#include <reg52.h> #include <intrins.h> // 包含頭文件 #define uint unsigned int #define uchar unsigned char #define ulong unsigned long //宏定義 #define LCD_DATA P0 //定義P0口為LCD_DATA sbit LCD_RS =P2^5; sbit LCD_RW =P2^6; sbit LCD_E =P2^7; //定義LCD控制引腳 sbit Xintiao =P3^2 ; //脈搏檢測輸入端定義 sbit speaker =P2^4; //蜂鳴器引腳定義 void delay5ms(void); //誤差 0us void LCD_WriteData(uchar LCD_1602_DATA); /********LCD1602數(shù)據(jù)寫入***********/ void LCD_WriteCom(uchar LCD_1602_COM); /********LCD1602命令寫入***********/ void lcd_1602_word(uchar Adress_Com,ucharNum_Adat,uchar *Adress_Data); /*1602字符顯示函數(shù),變量依次為字符顯示首地址,顯示字符長度,所顯示的字符*/ void InitLcd();//液晶初始化函數(shù) void Tim_Init(); uchar Xintiao_Change=0; // uint Xintiao_Jishu; uchar stop; uchar View_Data[3]; uchar View_L[3]; uchar View_H[3]; uchar Xintiao_H=100; //脈搏上限 uchar Xintiao_L=40; //脈搏下限 uchar Key_Change; uchar Key_Value; //按鍵鍵值 uchar View_Con; //設置的位(0正常工作,1設置上限,2設置下限) uchar View_Change; void main() //主函數(shù) { InitLcd(); Tim_Init(); lcd_1602_word(0x80,16,"HeartRate: "); //初始化顯示 TR0=1; TR1=1; //打開定時器 while(1) //進入循環(huán) { if(Key_Change) //有按鍵按下并已經(jīng)得出鍵值 { Key_Change=0; //將按鍵使能變量清零,等待下次按鍵按下 View_Change=1; switch(Key_Value) //判斷鍵值 { case 1: //設置鍵按下 { View_Con++; //設置的位加 if(View_Con>=3) //都設置好后將此變量清零 View_Con=0; break; //跳出,下同 } case 2: //加鍵按下 { if(View_Con==2) //判斷是設置上限 { if(Xintiao_H<150) //上限數(shù)值小于150 Xintiao_H++; //上限+ } if(View_Con==1) //如果是設置下限 { if(Xintiao_L<Xintiao_H)//下限值小于上限(下限值不能超過上限) Xintiao_L++; //下限值加 } break; } case 3: //減鍵按下 { if(View_Con==2) //設置上限 { if(Xintiao_H>Xintiao_L)//上限數(shù)據(jù)大于下限(同樣上限值不能小于下限) Xintiao_H--; //上限數(shù)據(jù)減 } if(View_Con==1) //設置下限 { if(Xintiao_L>30) //下限數(shù)據(jù)大于30時 Xintiao_L--; //下限數(shù)據(jù)減 } break; } } } if(View_Change)//顯示變量 { View_Change=0;//變量清零 if(stop==0) //心率正常時 { if(View_Data[0]==0x30) //最高位為0時不顯示 View_Data[0]=' '; } else //心率不正常(計數(shù)超過5000,也就是兩次信號時間超過5s)不顯示數(shù)據(jù) { View_Data[0]=' '; View_Data[1]=' '; View_Data[2]=' '; } switch(View_Con) { case 0: //正常顯示 { lcd_1602_word(0x80,16,"HeartRate: ");//顯示一行數(shù)據(jù) lcd_1602_word(0xc0,16," ");//顯示第二行數(shù)據(jù) lcd_1602_word(0xcd,3,View_Data); //第二行顯示心率 break; } case 1: //設置下限時顯示 { lcd_1602_word(0x80,16,"HeartRate: ");//第一行顯示心率 lcd_1602_word(0x8d,3,View_Data);
View_L[0]=Xintiao_L/100+0x30; //將下限數(shù)據(jù)拆字 View_L[1]=Xintiao_L%100/10+0x30; View_L[2]=Xintiao_L%10+0x30;
if(View_L[0]==0x30) //最高位為0時,不顯示 View_L[0]='';
lcd_1602_word(0xC0,16,"WarningL : ");//第二行顯示下限數(shù)據(jù) lcd_1602_word(0xCd,3,View_L); break; } case 2: //設置上限時顯示(同上) { lcd_1602_word(0x80,16,"HeartRate: "); lcd_1602_word(0x8d,3,View_Data);
View_H[0]=Xintiao_H/100+0x30; View_H[1]=Xintiao_H%100/10+0x30; View_H[2]=Xintiao_H%10+0x30;
if(View_H[0]==0x30) View_H[0]='';
lcd_1602_word(0xC0,16,"WarningH : "); lcd_1602_word(0xCd,3,View_H); break; } } } } } void Time1() interrupt 3 //定時器1服務函數(shù) { staticuchar Key_Con,Xintiao_Con; TL1=0xd8; //10ms TH1=0xf0; //重新賦初值 switch(Key_Con) //無按鍵按下時此值為0 { case 0: //每10ms掃描此處 { if((P1&0xf7)!=0xf7)//掃描按鍵是否有按下 { Key_Con++; //有按下此值加1,值為1 } break; } case 1: //10ms后二次進入中斷后掃描此處(Key_Con為1) { if((P1&0xf7)!=0xf7)//第二次進入中斷時,按鍵仍然是按下(起到按鍵延時去抖的作用) { Key_Con++; //變量加1,值為2 switch(P1&0xf7) //判斷是哪個按鍵按下 { case0x06:Key_Value=1;break; //判斷好按鍵后將鍵值賦值給變量Key_Value case0x05:Key_Value=2;break; case0x03:Key_Value=3;break; } } else //如果10ms時沒有檢測到按鍵按下(按下時間過短) { Key_Con=0; //變量清零,重新檢測按鍵 } break; } case 2: //20ms后檢測按鍵 { if((P1&0xf7)==0xf7) //檢測按鍵是否還是按下狀態(tài) { Key_Change=1; //有按鍵按下使能變量,(此變量為1時才會處理鍵值數(shù)據(jù)) Key_Con=0; //變量清零,等待下次有按鍵按下 } break; } } switch(Xintiao_Con)//此處與上面按鍵的檢測類似 { case 0: //默認Xintiao_Con是為0的 { if(!Xintiao)//每10ms(上面的定時器)檢測一次脈搏是否有信號 { Xintiao_Con++;//如果有信號,變量加一,程序就會往下走了 } break; } case 1: { if(!Xintiao) //每過10ms檢測一下信號是否還存在 { Xintiao_Con++;//存在就加一 } else { Xintiao_Con=0;//如果不存在了,檢測時間很短,說明檢測到的不是脈搏信號,可能是其他干擾,將變量清零,跳出此次檢測 } break; } case 2: { if(!Xintiao) { Xintiao_Con++;//存在就加一 } else { Xintiao_Con=0;//如果不存在了,檢測時間很短,說明檢測到的不是脈搏信號,可能是其他干擾,將變量清零,跳出此次檢測 } break; } case 3: { if(!Xintiao) { Xintiao_Con++;//存在就加一 } else { Xintiao_Con=0;//如果不存在了,檢測時間很短,說明檢測到的不是脈搏信號,可能是其他干擾,將變量清零,跳出此次檢測 } break; } case 4: { if(Xintiao)//超過30ms一直有信號,判定此次是脈搏信號,執(zhí)行以下程序 { if(Xintiao_Change==1)//心率計原理為檢測兩次脈沖間隔時間計算心率,變量Xintiao_Change第一次脈沖時為0的,所有走下面的else,第二次走這里 { if(60000/Xintiao_Jishu>200) { View_Data[0]='-'; View_Data[1]='-'; View_Data[2]='-'; speaker=1; //不響 } else { View_Data[0]=(60000/Xintiao_Jishu)/100+30; //計算心跳并拆字顯示:心跳計時是以1ms為單位,兩次心跳中間計數(shù)如果是1000次,也就是1000*1ms=1000ms=1s View_Data[1]=(60000/Xintiao_Jishu)%100/10+30; //那么計算出的一分鐘(60s)心跳數(shù)就是:60*1000/(1000*1ms)=60次 其中60是一分鐘60s,1000是一秒有1000ms,1000是計數(shù)值,1是一次計數(shù)對應的時間是1ms View_Data[2]=(60000/Xintiao_Jishu)%10+30; //計算出的心跳數(shù)/100得到心跳的百位,%100是取余的,就是除以100的余數(shù),再除以10就得到十位了,以此類推 //鹱趾蟮牡ジ鍪?0x30的目的是得到對應數(shù)字的液晶顯示碼,數(shù)字0對應的液晶顯示碼是0x30,1是0x30+1,以此類推 if(((60000/Xintiao_Jishu)>=Xintiao_H)||((60000/Xintiao_Jishu)<=Xintiao_L))//心率不在范圍內報警 speaker=0; //蜂鳴器響 else speaker=1; //不響 }
View_Change=1; //計算出心率后啟動顯示 Xintiao_Jishu=0; //心跳計數(shù)清零 Xintiao_Change=0; //計算出心率后該變量清零,準備下次檢測心率 stop=0; //計算出心率后stop邈 } else//第一次脈沖時Xintiao_Change為0 { Xintiao_Jishu=0; //脈沖計時變量清零,開始計時 Xintiao_Change=1;//Xintiao_Change置1,準備第二次檢測到脈沖時計算心率 } Xintiao_Con=0; //清零,準備檢測下一次脈沖 break; } } } } /**定時器T0工作函數(shù)**/ void Time0() interrupt 1 { TL0=0xfc; //1ms TH0=0x18; //重新賦初值 Xintiao_Jishu++; //心跳計數(shù)加 if(Xintiao_Jishu==5000)//心跳計數(shù)大于5000 { Xintiao_Jishu=0; //數(shù)據(jù)清零 View_Change=1; //顯示位置1 Xintiao_Change=0; //置零,準備再次檢測 stop=1; //心跳計數(shù)超過5000后說明心率不正;蛘邲]有測出,stop置1 speaker=1; //關閉蜂鳴器 } } /**定時器初始化函數(shù)**/ void Tim_Init() { EA=1; //打開中斷總開關 ET0=1; //打開T0中斷允許開關 ET1=1; //打開T1中斷允許開關 TMOD=0x11; //設定定時器狀態(tài) TL0=0xfc; //1ms TH0=0x18; //賦初值
TL1=0xd8; //10ms TH1=0xf0; //賦初值 } /**在指定地址顯示指定數(shù)量的指定字符**/ /**Adress_Com顯示地址,Num_Adat顯示字符數(shù)量,Adress_Data顯示字符串內容**/ void lcd_1602_word(uchar Adress_Com,ucharNum_Adat,uchar *Adress_Data) { uchara=0; ucharData_Word; LCD_WriteCom(Adress_Com);//選中地址 for(a=0;a<Num_Adat;a++) //for循環(huán)決定顯示字符個數(shù) { Data_Word=*Adress_Data; //讀取字符串數(shù)據(jù) LCD_WriteData(Data_Word); //顯示字符串 Adress_Data++; //顯示地址加一 } } /***************1602函數(shù)*******************/ void LCD_WriteData(uchar LCD_1602_DATA) /********LCD1602數(shù)據(jù)寫入***********/ { delay5ms(); //操作前短暫延時,保證信號穩(wěn)定 LCD_E=0; LCD_RS=1; LCD_RW=0; _nop_(); LCD_E=1; LCD_DATA=LCD_1602_DATA; LCD_E=0; LCD_RS=0; } /********LCD1602命令寫入***********/ void LCD_WriteCom(uchar LCD_1602_COM) { delay5ms();//操作前短暫延時,保證信號穩(wěn)定 LCD_E=0; LCD_RS=0; LCD_RW=0; _nop_(); LCD_E=1; LCD_DATA=LCD_1602_COM; LCD_E=0; LCD_RS=0; } void InitLcd() //初始化液晶函數(shù) { delay5ms(); delay5ms(); LCD_WriteCom(0x38);//display mode LCD_WriteCom(0x38);//display mode LCD_WriteCom(0x38);//display mode LCD_WriteCom(0x06);//顯示光標移動位置 LCD_WriteCom(0x01);//顯示清屏 LCD_WriteCom(0x0c);//顯示開及光標設置 delay5ms(); delay5ms(); } void delay5ms(void) //5ms延時函數(shù) { unsignedchar a,b; for(b=185;b>0;b--) for(a=12;a>0;a--); }
