查看: 4681|回復: 0
單片機初學入門INT0中斷數碼管計數0到99
分享設計:
大神不吐槽哈,這是實訓時的作業設計。
大神們若有學習的好建議一起分享哦
源程序:
#include<reg51.h>
uchar code DSY_CODE[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
uchar Display_Buffer[3]={0,0,0};
uint Count = 0;
sbit Clear_Key = P3^6;
void Show_Count_ON_DSY()
  Display_Buffer[1] = Count % 100/10;
  Display_Buffer[0] = Count %10;
  if(Display_Buffer[1] == 0)
    Display_Buffer[2] = 0x0a;
    if(Display_Buffer[1] == 0 ) Display_Buffer[1] = 0x0a;
P1=DSY_CODE[Display_Buffer[0] ];
P2=DSY_CODE[Display_Buffer[1] ];
P0=0xff;
P1=0xff;
P2=0xff;
IE=0x81;
IT0=1;
if(Clear_Key==0)
  Count = 0;
   Show_Count_ON_DSY();
void EX_INT0() interrupt 0
Count++;
全部資料51hei下載地址:
計數c源程序和仿真程序.zip (17.56 KB, 下載次數: 34)
