查看: 1585|回復(fù): 0
沒有完成長按
ID:358998 發(fā)表于 2018-7-4 14:45 | 顯示全部樓層 |閱讀模式
#include "BS87D20A-3.h"
#define com1    _pc1
#define com2        _pc0
#define com3        _pc2
#define com4        _pc3
#define key1    _pd2
#define key2        _pd3
#define key3        _pa1
#define key4    _pa4
#define key_state_0        0   //按鍵的初始狀態(tài)
#define key_state_1        1   //按鍵按下的狀態(tài)
#define key_state_2        2   //按鍵釋放的狀態(tài)
volatile bit Flag_T5ms;
volatile bit Flag_T10ms;
volatile bit Flag_T1s;
const unsigned char tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char strtab[3];//緩沖區(qū)
unsigned char key_number=0;
//unsigned char sec=0,min=0,hour=0;
unsigned char temp;
unsigned long s;  //秒級
unsigned long ms10;//毫秒
unsigned long ms5;
unsigned char n;
unsigned char read_key(void)
    static char key_state=0 ;     //按鍵的狀態(tài)
    unsigned char key_press;       //按鍵是否被按下
        unsigned char key_return = 0;  //按鍵返回值
    key_press = key4;         // 讀按鍵I/O電?
    switch (key_state)
        case key_state_0:                 // 按鍵初始態(tài)
                if (!key_press)
                                if(Flag_T10ms)
                                        Flag_T10ms=0;
                                key_return = 0;
                                key_state = key_state_1;// 鍵被按下,狀態(tài)轉(zhuǎn)換到鍵確認(rèn)態(tài)
                else key_state = key_state_0;
                        break;
        case key_state_1:                   // 按鍵確認(rèn)態(tài)
            if (!key_press)
                    if(Flag_T10ms)
                            Flag_T10ms=0;
                key_return = 1;         // 按鍵仍按下,按鍵確認(rèn)輸出為“1”
                key_state = key_state_2;// 狀態(tài)轉(zhuǎn)換到鍵釋放態(tài)
                                key_state = key_state_0; // 按鍵已抬起,轉(zhuǎn)換到按鍵初始態(tài)
                                key_return = 0;
            break;
        case key_state_2:
            if (key_press)
                            key_state = key_state_0;//按鍵已釋放,轉(zhuǎn)換到按鍵初始態(tài)
                            key_return = 0;
            break;
return key_return;                //返回按鍵值
void displaypro()
        strtab[0]=tab[sec%10];
        strtab[1]=tab[sec/10];
        strtab[2]=tab[min%10];
        strtab[3]=tab[min/10];
void display_drive()
        com1=1;com2=1;com3=1;com4=1;
                    switch(temp)
                        case 0:com4=0;
                         _pb=strtab[temp]; break;
                        case 1:com3=0;
                        case 2:com2=0;
                        case 3:com1=0;
                        default:break;
                temp++;
                if(temp==4)
                        temp=0;
void init()
    _ctm0c0=0x20;  // fh/16   2us
        _ctm0c1=0xc1; // 定時/計數(shù)器模式 比較器a
        _ctm0al=0xf4; // 1ms
    _ctm0ah=0x01;
        _pbc=0; //輸出
        _pcc0=0;
        _pcc1=0;
        _pcc2=0;
        _pcc3=0;
        _pac1=1;
        _pac4=1;
        _pdc2=1;
        _pdc3=1;
        _pdpu3=1;
        _pdpu2=1;
        _papu1=1;
        _papu4=1;
        s=1000;
        ms10=10;
        ms5=5;
        temp=0;
        n=0;
        _mfe=1; //開多功能中斷
    _ctm0ae=1; //CTM a中斷使能
        _emi=1;        //開總中斷
        _ct0on=1; //開定時器
                init();
                        if(Flag_T5ms)
                                Flag_T5ms=0;
                        if(Flag_T1s)
                                Flag_T1s=0;
                                displaypro();
                        if(Flag_T10ms)  //10MS進(jìn)入一次
                                read_key();
                                key_number=read_key();//調(diào)用按鍵掃描函數(shù),取得按鍵值,5MS調(diào)用一次
                        if(key_number==1)
                                n++;
                                _pb=tab[n];
                                Flag_T10ms=0;
                        GCC_CLRWDT();
                        com1=1;com2=1;com3=0;com4=0;
        void __attribute__((interrupt(0x14))) ISR_CTMO(void)
                _ctm0af=0;
                s--;
                ms5--;
                ms10--;
                  if(! ms5)
                        ms5=5;//5MS 視覺暫留
                        Flag_T5ms=1;
                if(!ms10)
                        ms10=10;
                        Flag_T10ms=1;
                if(! s)
                        Flag_T1s=1;
                        s=1000;//1s電子鐘計數(shù)
                        sec++;
                if(sec==60)
               sec=0;
               min++;
               if(min==60)
                min=0;
                 hour++;
                 if(hour==24)
                  hour=0;
參與人數(shù) 1黑幣 +50 收起 理由
