C51單片機六位數碼管時鐘 用數碼管dot分隔時分秒 用三個按鍵設置時間: SET鍵:小時設定->分鐘設定->結束設定,小時設定狀態時表示小時的兩位數碼管閃爍,分鐘設定時表示分鐘的兩位數碼管閃爍 CHANGE鍵:在小時設定狀態和分鐘設定狀態改變數值 SET S鍵:秒置零
20160922120743121 .jpg (641.23 KB, 下載次數: 40)
2018-7-2 23:41 上傳
C語言代碼: //main.c - #include <REGX52.H>
- typedef unsigned int UINT ;
- typedef unsigned char UCHAR ;
- #define KEY P2
- #define KEYMASK 0x07
- sbit LE1 = P2^6; //定義位控口
- sbit LE2 = P2^7; //定義段控口
- UCHAR KeyPressDown = 0x00;
- UCHAR KeyRelease = 0x00;
- UCHAR LastKey = 0x00;
- UCHAR MODE ;
- extern UCHAR HH;
- extern UCHAR MM;
- extern UCHAR SS;
- extern bit T_CYCLE ;
- extern void T0_Init(void); //初始化定時器,函數定義在Timer.c
- UCHAR code NUM[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- void delay(UINT t) //延時t時鐘周期
- while (t--) ;
- void H_Increase(void) //小時增1
- if(HH<23) HH++;
- else
- HH = 0;
- void M_Increase(void) //分鐘增1
- if(MM<59) MM++;
- else
- MM = 0;
- H_Increase();
- void S_Increase(void) //秒增1
- if(SS<59) SS++;
- else
- SS = 0;
- M_Increase();
- void display(UCHAR SEG,UCHAR Digi) //顯示一位數碼管,SEG = 0-9數字,Digi = 第0-6位
- LE2 = 1;
- P0 = (0x01<<Digi) ;
- LE2 = 0;
- P0 = 0x00;
- LE1 = 1;
- P0 = NUM[SEG];
- if (Digi==1||Digi==3) P0 &= 0x7f ; //顯示分隔符
- delay(50);
- P0 = 0xff;
- LE1 = 0;
- void main(void)
- P0 = 0xff;
- LE1 = 0;
- LE2 = 0;
- T0_Init();
- while(1)
- if(MODE != 1 || T_CYCLE)
- display(HH/10,0); //顯示小時十位數
- display(HH%10,1); //顯示小時個位數
- if(MODE != 2 || T_CYCLE)
- display(MM/10,2); //顯示分鐘十位數
- display(MM%10,3); //顯示分鐘個位數
- display(SS/10,4); //顯示秒十位數
- display(SS%10,5); //顯示秒個位數
- void key_Process(void) //按鍵處理程序
- UCHAR CurrKey;
- KEY |= KEYMASK; //將按鍵對應的IO設置為輸入狀態
- CurrKey = (~KEY) & KEYMASK;
- KeyPressDown = (~LastKey) & CurrKey;
- KeyRelease = LastKey & (~CurrKey);
- LastKey = CurrKey;
- switch(KeyRelease)
- case 1:
- if(MODE == 2) MODE = 0;
- else MODE ++;
- break;
- case 2:
- if(MODE == 1) H_Increase() ;
- if(MODE == 2) M_Increase() ;
- break;
- case 4:
- SS = 0;
- break;
- default: break;
- //Timer#include <reg52.h>
- UCHAR HH = 14; //小時初始值
- UCHAR MM = 2; //分鐘初始值
- UCHAR SS = 55; //秒初始值
- UINT u_10ms = 0; //10ms計數
- bit T_CYCLE = 0;
- extern void key_Process(void);
- extern void S_Increase(void);
- void T0_Init(void)
- TMOD &= 0xf0;
- TMOD |= 0x01;
- //定時器賦初始值,定時時間為10ms。
- TH0 = 0xd8;
- TL0 = 0xf0;
- TR0 = 1;
- IE = 0x82;
- void T0_INTSrv(void) interrupt 1
- //定時器重新開始計時。
- TH0 = 0xd8;
- TL0 = 0xf0;
- u_10ms ++;
- if (u_10ms%20==0) // 200 ms
- T_CYCLE = ! T_CYCLE; //閃爍循環
- if (u_10ms>99) // 1000 ms = 1 second
- u_10ms = 0;
- S_Increase();
- key_Process(); //SET按鍵處理
