15W4K58S4單片機ADC鍵盤控制數碼管顯示鍵值的工程源碼,用keil打開即可
- #define MAIN_Fosc 22118400L //定義主時鐘
- #include "STC15Fxxxx.H"
- #define Timer0_Reload (65536UL -(MAIN_Fosc / 2000)) //Timer 0 中斷頻率, 1000次/秒
- u8 code t_display[]={ //標準字庫
- // 0 1 2 3 4 5 6 7 8 9 A B C D E F
- 0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71,
- //black - H J K L N o P U t G Q r M y
- 0x00,0x40,0x76,0x1E,0x70,0x38,0x37,0x5C,0x73,0x3E,0x78,0x3d,0x67,0x50,0x37,0x6e,
- 0xBF,0x86,0xDB,0xCF,0xE6,0xED,0xFD,0x87,0xFF,0xEF,0x46}; //0. 1. 2. 3. 4. 5. 6. 7. 8. 9. -1
- u8 code T_COM[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //位碼
- sbit P_HC595_SER = P4^0; //pin 14 SER data input
- sbit P_HC595_RCLK = P5^4; //pin 12 RCLk store (latch) clock
- sbit P_HC595_SRCLK = P4^3; //pin 11 SRCLK Shift data clock
- u8 LED8[8]; //顯示緩沖
- u8 display_index; //顯示位索引
- bit B_1ms; //1ms標志
- u8 ADC_KeyState,ADC_KeyState1,ADC_KeyState2,ADC_KeyState3; //鍵狀態
- u8 ADC_KeyHoldCnt; //鍵按下計時
- u8 KeyCode; //給用戶使用的鍵碼, 1~16有效
- u8 cnt10ms;
- void CalculateAdcKey(u16 adc);
- u16 Get_ADC10bitResult(u8 channel); //channel = 0~7
- void DisplayScan();
- void main(void)
- u16 j;
- u16 i;
- P0M1 = 0; P0M0 = 0; //設置為準雙向口
- P1M1 = 0; P1M0 = 0; //設置為準雙向口
- P2M1 = 0; P2M0 = 0; //設置為準雙向口
- P3M1 = 0; P3M0 = 0; //設置為準雙向口
- P4M1 = 0; P4M0 = 0; //設置為準雙向口
- P5M1 = 0; P5M0 = 0; //設置為準雙向口
- P6M1 = 0; P6M0 = 0; //設置為準雙向口
- P7M1 = 0; P7M0 = 0; //設置為準雙向口
- display_index = 0;
- P1ASF = 0x10; //P1.4做ADC
- ADC_CONTR = 0xE0; //90T,90個周期轉換一次, ADC power on,ADC電源打開
- AUXR = 0x80; //Timer0 set as 1T, 16 bits timer auto-reload,
- ET0 = 1; //Timer0 interrupt enable
- TR0 = 1; //Tiner0 run
- EA = 1; //打開總中斷
- ADC_KeyState = 0;
- ADC_KeyState1 = 0;
- ADC_KeyState2 = 0;
- ADC_KeyState3 = 0; //鍵狀態
- ADC_KeyHoldCnt = 0;
- KeyCode = 0; //鍵碼 1~16有效
- cnt10ms = 0;
- for(i=0;i<8;i++)
- LED8[i] = 0x10;
- while(1)
- DisplayScan();
- if(B_1ms) //1ms到
- B_1ms = 0;
- j=Get_ADC10bitResult(4);
- CalculateAdcKey(j);
- if(KeyCode > 0) //有鍵按下
- LED8[6] = KeyCode / 10; //顯示鍵碼
- LED8[7] = KeyCode % 10; //顯示鍵碼
- KeyCode = 0;
- u16 Get_ADC10bitResult(u8 channel) //channel = 0~7
- ADC_RES = 0; //ADC結果高位寄存器
- ADC_RESL = 0; //ADC結果低位寄存器
- ADC_CONTR = (ADC_CONTR & 0xe0) | 0x08 | channel; //start the ADC,將P1.4引腳作為內部ADC模塊采樣輸入
- NOP(4);
- while((ADC_CONTR & 0x10) == 0) ; //wait for ADC finish,如果adc轉換你未完成,就空操作,轉換完成就執行下一句
- ADC_CONTR &= ~0x10; //清除ADC結束標志,就是讓adc轉換不結束,一直處于運行狀態
- return (((u16)ADC_RES << 2) | (ADC_RESL & 3)); //10位ADC結果,取ADC_RES的八位和ADC_RESL的低兩位
- #define ADC_OFFSET 16
- u8 i;
- u16 j;
- if(adc < (64-ADC_OFFSET)) //判斷無鍵按下,然后讓鍵狀態歸0
- ADC_KeyState = 0; //鍵狀態歸0
- j = 64; //鍵值1所對應的ADC值
- for(i=1; i<=16; i++) //讓i值輪詢去判斷鍵值i
- if((adc >= (j - ADC_OFFSET)) && (adc <= (j + ADC_OFFSET))) break; //判斷是否在偏差范圍內
- j += 64;
- ADC_KeyState3 = ADC_KeyState2;
- ADC_KeyState2 = ADC_KeyState1;
- if(i > 16) ADC_KeyState1 = 0; //鍵無效
- else //鍵有效
- ADC_KeyState1 = i;
- if((ADC_KeyState3 == ADC_KeyState2) && (ADC_KeyState2 == ADC_KeyState1) &&
- (ADC_KeyState3 > 0) && (ADC_KeyState2 > 0) && (ADC_KeyState1 > 0))
- if(ADC_KeyState == 0) //第一次檢測到
- KeyCode = i; //保存鍵碼
- ADC_KeyState = i; //保存鍵狀態
- if(ADC_KeyState == i) //連續檢測到同一鍵按著
- if(++ADC_KeyHoldCnt >= 100) //按下1秒后,以10次每秒為周期的速度Repeat Key
- ADC_KeyHoldCnt = 90;
- else ADC_KeyHoldCnt = 0; //按下時間計數歸0
- /**************** 向HC595發送一個字節函數 ******************/
- void Send_595(u8 dat)
- u8 i;
- for(i=0; i<8; i++)
- dat <<= 1;
- P_HC595_SER = CY;
- P_HC595_SRCLK = 1;
- P_HC595_SRCLK = 0;
- /********************** 顯示掃描函數 ************************/
- void DisplayScan(void)
- Send_595(~T_COM[display_index]); //輸出位碼
- Send_595(t_display[LED8[display_index]]); //輸出段碼
- P_HC595_RCLK = 1;
- P_HC595_RCLK = 0; //鎖存輸出數據
- if(++display_index >= 8) display_index = 0; //8位結束回0
- /********************** Timer0 1ms中斷函數 ************************/
- void timer0 (void) interrupt TIMER0_VECTOR
- B_1ms = 1; //1ms標志
ad.zip
(44.6 KB, 下載次數: 21)
2018-7-9 11:24 上傳
工程原碼
