一個關于電子秤的畢業設計程序 1602矩陣鍵盤+ADC0832。大家可以參考
附件里面有原理圖
- #include<reg52.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define BUSY 0x80 //常量定義
- #define DATAPORT P0
- #define ADCOFFSET 12
- #define GAIN 17.857
- //ADC0832的引腳
- sbit ADCS =P2^4; //ADC0832 chip seclect
- sbit ADDI =P2^0; //ADC0832 k in
- sbit ADDO =P2^1; //ADC0832 k out
- sbit ADCLK =P2^2; //ADC0832 clock signal
- sbit LCM_RS=P2^7;
- sbit LCM_RW=P2^6;
- sbit LCM_EN=P2^5;
- sbit KEY_IN_1 = P1^7;
- sbit KEY_IN_2 = P1^6;
- sbit KEY_IN_3 = P1^5;
- sbit KEY_IN_4 = P1^4;
- sbit KEY_OUT_1 = P1^0;
- sbit KEY_OUT_2 = P1^1;
- sbit KEY_OUT_3 = P1^2;
- sbit KEY_OUT_4 = P1^3;
- char TestModeFlag = 0; //實驗模式選項,單臂 半橋 全橋 0 1 2
- char WeigherModeflag = 0;
- char TestOrWeigher = 0;
- char IsExistPoint = 0;
- char IsInput = 0;
- char InputIndex = 0;
- char ShowWigherFlag = 0;
- unsigned char PriceArray[5] = {'0','0','0','0','0'};
- float voltage = 0;
- float weight = 123.4;
- float UnitPrice = 0;
- float TotalPrice = 0;
- float Shelling = 0;
- float K_D = 0.1764;
- float K_B = 0.3805;
- float K_Q = 0.7541;
- float B_D = 0.3636;
- float B_B = -0.4091;
- float B_Q = -0.1364;
- long ad_data;
- unsigned long AD_Sum = 0;
- unsigned long TimerCnt =0;
- sbit Beep =P3^2; //超過重量表量程最大值紅色led報警定義
- unsigned char AlarmFlag = 0;
- //adc采樣值存儲單元
- unsigned char KeySta[4][4] = {
- {1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}
- unsigned char code KeyCodeMap[4][4] = { //矩陣按鍵編號到標準鍵盤鍵碼的映射表
- { 0x01, 0x02, 0x03, 'U' }, //數字鍵1、數字鍵2、數字鍵3、向上鍵
- { 0x04, 0x05, 0x06, 'D' }, //數字鍵4、數字鍵5、數字鍵6、向下鍵
- { 0x07, 0x08, 0x09, 'E' }, //數字鍵7、數字鍵8、數字鍵9、向下鍵
- { 0x00, '.', 'L', 'R' } //數字鍵0、ESC鍵、 回車鍵、 向右鍵
- void KeyDriver();
- void Showfolat_1(uchar X,uchar Y,float num);
- void Showfolat_2(uchar X,uchar Y,float num);
- void delay(uint);
- void lcd_wait(void);
- void delay_LCM(uint); //LCD延時子程序
- void initLCM( void); //LCD初始化子程序
- void lcd_wait(void); //LCD檢測忙子程序
- void WriteCommandLCM(uchar WCLCM,uchar BusyC); //寫指令到ICM子函數
- void WriteDataLCM(uchar WDLCM); //寫數據到LCM子函數
- void DisplayOneChar(uchar X,uchar Y,uchar DData); //顯示指定坐標的一個字符子函數
- void DisplayListChar(uchar X,uchar Y,uchar code *DData); //顯示指定坐標的一串字符子函數
- void WeigherModeDisplay();
- void TestModeDisplay();
- //系統顯示子函數
- uchar Adc0832(unsigned char channel);
- void alarm(void);
- /**********main funcation************/
- void main(void)
- int i = 0;
- Beep = 0;
- EA = 1; //使能總中斷
- TMOD = 0x11; //設置T0為模式1
- TH0 = 0xF8; //為T0賦初值0xFC67,定時2ms
- TL0 = 0x2F;
- ET0 = 1; //使能T0中斷
- TR0 = 1; //啟動T0
- TH1 = 0x27; //為T1賦初值0xFC67,定時50ms
- TL1 = 0x10;
- ET1 = 1; //使能T1中斷
- TR1 = 1; //啟動T1
- Beep = 0;
- delay(500); //系統延時500ms啟動
- ad_data=0; //采樣值存儲單元初始化為0
- initLCM( );
- Beep = 0;
- WriteCommandLCM(0x01,1); //清顯示屏
- //DisplayListChar(0,0,str0);
- WriteCommandLCM(0x01,0);
- //DisplayListChar(0,1,str2);
- Beep = 0;
- while(1)
- ad_data = 0;
- for(i=0;i<400;i++)
- ad_data += Adc0832(0); //采樣值存儲單元初始化為0
- ad_data/=400;
- voltage = ad_data;
- //voltage = 1000*ad_data*5.0/255.0/GAIN;
- //voltage = (ad_data*5.0/255.0)*1000.0/GAIN;
- if(TestOrWeigher==0)
- TestModeDisplay();
- delay(1);
- Beep = 0;
- DisplayOneChar(14,1,' ');
- DisplayOneChar(15,1,' ');
- }else if(TestOrWeigher==1)
- WeigherModeDisplay();
- alarm();
- delay(1);
- //KeyDriver();
- // DisplayOneChar(0,0,ad_data/100+'0');
- // DisplayOneChar(1,0,ad_data/10%10+'0');
- // DisplayOneChar(2,0,ad_data%10+'0');
- // delay(500);
- /*********延時K*1ms,12.000Mhz**********/
- void delay(uint k)
- uint i,j;
- for(i=0;i<k;i++)
- for(j=0;j<60;j++);
- /**********寫指令到ICM子函數************/
- if(BusyC)
- lcd_wait();
- DATAPORT=WCLCM;
- LCM_RS=0; // 選中指令寄存器
- LCM_RW=0; // 寫模式
- LCM_EN=1;
- _nop_();
- _nop_();
- _nop_();
- LCM_EN=0;
- /**********寫數據到LCM子函數************/
- lcd_wait( ); //檢測忙信號
- DATAPORT=WDLCM;
- LCM_RS=1; // 選中數據寄存器
- LCM_RW=0; // 寫模式
- LCM_EN=1;
- _nop_();
- _nop_();
- _nop_();
- LCM_EN=0;
- /***********lcm內部等待函數*************/
- DATAPORT=0xff; //讀LCD前若單片機輸出低電平,而讀出LCD為高電平,則沖突,Proteus仿真會有顯示邏輯黃色
- LCM_EN=1;
- LCM_RS=0;
- LCM_RW=1;
- _nop_();
- _nop_();
- _nop_();
- while(DATAPORT&BUSY)
- { LCM_EN=0;
- _nop_();
- _nop_();
- LCM_EN=1;
- _nop_();
- _nop_();
- LCM_EN=0;
- /**********LCM初始化子函數***********/
- void initLCM( )
- DATAPORT=0;
- delay(15);
- WriteCommandLCM(0x38,0); //三次顯示模式設置,不檢測忙信號
- delay(5);
- delay(5);
- delay(5);
- WriteCommandLCM(0x38,1); //8bit數據傳送,2行顯示,5*7字型,檢測忙信號
- WriteCommandLCM(0x08,1); //關閉顯示,檢測忙信號
- WriteCommandLCM(0x01,1); //清屏,檢測忙信號
- WriteCommandLCM(0x06,1); //顯示光標右移設置,檢測忙信號
- WriteCommandLCM(0x0c,1); //顯示屏打開,光標不顯示,不閃爍,檢測忙信號
- /****顯示指定坐標的一個字符子函數****/
- Y&=0x01;
- X&=0x0f;
- if(Y)X|=0x40; //若y為1(顯示第二行),地址碼+0X40
- X|=0x80; //指令碼為地址碼+0X80
- WriteCommandLCM(X,1);
- WriteDataLCM(DData);
- int i = 0;
- unsigned char temp[5]={0};
- int number;
- number = (int)(num*10);
- //int number = 12345;
- temp[4] = number%10;
- temp[3] = '.';
- temp[2] = number/10%10;
- temp[1] = number/100%10;
- temp[0] = number/1000%10;
- DisplayOneChar(X+4,Y,temp[4]+'0');
- DisplayOneChar(X+3,Y,temp[3]);
- DisplayOneChar(X+2,Y,temp[2]+'0');
- DisplayOneChar(X+1,Y,temp[1]+'0');
- DisplayOneChar(X+0,Y,temp[0]+'0');
- if(temp[i]==0)
- for(i = 0;i<2;i++)
- if(temp[i]!=0)break;
- if(temp[i]==0)DisplayOneChar(X+i,Y,' ');
- int i = 0;
- int j = 1;
- int temp[7]={0};
- long number;
- number = (long)(num*100);
- temp[6] = number%10;
- temp[5] = number/10%10;
- temp[4] = '.';
- temp[3] = number/100%10;
- temp[2] = number/1000%10;
- temp[1] = number/10000%10;
- temp[0] = number/100000%10;
- DisplayOneChar(X+6,Y,temp[6]+'0');
- DisplayOneChar(X+5,Y,temp[5]+'0');
- DisplayOneChar(X+4,Y,temp[4]);
- DisplayOneChar(X+3,Y,temp[3]+'0');
- if(temp[i]==0)
- for(i = 0;i<3;i++)
- // for(i = 0;i<7;i++)
- // if(temp[i]==0)DisplayOneChar(X+i,Y,0);
- void Showfolat_3(uchar X,uchar Y,float num)
- int i = 0;
- int j = 1;
- int temp[7]={0};
- long number;
- number = (long)(num*1000);
- temp[4] = number/100%10;
- temp[3] = '.';
- if(temp[i]==0)
- // float voltage = 0;
- // float weight = 0;
- // float sensitivity = 0;
- DisplayOneChar(2,0,'U');
- DisplayOneChar(3,0,':');
- if(ShowWigherFlag==1)
- DisplayOneChar(9,0,'W');
- else DisplayOneChar(9,0,' ');
- DisplayOneChar(10,0,':');
- else DisplayOneChar(10,0,' ');
- DisplayOneChar(0,1,'S');
- else DisplayOneChar(0,1,' ');
- DisplayOneChar(1,1,':');
- else DisplayOneChar(1,1,' ');
- if(TestModeFlag==0)
- DisplayOneChar(0,0,'D');
- Showfolat_3(2,1,K_D);
- else{
- DisplayOneChar(2,1,' ');
- DisplayOneChar(3,1,' ');
- DisplayOneChar(4,1,' ');
- DisplayOneChar(5,1,' ');
- DisplayOneChar(6,1,' ');
- DisplayOneChar(7,1,' ');
- DisplayOneChar(8,1,' ');
- DisplayOneChar(9,1,' ');
- DisplayOneChar(10,1,' ');
- weight = (voltage - B_D)/K_D;
- if(voltage==0)weight = 0;
- }else if(TestModeFlag==1)
- DisplayOneChar(0,0,'B');
- Showfolat_3(2,1,K_B);
- else{
- weight = (voltage - B_B)/K_B;
- }else if(TestModeFlag==2)
- DisplayOneChar(0,0,'Q');
- Showfolat_3(2,1,K_Q);
- else{
- weight = (voltage - B_Q)/K_Q;
- Showfolat_1(4,0,voltage);
- Showfolat_1(11,0,weight);
- else
- DisplayOneChar(15,0,' ');
- DisplayOneChar(14,0,' ');
- DisplayOneChar(13,0,' ');
- DisplayOneChar(12,0,' ');
- DisplayOneChar(11,0,' ');
- DisplayOneChar(0,0,'W');
- DisplayOneChar(1,0,':');
- if(IsInput == 0)
- DisplayOneChar(8,0,'U');
- DisplayOneChar(9,0,'P');
- DisplayOneChar(0,1,'T');
- DisplayOneChar(1,1,'P');
- DisplayOneChar(2,1,':');
- weight = (voltage-Shelling)*2.0;
- TotalPrice = UnitPrice*weight;
- Showfolat_1(2,0,weight);
- Showfolat_2(3,1,TotalPrice);
- void KeyAction(unsigned char keycode)
- int i = 0;
- int j = 1;
- float k = 0.1;
- //IsExistPoint
- if(TestOrWeigher==0)//試驗模式
- if((keycode >= 0x00) &&(keycode <= 0x09))
- }else if(keycode == '.')
- }else if(keycode == 'E')
- TestOrWeigher = 1;
- //Showfolat_2(11,0,12.34);
- }else if(keycode == 'U')
- TestModeFlag--;
- } else if(keycode == 'D')
- TestModeFlag++;
- }else if(keycode == 'L')
- ShowWigherFlag = 0;
- WriteCommandLCM(0x01,0); //清顯示屏
- }else if(keycode == 'R')
- ShowWigherFlag = 1;
- if(TestModeFlag<=0)TestModeFlag = 0;
- if(TestModeFlag>=2)TestModeFlag = 2;
- if(IsInput)
- //DisplayOneChar(13,1,InputIndex+'0');
- switch(InputIndex)
- case 0:
- PriceArray[4] = keycode+'0';
- break;
- case 1:
- PriceArray[3] = PriceArray[4];
- break;
- case 2:
- PriceArray[2] = PriceArray[3];
- break;
- case 3:
- PriceArray[1] = PriceArray[2];
- break;
- case 4:
- PriceArray[0] = PriceArray[1];
- break;
- default:break;
- InputIndex++;
- if(InputIndex>4)InputIndex=5;
- //DisplayOneChar(0,1,keycode+'0');
- if(IsInput)
- case 0:
- PriceArray[4] = '.';
- break;
- case 1:
- break;
- case 2:
- break;
- case 3:
- break;
- case 4:
- break;
- default:break;
- IsExistPoint = InputIndex;
- InputIndex++;
- TestOrWeigher = 0;
- IsInput = 1;
- InputIndex = 0;
- for(i = 0;i<5;i++)
- PriceArray[i] = 0+'0';
- UnitPrice = 0;
- IsExistPoint = 5;
- if(PriceArray[i]=='.')
- IsExistPoint = i;
- break;
- for(i=IsExistPoint-1;i>=0;i--)
- UnitPrice += j*(PriceArray[i]-'0');
- j*=10;
- for(i=IsExistPoint+1;i<5;i++)
- UnitPrice += k*(PriceArray[i]-'0');
- k*=0.1;
- //Showfolat_2(3,1,UnitPrice);
- IsInput = 0;
- //DisplayOneChar(0,1,keycode);
- Shelling = voltage;
- Shelling = 0;
- // if(PriceArray[i]=='0')
- // DisplayOneChar(11+i,0,0);
- // else
- DisplayOneChar(11+i,0,PriceArray[i]);
- // if(PriceArray[0]==0)
- // for(i = 0;i<3;i++)
- // if(PriceArray[i]!=0)break;
- // if(PriceArray[i]==0)DisplayOneChar(11+i,0,' ');
- void KeyDriver()
- unsigned char i, j;
- static unsigned char backup [4][4] = {
- for(i=0; i<4; i++)
- for(j=0; j<4; j++)
- if(backup[i][j] != KeySta[i][j])
- if(backup[i][j] == 0)
- KeyAction(KeyCodeMap[i][j]);
- backup[i][j] = KeySta[i][j];
- /* 按鍵掃描函數,需在定時中斷中調用,推薦調用間隔1ms */
- void KeyScan()
- unsigned char i;
- static unsigned char keyout = 0; //矩陣按鍵掃描輸出索引
- static unsigned char keybuf[4][4] = { //矩陣按鍵掃描緩沖區
- {0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF},
- //將一行的4個按鍵值移入緩沖區
- keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN_1;
- keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN_2;
- keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN_3;
- keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN_4;
- //消抖后更新按鍵狀態
- for (i=0; i<4; i++) //每行4個按鍵,所以循環4次
- if ((keybuf[keyout][i] & 0x0F) == 0x00)
- { //連續4次掃描值為0,即4*4ms內都是按下狀態時,可認為按鍵已穩定的按下
- KeySta[keyout][i] = 0;
- else if ((keybuf[keyout][i] & 0x0F) == 0x0F)
- { //連續4次掃描值為1,即4*4ms內都是彈起狀態時,可認為按鍵已穩定的彈起
- KeySta[keyout][i] = 1;
- //執行下一次的掃描輸出
- keyout++; //輸出索引遞增
- keyout = keyout & 0x03; //索引值加到4即歸零
- switch (keyout) //根據索引,釋放當前輸出引腳,拉低下次的輸出引腳
- case 0: KEY_OUT_4 = 1; KEY_OUT_1 = 0; break;
- case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
- case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
- case 3: KEY_OUT_3 = 1; KEY_OUT_4 = 0; break;
- default: break;
- 讀ADC0832函數
- //采集并返回
- uchar Adc0832(unsigned char channel) //AD轉換,返回結果
- uchar i=0;
- uchar j;
- uint dat=0;
- uchar ndat=0;
- if(channel==0)channel=2;
- if(channel==1)channel=3;
- ADDI=1;
- _nop_();
- _nop_();
- ADCS=0;//拉低CS端
- _nop_();
- _nop_();
- ADCLK=1;//拉高CLK端
- _nop_();
- _nop_();
- ADCLK=0;//拉低CLK端,形成下降沿1
- _nop_();
- _nop_();
- ADCLK=1;//拉高CLK端
- ADDI=channel&0x1;
- _nop_();
- _nop_();
- ADCLK=0;//拉低CLK端,形成下降沿2
- _nop_();
- _nop_();
- ADCLK=1;//拉高CLK端
- ADDI=(channel>>1)&0x1;
- _nop_();
- _nop_();
- ADCLK=0;//拉低CLK端,形成下降沿3
- ADDI=1;//控制命令結束
- _nop_();
- _nop_();
- dat=0;
- for(i=0;i<8;i++)
- dat|=ADDO;//收數據
- ADCLK=1;
- _nop_();
- _nop_();
- ADCLK=0;//形成一次時鐘脈沖
- _nop_();
- _nop_();
- dat<<=1;
- if(i==7)dat|=ADDO;
- for(i=0;i<8;i++)
- j=0;
- j=j|ADDO;//收數據
- ADCLK=1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- j=j<<7;
- ndat=ndat|j;
- if(i<7)ndat>>=1;
- ADCS=1;//拉低CS端
- ADCLK=0;//拉低CLK端
差動橋智能電子秤畢設.zip
(125.6 KB, 下載次數: 38)
2018-7-5 18:03 上傳
1602+矩陣鍵盤+ADC0832 下載積分: 黑幣 -5
