查看: 3428|回復(fù): 0
步進(jìn)電機(jī)轉(zhuǎn)速數(shù)碼管顯示
ID:350005 發(fā)表于 2018-7-10 22:04 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
#define DataPort P0 //定義數(shù)據(jù)端口 程序中遇到DataPort 則用P0 替換
sbit LATCH1=P2^2;//定義鎖存使能端口 段鎖存
sbit LATCH2=P2^3;//                 位鎖存
unsigned char code dofly_DuanMa[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};// 顯示段碼值0~9
unsigned char code dofly_WeiMa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//分別對應(yīng)相應(yīng)的數(shù)碼管點(diǎn)亮,即位碼
unsigned char TempData[8]; //存儲(chǔ)顯示值的全局變量
sbit A1=P1^0; //定義步進(jìn)電機(jī)連接端口
sbit B1=P1^1;
sbit C1=P1^2;
sbit D1=P1^3;
#define Coil_AB1 {A1=1;B1=1;C1=0;D1=0;}//AB相通電,其他相斷電
#define Coil_BC1 {A1=0;B1=1;C1=1;D1=0;}//BC相通電,其他相斷電
#define Coil_CD1 {A1=0;B1=0;C1=1;D1=1;}//CD相通電,其他相斷電
#define Coil_DA1 {A1=1;B1=0;C1=0;D1=1;}//D相通電,其他相斷電
#define Coil_A1 {A1=1;B1=0;C1=0;D1=0;}//A相通電,其他相斷電
#define Coil_B1 {A1=0;B1=1;C1=0;D1=0;}//B相通電,其他相斷電
#define Coil_C1 {A1=0;B1=0;C1=1;D1=0;}//C相通電,其他相斷電
#define Coil_D1 {A1=0;B1=0;C1=0;D1=1;}//D相通電,其他相斷電
#define Coil_OFF {A1=0;B1=0;C1=0;D1=0;}//全部斷電
unsigned char Speed;
void Display(unsigned char FirstBit,unsigned char Num);
void Init_Timer0(void);
uS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
unsigned char 是定義無符號(hào)字符變量,其值的范圍是
0~255 這里使用晶振12M,精確延時(shí)請使用匯編,大致延時(shí)
長度如下 T=tx2+5 uS
void DelayUs2x(unsigned char t)
while(--t);
mS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
void DelayMs(unsigned char t)
while(t--)
     //大致延時(shí)1mS
     DelayUs2x(245);
         DelayUs2x(245);
                    主函數(shù)
main()
unsigned int i=512;//旋轉(zhuǎn)一周時(shí)間
Init_Timer0();
EA=1;          //全局中斷開
EX0=1;         //外部中斷0開
IT0=1;         //1表示邊沿觸發(fā)
Speed=3;
TempData[0]=dofly_DuanMa[Speed/10];//分解顯示信息,如要顯示68,
TempData[1]=dofly_DuanMa[Speed%10];//則68/10=6  68%10=8
Coil_OFF
while(i--)  //正向
  {  Coil_A1
     DelayMs(Speed);
     Coil_AB1                 //遇到Coil_AB1  用{A1=1;B1=1;C1=0;D1=0;}代替
     DelayMs(Speed);         //改變這個(gè)參數(shù)可以調(diào)整電機(jī)轉(zhuǎn)速 ,
                             //數(shù)字越小,轉(zhuǎn)速越大,力矩越小
         Coil_B1
     DelayMs(Speed);
     Coil_BC1
     DelayMs(Speed);
         Coil_C1
     DelayMs(Speed);
     Coil_CD1
     DelayMs(Speed);
         Coil_D1
     DelayMs(Speed);
     Coil_DA1
     DelayMs(Speed);
                 外部中斷程序
void ISR_INT0(void) interrupt 0
if(!INT0)
   DelayMs(10);//在此處可以添加去抖動(dòng)程序,防止按鍵抖動(dòng)造成錯(cuò)誤
   if(!INT0)
   //while(!INT1);//等待按鍵釋放
     Speed++;
         if(Speed==20)
           Speed=3;
顯示函數(shù),用于動(dòng)態(tài)掃描數(shù)碼管
輸入?yún)?shù) FirstBit 表示需要顯示的第一位,如賦值2表示從第三個(gè)數(shù)碼管開始顯示
如輸入0表示從第一個(gè)顯示。
Num表示需要顯示的位數(shù),如需要顯示99兩位數(shù)值則該值輸入2
      static unsigned char i=0;
           DataPort=0;   //清空數(shù)據(jù),防止有交替重影
       LATCH1=1;     //段鎖存
       LATCH1=0;
       DataPort=dofly_WeiMa[i+FirstBit]; //取位碼
       LATCH2=1;     //位鎖存
       LATCH2=0;
       DataPort=TempData[i]; //取顯示數(shù)據(jù),段碼
       LATCH1=1;     //段鎖存
       LATCH1=0;
           i++;
       if(i==Num)
              i=0;
                    定時(shí)器初始化子程序
TMOD |= 0x01;          //使用模式1,16位定時(shí)器,使用"|"符號(hào)可以在使用多個(gè)定時(shí)器時(shí)不受影響
//TH0=0x00;              //給定初值
//TL0=0x00;
EA=1;            //總中斷打開
ET0=1;           //定時(shí)器中斷打開
TR0=1;           //定時(shí)器開關(guān)打開
PT0=1;           //優(yōu)先級(jí)打開
                 定時(shí)器中斷子程序
void Timer0_isr(void) interrupt 1
TH0=(65536-2000)/256;                  //重新賦值 2ms
TL0=(65536-2000)%256;
Display(0,8);
參與人數(shù) 1黑幣 +50 收起 理由
