐標
  115.   display.println(x);
  116.
  117. //15.顯示16進制變量
  118.   display.setTextSize(2);
  119.   display.setTextColor(WHITE);//設置字體不反白
  120.   display.setCursor(60,0);//列127 行63     坐標
  121.   display.print("0x");
  122.   display.println(x, HEX);
  123. //16.顯示單個文字 就是調用drawBitmap(自己用取模軟件取模)相當于一個任意16X16字
  124.   //display.drawBitmap(0,17,Strong_16x16,16,16,BLACK);//可用BLACK黑字在圖片上顯示(控制位置列0/127   控制位置行0/63  )(控制大小=16  結束大小=16)這里只能是16X16因為是16X16字
  125.   display.drawBitmap(0,17,Strong_16x16,16,16,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=16  結束大小=16)這里只能是16X16因為是16X16字
  126. //17.顯示多個文字(在庫里面加入一個ShowCN_16方法  為了同時顯示多個中文 16X16 ,不然的話 就得一個一個drawBitmap)
  127.   display.ShowCN_16(0,45, bbjj_16x16,sizeof(bbjj_16x16)/32,WHITE);//查找數組法(控制位置列0/127   控制位置行0/63  )
  128. */
  129. //6.畫空心圓
  130.    display.drawCircle(xo,yo,19,WHITE);//(控制圓心位置列0/127   控制圓心位置行0/63  )(控制大小=0+x )
  131.    display.drawCircle(xo,yo,25+6,WHITE);//(控制圓心位置列0/127   控制圓心位置行0/63  )(控制大小=0+x )
  132.   //7.畫實心圓
  133.   display.fillCircle(xo,yo,2,WHITE);//(控制圓心位置列0/127   控制圓心位置行0/63  )(控制大小=0+x )
  134.    //不能用char型變量無法計算
  135.   r=17;//指針半徑
  136.   xo=80;//圓心坐標x MAX 127
  137.   yo=32;//圓心坐標y  MAX 63
  138.   z=180;//圓
  139.   //second=0;//調整
  140.   // minute=0;//調整
  141.    // hour=0;//調整
  142.   int  hour1=hour;
  143.    if(hour1>12)
  144. {hour1=hour1-12;}
  145. else
  146. {hour1=hour1;}
  147.   a=(second-15)*6;//圓角度360/60
  148.   b=(minute-15)*6;//圓角度360/60
  149.   c=(hour1-15)*30;//圓角度360/12
  150.   //.畫一圈實心圓
  151.    int B;
  152.    for(B=0;B<12;B++)//.畫一圈實心圓
  153.    {
  154.      int A=B*30;//圓角度
  155.     if(B==0||B==3||B==6||B==9)//跳過這幾個點畫實心圓
  156.     {}
  157.     else
  158.    {
  159.     display.fillCircle((xo+((r+9)*cos(A*3.14/z))),(yo+((r+9)*sin(A*3.14/z))),1,WHITE);//(控制圓心位置列0/127   控制圓心位置行0/63  )(控制大小=0+x )
  160.    }
  161.    }
  162.   //.畫sec時針線
  163.    display.drawLine((xo+(r*cos(a*3.14/z))),(yo+(r*sin(a*3.14/z))),xo,yo, WHITE);//(開始列127  開始行63)( 結束列127 結束行63) /////00
  164.   //.畫minute時針線
  165.    display.drawLine((xo+((r-2)*cos(b*3.14/z))),(yo+((r-2)*sin(b*3.14/z))),xo,yo, WHITE);//(開始列127  開始行63)( 結束列127 結束行63) /////00
  166.    //.畫hour時針線
  167.    display.drawLine((xo+((r-6)*cos(c*3.14/z))),(yo+((r-6)*sin(c*3.14/z))),xo,yo, WHITE);//(開始列127  開始行63)( 結束列127 結束行63) /////00
  168.
  169.    //7.畫實心圓//.畫sec時針線
  170.   display.fillCircle((xo+((r-4)*cos(a*3.14/z))),(yo+((r-4)*sin(a*3.14/z))),2,WHITE);//(控制圓心位置列0/127   控制圓心位置行0/63  )(控制大小=0+x )
  171.
  172.    //13.顯示英文
  173.   display.setTextSize(1);//設置字體大小
  174.   display.setTextColor(WHITE);//設置字體不反白
  175.   display.setCursor(xo-6,yo-29);//列127 行63     坐標
  176.   display.println("12");
  177.   display.setCursor(xo+22,yo-2);//列127 行63     坐標
  178.   display.println("3");
  179.   display.setCursor(xo-2,yo+22);//列127 行63     坐標
  180.   display.println("6");
  181.   display.setCursor(xo-27,yo-3);//列127 行63     坐標
  182.   display.println("9");
  183.
  184.
  185. // 17.顯示多個文字(在庫里面加入一個ShowCN_16方法  為了同時顯示多個中文 16X16 ,不然的話 就得一個一個drawBitmap)
  186.   display.ShowCN_16(0,40, bbjj_16x16,sizeof(bbjj_16x16)/32,WHITE);//查找數組法(控制位置列0/127   控制位置行0/63  )
  187.
  188.   display.setTextSize(3);
  189.   display.setTextColor(WHITE);
  190.
  191.   display.setCursor(0,17);
  192.   display.println((int)temperature);////溫度
  193.
  194.   display.setTextSize(1);
  195.   display.setTextColor(WHITE);
  196.    display.setCursor(0,5);
  197.   display.println((int)hour/10);////
  198.    display.setCursor(7,5);
  199.    display.println((int)hour%10);////
  200.    display.setCursor(18,5);
  201.   display.println((int)minute/10);////
  202.    display.setCursor(25,5);
  203.   display.println((int)minute%10);////
  204.   display.setCursor(37,5);
  205.   display.println((int)second/10);////
  206.    display.setCursor(44,5);
  207.   display.println((int)second%10);////
  208. display.drawPixel(15, 6, WHITE);// 列127 行63 畫點 點坐標
  209. display.drawPixel(15, 10, WHITE);// 列127 行63 畫點 點坐標
  210. display.drawPixel(33, 6, WHITE);// 列127 行63 畫點 點坐標
  211. display.drawPixel(33, 10, WHITE);// 列127 行63 畫點 點坐標
  212.    //11.畫空心圓角矩形
  213.   display.drawRoundRect(37,16,9,30,3,WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=列+x  結束大小=行+Y  控制圓角=+x)
  214.   //6.畫空心圓
  215.   display.fillCircle(41,50,7,WHITE);//(控制圓心位置列0/127   控制圓心位置行0/63  )(控制大小=0+x )
  216.   //5.畫個實心矩形
  217.   display.fillRect(39,(16+((60-temperature)/2)),5,30-(((60-temperature)/2)),WHITE);//(控制位置列0/127   控制位置行0/63  )(控制大小=列+x  結束大小=行+Y)//溫度
  218.   display.display();
  219.
  220.
  221. }
ID:358930 發表于 2018-7-14 12:11 來自觸屏版 | 只看該作者
//A4  SDA
//A5  SCL
//0X57   0X68
#include <DS3231.h>
#include <Wire.h>
DS3231 Clock;
bool Century=false;
bool h12;
bool PM;
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#endif
int x;//動畫變量
//顯示一個心形
void setup()   {
  delay(500);
Wire.begin();
         //改時間
void loop() {
     ReadDS3231();//讀取時間
   //2.畫點 點坐標(10,10)
  //5.畫個實心矩形
   //6.畫空心圓
  //7.畫實心圓
  //8.畫空心三角形
  //9.畫實心三角形
  //10.畫空心圓角矩形
//11.畫實心圓角矩形
//13.顯示英文
  //14.顯示數字變量
  display.println(x);
//15.顯示16進制變量
//6.畫空心圓
  //7.畫實心圓
   //不能用char型變量無法計算
  r=17;//指針半徑
  z=180;//圓
  //second=0;//調整
  // minute=0;//調整
   // hour=0;//調整
  int  hour1=hour;
   if(hour1>12)
{hour1=hour1-12;}
{hour1=hour1;}
  //.畫一圈實心圓
   int B;
     int A=B*30;//圓角度
  //.畫sec時針線
  //.畫minute時針線
   //.畫hour時針線
   //7.畫實心圓//.畫sec時針線
   //13.顯示英文
   //11.畫空心圓角矩形
  //6.畫空心圓
  //5.畫個實心矩形
  display.display();
ID:358930 發表于 2018-7-14 12:14 來自觸屏版 | 只看該作者
冰冰潔潔 發表于 2018-7-14 12:11
//A4  SDA
//A5  SCL
//0X57   0X68
上個圖,大家一起分享。
ID:219332 發表于 2018-7-30 11:01 來自觸屏版 | 只看該作者
謝謝,做的真漂亮
