#include <reg51.h>
#include "intrins.h"
#define uint unsigned int //宏定義
#define uchar unsigned char //宏定義
uchar i=0,j=0,k=0, s=1,f=1,m=0,a[9]; //定義變量
sbit K4=P1^3; //位定義
sbit K5 =P1^4; //位定義
sbit fmq =P3^6; //位定義
sbit DQ=P3^3; //溫度輸入口
sbit DIN=P0^7;
uint h;
uint temp;
uint num;
uint numc;
//uchar code sz[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf} ; //數(shù)字編碼表
//uchar code xw[]={ 0xff,0xfe,0xfd,0xfb,0xf7, //選位編碼表
//0xef,0xdf,0xbf,0x7f
//**************溫度小數(shù)部分用查表法***********//
uchar code ditab[16]=
{0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x04,0x05,0x06,0x06,0x07,0x08,0x08,0x09,0x09};
uchar code dis_7[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0xbf};
//共陽LED段碼表 "0" "1" "2" "3" "4" "5" "6" "7" "8" "9" "不亮" "-"
uchar code scan_con[8]={0xf7,0xfb,0xfd,0xfe,0xef,0xdf,0xbf,0x7f}; //列掃描控制字
uchar data temp_data[2]={0x00,0x00}; //讀出溫度暫放
uchar data display[10]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}; //顯示單元數(shù)據(jù),共4個數(shù)據(jù)和一個運(yùn)算暫用
//uchar data display1[5]={};
void pf() //區(qū)分出個位和十位
a[1]=s/10;
a[2]=s%10;
a[3]=11;
a[4]=f/10;
a[5]=f%10;
a[6]=11;
a[7]=m/10;
a[8]=m%10;
/*****************11us延時函數(shù)*************************/
void delay(uint t)
for (;t>0;t--);
/*****************延時函數(shù)***********************/
void ys ( int d )
int b ,c ;
for (b = d;b>0;b--)
for (c=110;c>0;c--) ;
//****************1ms基準(zhǔn)延時程序
void delay1ms(uint i)
uchar j;
while(i--)
for(j=0;j<115;j++)
/************500us基準(zhǔn)延時程序 ******************/
void delay500us()
unsigned char j;
for(j=0;j<57;j++)
/****************顯示掃描函數(shù)***************************/
void scan()
uchar k;
display[4]=num/1000;
display[5]=num/100-display[4]*100;
display[6]=num/10-display[5]*10;
display[7]=num-display[5]*100-display[6]*10;
numc=display[2]*100+display[1]*10+display[0];
for(k=0;k<8;k++) //4位LED掃描控制
P0=dis_7[display[k]]; //數(shù)據(jù)顯示
if ((k==1)||(6==k))
{DIN=0;} //小數(shù)點(diǎn)顯示
P2=scan_con[k]; //位選
delay(100);
void xs(uint k)
{ uint i;
for(i=0;i<k;i++)
scan();
/***********產(chǎn)生1KHZ頻率聲音的函數(shù) /****************/
void beep()
fmq=0;
delay500us();
fmq=1;
/****************DS18B20復(fù)位函數(shù)************************/
void ow_reset(void)
char presence=1;
while(presence)
while(presence)
DQ=1;_nop_();_nop_();//從高拉倒低
DQ=0;
delay(50); //550 us
DQ=1;
delay(6); //66 us
presence=DQ; //presence=0 復(fù)位成功,繼續(xù)下一步
delay(45); //延時500 us
presence=~DQ;
DQ=1; //拉高電平
/****************DS18B20寫命令函數(shù)************************/
//向1-WIRE 總線上寫1個字節(jié)
void write_byte(uchar val)
uchar i;
for(i=8;i>0;i--)
DQ=1;_nop_();_nop_(); //從高拉倒低
DQ=0;_nop_();_nop_();_nop_();_nop_(); //5 us
DQ=val&0x01; //最低位移出
delay(6); //66 us
val=val/2; //右移1位
DQ=1;
delay(1);
/****************DS18B20讀1字節(jié)函數(shù)************************/
//從總線上取1個字節(jié)
uchar read_byte(void)
uchar i;
uchar value=0;
for(i=8;i>0;i--)
value>>=1;
DQ=0;_nop_();_nop_();_nop_();_nop_(); //4 us
DQ=1;_nop_();_nop_();_nop_();_nop_(); //4 us
if(DQ)value|=0x80;
delay(6); //66 us
DQ=1;
return(value);
/****************讀出溫度函數(shù)************************/
read_temp()
ow_reset(); //總線復(fù)位
delay(200);
write_byte(0xcc); //發(fā)命令
write_byte(0x44); //發(fā)轉(zhuǎn)換命令
ow_reset();
delay(1);
write_byte(0xbe);
temp_data[0]=read_byte(); //讀溫度值的第字節(jié)
temp_data[1]=read_byte(); //讀溫度值的高字節(jié)
temp=temp_data[1];
temp<<=8;
temp=temp|temp_data[0]; // 兩字節(jié)合成一個整型變量。
return temp; //返回溫度值
/****************溫度數(shù)據(jù)處理函數(shù)************************/
//二進(jìn)制高字節(jié)的低半字節(jié)和低字節(jié)的高半字節(jié)組成一字節(jié),這個
//字節(jié)的二進(jìn)制轉(zhuǎn)換為十進(jìn)制后,就是溫度值的百、十、個位值,而剩
//下的低字節(jié)的低半字節(jié)轉(zhuǎn)化成十進(jìn)制后,就是溫度值的小數(shù)部分
void work_temp(uint tem)
uchar n=0;
if(tem>6348) // 溫度值正負(fù)判斷
{tem=65536-tem;n=1;} // 負(fù)溫度求補(bǔ)碼,標(biāo)志位置1
display[4]=tem&0x0f; // 取小數(shù)部分的值
display[0]=ditab[display[4]]; // 存入小數(shù)部分顯示值
display[4]=tem>>4; // 取中間八位,即整數(shù)部分的值
display[3]=display[4]/100; // 取百位數(shù)據(jù)暫存
display[1]=display[4]%100; // 取后兩位數(shù)據(jù)暫存
display[2]=display[1]/10; // 取十位數(shù)據(jù)暫存
display[1]=display[1]%10;
/******************符號位顯示判斷**************************/
if(!display[3])
display[3]=0x0a; //最高位為0時不顯示
if(!display[2])
display[2]=0x0a; //次高位為0時不顯示
if(n){display[3]=0x0b;} //負(fù)溫度時最高位顯示"-"
/*************顯視函數(shù)*************/
void szxs()
{ uint jj;
pf() ;
for (k=1;k<=8;k++)
if(k<5)
{jj=4-k;}
jj=k-1;
P2=scan_con[jj];
P0=dis_7[a[k]];
ys(3);
void dczd() interrupt 1 //定時中斷
TH0=(65535-50000)/256;
TL0=(65535-50000)%256;
i++;
if (i==20)
i=0;
m++;
if (m==60)
m=0;
f++;
if (f==60)
f=0;
s++;
if (s==24)
s=0;
void cs() //初始函數(shù)
TMOD=0x01; //設(shè)置為定時工作方式
TH0=(65535-50000)/256; //定時器裝初值
TL0=(65535-50000)%256; //定時器裝初值
EA=1; //打開總中斷
ET0=1; //打開定時中斷
TR0=1; //起用定時器
//P3=0X00;
void szxs1(uint t)
uint a;
for(a=0;a<t;a++)
{szxs();
void shizhong()
szxs1(1);
if(( K4==0)&&(0!=K5))
szxs1(2);
if( ( K4==0)&&(0!=K5))
szxs1(10);
s++;
s%=24;
if(( K5==0)&&(0!=K4))
szxs1(2);
szxs1(10);
f++;
f%=60;
void cw()
work_temp(read_temp()); //處理溫度數(shù)據(jù)
scan();
if(( K5==0)&&(0!=K4)) //上限+
//delay1ms(15);
xs(3); //用顯示程序延時,下同
num=num+1;
//while(!K5);
xs(14);
if(( K4==0)&&(0!=K5)) //上限-
//delay1ms(15);
xs(3);
num=num-1;
//while(!K4);
xs(14);
if(numc>num)
beep();
} //顯示溫度值
void main ()
uint b=0;
cs();
num=300;
P0=0xff; //初始化端口
P2=0xff;
for(h=0;h<4;h++) //開機(jī)顯示"0000"
{display[h]=0;}
ow_reset(); //開機(jī)先轉(zhuǎn)換一次
write_byte(0xcc); //Skip ROM
xs(20); //開機(jī)顯示"00000300"
for(b=0;b<200;b++)
shizhong();
for(b=0;b<200;b++)
cw();
