查看: 2451|回復(fù): 1
智能燈控的單片機(jī)源碼
ID:369562 發(fā)表于 2018-7-11 16:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
【Realplay】 PCF8591模塊 ADDA轉(zhuǎn)換模塊 模數(shù)數(shù)模轉(zhuǎn)換送杜邦線.zip (625.18 KB, 下載次數(shù): 16)
畢業(yè)設(shè)計1.rar (15.14 MB, 下載次數(shù): 48)
家庭智能燈控系統(tǒng),人走斷電,根據(jù)環(huán)境調(diào)光,強(qiáng)制開關(guān)
不多說上程序
//主程序//
#include <REGX51.H>
uint cp1,cp2,cp3,cp4,cp5,sec=0,hour=0,min=0,a,b=16,pwm,sec1=0;
uint  intensity,infrard,AD1,AD2;
#include <AD.c>
#include <1602.c>
#include <key.c>
sbit LED=P2^1;
#include <display.c>
void timer_isr()interrupt 1
        TL0 = (65535-1000)%256;
    TH0 = (65535-1000)/256;
        cp1++;
        cp3++;
    if(cp3 > AD2)  pwm =1;
        if(cp3 <= AD2)  pwm =0;
           if(cp3 >= 25) cp3=0;
        if(cp1>=200)
                cp1=0;
                cp2++;
                if(cp2 == 1)
                        infrard =  read_pcf8591(0x40);
                if(cp2 == 4)
                        cp2=0;
                          sec++;
                        intensity = read_pcf8591(0x42);//光強(qiáng)
                        AD1= intensity*0.39;
                     AD2= intensity/10;
        if(sec>=60)
                 min++;
                 sec=0;
        if(min>=60)
                 min=0;
                 hour++;
        if(hour>=24) hour=0;
         if(mode == 0)
        if(infrard  >= 150)LED = pwm;
        else LED = 1;
        if(mode == 1)
                LED = 1;
void timer_init()
    TMOD |= 0x01;
    TR0 = 1;
    ET0 = 1;
    EA = 1;
//    uchar i;
    timer_init();
    init_24c04();
        init_1602();
        sec=0;
        hour=0;
        min=0;
                 key();
                 display();
//pcf8591AD轉(zhuǎn)換//
#include<intrins.h>
sbit scl = P1^1;
sbit sda = P1^0;
/*************起始信號**************/
//工作條件sda 產(chǎn)生下降沿 scl 為高電平;
void star_24c04 ()
        sda = 1;
        scl = 1;
        sda = 0;
        scl = 0;                                 //時鐘信號復(fù)位
/*************終止信號**************/
//終止條件sda數(shù)據(jù)信號產(chǎn)生下降沿 scl 時鐘信號為高電平
void stop_24c04()
        sda = 0;
        scl = 1;
        sda = 1;
/**************應(yīng)答信號**************/
void ack_24c04()
        uchar i= 255;
        scl = 1;
        while(sda && i--);
        scl = 0;
/**************I2C總線初始化*********/
void init_24c04(void)
        sda = 1;
        scl = 1;
/**************讀取一個字節(jié)**************/
uchar read_onebyte_24c04(void)
        uchar i ,dat;
        sda = 1;//釋放總線
        for(i = 0;i < 8;i++)
                scl = 1;
                dat = dat<<1;
                if(sda)dat = dat|0x01;//先讀取高位,放到dat 的低位;
                scl = 0;
        sda = 1;
        scl = 0;
        return (dat);
/*************寫入一個字節(jié)**************/
void write_onebyte_24c04(uchar dat)
        uchar i;
                sda = (bit)(dat & 0x80);
                dat = dat << 1;
                scl = 1;
                scl = 0;
        sda = 1;
        scl = 0;
//讀地址、數(shù)據(jù)函數(shù)
//0x40表示0號通道;0x41表示1號通道;
uchar read_pcf8591(uchar sh)
        uchar temp;
        star_24c04();                 //發(fā)出開始信號
        write_onebyte_24c04(0x90);//PCF8591地址  相當(dāng)于握手信號
        ack_24c04();                         //響應(yīng)
        write_onebyte_24c04(sh);//0x40表示0號通道;//0x43 滑變  //0x40  光敏 //0x41 熱敏
        star_24c04();                 //再次發(fā)出開始信號
        write_onebyte_24c04(0x91);//發(fā)出讀取對應(yīng)8951模塊AD的信號
        temp=read_onebyte_24c04();//讀取數(shù)據(jù)
        stop_24c04();                         //停止
        return(temp);         //返回數(shù)據(jù)
//1602時序//
sbit RS = P2^3;//數(shù)據(jù)/命令
sbit RW = P2^4;//讀/寫
sbit E  = P2^5;//使能
uchar i;
uchar num[] = {"0123456789"};
void delayus(uint x)  //延時函數(shù)
        while(x--);
void write_com(uchar com)//寫命令
        RW = 0;
        RS = 0;
        E = 1;
        P0 = com;
        delayus(100);
        E = 0;
void write_data(uchar da)//寫入數(shù)據(jù)
        RW = 0;
        RS = 1;
        E = 1;
        P0 = da;
        delayus(100);
        E = 0;
void init_1602()        //LCD1602  初始化
        write_com(0x3c);//設(shè)定數(shù)據(jù)總線的個數(shù)4/8,顯示一行/兩行
        write_com(0x0c);//          //光標(biāo)不顯示
        write_com(0x06);//           //光標(biāo)隨字符右移
//void LCD_clr1602()        //LCD1602  清屏
//        write_com(0x01);        // 對字符串清0
//        write_com(0x02);   //對光標(biāo)清0
void goto_xy(uchar y,uchar x)    //定位顯示位置
        if(y == 1)
                write_com(x + 0x80);                 //定位第一行
                write_com(x + 0x80 + 0x40);         //定位第二行
void display_num(unsigned char x)                 //顯示數(shù)字
        write_data(num[x / 10]);
        write_data(num[x % 10]);
void display_num1(unsigned int x)                 //顯示數(shù)字
        write_data(num[x / 100 % 10]);
        write_data(num[x / 10 % 10]);
void display_string(uchar *p)         //顯示字符
        while(*p)
                write_data(*p);
                p++;
//display//
void display()
        goto_xy(1,0);
        display_string("time ");
        goto_xy(1,6);
        display_num(hour);
        goto_xy(1,8);
        display_string(":");
        goto_xy(1,9);
        display_num(min);
        goto_xy(1,11);
    goto_xy(1,12);
        display_num(sec);
        goto_xy(2,0);
        display_string("Lx:");
        goto_xy(2,3);
         display_num1(AD1);
        goto_xy(2,6);
        display_string("%");
        goto_xy(2,8);
        if(infrard > 150)display_string("OPEN");
        else  display_string("OFF ");
ID:369562 發(fā)表于 2018-7-11 16:34 | 只看該作者
贊一個
