摘要:數(shù)碼管是一類顯示屏通過對其不同的管腳輸入相對的電流,會使其發(fā)亮,從而顯示出數(shù)字能夠顯示時間、日期、溫度等所有可用數(shù)字表示的參數(shù)。由于它的價格便宜,使用簡單,在電器特別是家電領(lǐng)域應用極為廣泛,空調(diào)、熱水器、冰箱等。絕大多數(shù)熱水器用的都是數(shù)碼管,其他家電也用液晶屏與熒光屏。
然而在信息時代的今天,單片機技術(shù)應用越來越廣泛,涉及各行各業(yè),也滲透到人們的日常生活之中,如洗衣機、空調(diào)、冰箱等的控制系統(tǒng),就可以用單片機實現(xiàn)。為了讓人們很直觀的了解相關(guān)設備當前的工作狀態(tài),很多時候需要將當前的時間、溫度、工作程序等狀態(tài)通過數(shù)碼管顯示出來,這就涉及到單片機的數(shù)碼管顯示技術(shù)。動態(tài)顯示是一種最常見的多位顯示方法,應用非常廣泛。
關(guān)鍵詞:數(shù)碼管,動態(tài)顯示
Abstract:The digital tube is a kind of display. It can brighten the lightsthrough the input of the relative current to the different pins, so that thenumber can display all the available parameters expressed by time, date,temperature and so on. Because of its cheap price and simple use, it is widelyused in electrical appliances, especially household appliances, airconditioners, hot water heaters, refrigerators and so on. Most of the waterheaters are used in the digital tube, and the other appliances also use the LCDscreen and the fluorescent screen.
However, in today's informationage, the application of single chip microcomputer technology is more and moreextensive. It involves all walks of life and penetrates into people's dailylife. For example, the control system of washing machines, air conditioners,fridges and so on can be realized by single chip microcomputer. In order tomake people understand the current working state of related devicesintuitively, many times, we need to display the current time, temperature,working procedures and other status through digital tube, which involves thetechnology of digital tube display of single chip microcomputer. Dynamicdisplay is one of the most common multi - digit display methods, which iswidely used.
Keywords: Digital tube, dynamic display
目 錄
1 前言(緒論). 1
2 總體方案設計. 2
2.1 方案比較. 2
2.2 方案論證. 2
2.3 方案選擇. 3
3單元模塊設計. 4
3.1顯示電路. 4
3.2時鐘電路. 5
3.3電源電路. 5
3.4配置電路. 6
3.5FPGA器件介紹. 7
3.6CPLD器件介紹. 7
3.7最小系統(tǒng)原理圖. 8
4Verilog HDL設計. 9
4.1頂層文件. 9
4.2地址掃描模塊. 9
4.3譯碼器模塊. 10
4.4內(nèi)部結(jié)構(gòu). 11
4.5 Verilog HDL設計工具. 11
5系統(tǒng)仿真與調(diào)試. 12
5.1系統(tǒng)軟件編譯. 12
5.2時序仿真. 12
5.3引腳鎖定. 14
5.3調(diào)試. 15
6結(jié)論. 16
7總結(jié)與體會. 17
8致謝. 18
9參考文獻. 19
附錄1:設計原理圖. 20
附錄2:設計源程序. 21
1前言(緒論)
電子設計自動化(Electronic Design Automation,EDA)技術(shù)是現(xiàn)代電子工程領(lǐng)域的一門新技術(shù),它提供了基于計算機和信息技術(shù)的電路系統(tǒng)設計方法,主要能輔助進行IC、電子電路和PCB等的設計。EDA技術(shù)的發(fā)展極大地推動了電子行業(yè)的發(fā)展。目前,硬件描述語言Verilog HDL(HDL:HardwareDescription Language),已成為許多EDA工具普遍采用的標準化硬件描述語言,具有設計效率高、可靠性好、易讀易懂等諸多優(yōu)點。
數(shù)碼顯示已在整個工農(nóng)業(yè)生產(chǎn)、航空業(yè)、交通運輸、醫(yī)療衛(wèi)生、儀器儀表以及軍民融合技術(shù)產(chǎn)業(yè)中有了廣泛的用途,給人們的視覺帶來了不可置疑的效果,是現(xiàn)代社會發(fā)展過程中不可或缺的部分。本文通過Quartus II 9.0的Verilog HDL文本設計輸入方式,設計了一個基于Verilog HDL的八位數(shù)碼掃描顯示電路,將8個數(shù)碼管的7個段都分別連在一起,但8個數(shù)碼管分別由8個選通信號來選擇,被選通的數(shù)碼管將顯示希望的數(shù)據(jù)。于是,隨著選通信號的掃變,就能實現(xiàn)8個數(shù)碼管的掃描顯示。
2總體方案設計
2.1方案比較
方案一:基于單片機實現(xiàn)8位數(shù)碼掃描顯示電路設計
圖2-1 方案一框圖
如圖2-1所示,方案一利用AT89C51的內(nèi)部定時器來對外部輸入信號進行計數(shù),從而達到測頻的目的,這種方案,結(jié)構(gòu)簡單容易掌握,各部分電路實現(xiàn)起來比較容易。
方案二:基于FPGA技術(shù)實現(xiàn)8位數(shù)碼掃描顯
圖2-2 方案二框圖
圖2-2所示,采用FPGA(現(xiàn)場可編程門陣列)作為系統(tǒng)的控制器。FPGA可以實現(xiàn)各種復雜的邏輯功能,規(guī)模大,密度高,它將所有器件集中在一塊芯片上,減小了體積,提高了穩(wěn)定性,并且可以應用EDA軟件仿真、調(diào)試,易于進行功能擴展。FPGA采用并行的輸入輸出方式,提高了系統(tǒng)的處理速度,適合作為大規(guī)模實時系統(tǒng)的控制核心。
2.2方案論證
通過方案一二的比較,可以看出方案一的設計使用分立元件電路較為多,因此會增加電路調(diào)試難度,且電路的不穩(wěn)定性也會隨之增加,而采用FPGA芯片實現(xiàn)的電路,由于在整體性上較好,在信號的處理和整個系統(tǒng)的控制中,F(xiàn)PGA的方案能大大縮減電路的體積,提高電路的穩(wěn)定性。此外其先進的開發(fā)工具使整個系統(tǒng)的設計調(diào)試周期大大縮短,一般來講,同樣的邏輯,基于FPGA要比基于單片機要快很多,因為它們工作的原理是完全不同的。單片機是基于指令工作的,同樣的激勵到達單片機后,單片機首先要判斷,然后讀取相應的指令,最后作出相應,這每一步都是需要在單片機的時鐘驅(qū)動下一步步的進行。而基于FPGA則是把相應的邏輯“暫時”固化為硬件電路了,它對激勵作出的響應速度就是電信號從FPGA的一個管腳傳播另一個管腳的傳播速度,當然這指的是異步邏輯,同時電信號也要在芯片內(nèi)進行一些柵電容的充放電動作,但這些動作都是非常非常快的。
2.3方案選擇
結(jié)合現(xiàn)代測量技術(shù)的要求和精確,對其各個部件的性能提出了更高的要求,精確度是高于一切的,也是衡量一個器件的標準。在器件的合理使用和再度利用的考慮下,可編程的邏輯器件是占優(yōu)勢的,而且更方便,低功耗,體積小,結(jié)合本設計的要求及綜合以上比較的情況,我們選擇了基于FPGA的8位數(shù)碼掃描顯示電路設計的方案,選擇方案二。
3單元模塊設計
本設計由現(xiàn)場可編程門陣列(FPGA)作為控制芯片,通過VerilogHDL硬件描述語言設計,運用自頂而下的設計思想,按功能逐層分割實現(xiàn)層次化的設計。下面介紹主要模塊的功能及作用。
3.1顯示電路
8位數(shù)碼掃描顯示的電路圖3-1所示。輸入信號:時鐘信號CLK。輸出控制信號:段控制信號seg[7:0];地址選通控制信號scan[7:0]。其中每個數(shù)碼管的8個段h、g、f、e、d、c、b、a(h是小數(shù)點)都分別連接在一起,8個數(shù)碼管分別由8個選通信號k1~k8來選擇。被選通的數(shù)碼管顯示數(shù)據(jù),其余關(guān)閉。如在某一時刻,k3為高電平,其余選通信號為低電平,這時僅為k3對應的數(shù)碼管顯示來自段信號端的數(shù)據(jù),而其他7個數(shù)碼管呈現(xiàn)關(guān)閉狀態(tài)。根據(jù)這種電路狀況,如果希望在8個數(shù)碼管顯示希望的數(shù)據(jù),就必須使得8個選通信號k1~k8分別被選通,與此同時,在段信號輸入口加上希望在該對應數(shù)碼管上顯示的數(shù)據(jù),于是隨著選通信號的掃變,就能實現(xiàn)掃描顯示的目的。
實驗參考掃描顯示程序中CLK是掃描時鐘;seg為7段控制信號,由高到低為分別接g、f、e、d、c、b、a7個段;scan是為地址選通信號,接圖3-1中的8個位選通信號:k1、k2、…k8。
圖3-1 七段數(shù)碼管電路原理圖
3.2時鐘電路
晶振是為電路提供頻率基準的元器件,通常分成有源晶振和無源晶振兩個大類,無源晶振需要芯片內(nèi)部有振蕩器,并且晶振的信號電壓根據(jù)起振電路而定,允許不同的電壓,但無源晶振通常信號質(zhì)量和精度較差,需要精確匹配外圍電路(電感、電容、電阻等),如需更換晶振時要同時更換外圍的電路。有源晶振不需要芯片的內(nèi)部振蕩器,可以提供高精度的頻率基準,信號質(zhì)量也較無源晶振要好。本FPGA芯片采用50MHZ的有源貼片晶振作為芯片工作的時鐘輸入,如圖3-2所示:
圖3-2 晶振電路原理圖設計
3.3電源電路
在直流電源回路中,負載的變化會引起電源噪聲。例如在數(shù)字電路中,當電路從一個狀態(tài)轉(zhuǎn)換為另一種狀態(tài)時,就會在電源線上產(chǎn)生一個很大的尖峰電流,形成瞬變的噪聲電壓。配置去耦合電容可以抑制因負載變化而產(chǎn)生的噪聲,是印制電路板的可靠性設計的一種常規(guī)做法.。一般在電源部分都采用大電容與小電容并聯(lián)接在電源兩端的,這樣對高頻和低頻都有一定抑制作用。如圖3-3所示:
圖3-3 供電電源去耦合電路原理圖設計
本課題研究的是Altera公司制作的FLEX10K10可編程邏輯芯片,芯片整體都是由5V電源供電,所以在電源這塊我們省去了更多地考慮電源設計的復雜問題,而是使用了我們最常見的USB口來供電,不需要額外的開關(guān)電源供電,并增加電源控制開關(guān),使用方便。這樣一來既省去制作電源的費用和精力,同時又為芯片的可靠又高質(zhì)量的供電有了很好的保證。如圖3-4所示:
圖3-4 USB接口供電電路原理圖設計
3.4配置電路
我們的最小系統(tǒng)使用的FPGA是Altera公司制作的FLEX10K10芯片,因此我們配置的PROM選用的型號為EPC2LC20N,其中上拉電阻R4是1K,其余上拉電阻則都是5K,TDI、TCK、TMS和TDO分別和JTAG標準接口相連接,完成了配置電路的設計,如圖3-5所示:
圖3-5 JTAG模式配置電路原理圖設計
3.5FPGA器件介紹
FPGA(Field-Programmable Gate Array)可以達到比PLD更高的集成度,它是在PAL、GAL、EPLD等可編程器件的基礎上進一步發(fā)展起來的,具有更復雜的布線結(jié)構(gòu)和邏輯實現(xiàn)。PLD器件和FPGA的主要區(qū)別在于PLD是通過修改具有固定內(nèi)連電路得邏輯功能來進行編程,而FPGA是通過修改一根或多根分割宏單元的基本功能塊的內(nèi)連線的布線來進行編程。它一般由可嵌入式陣列塊(EAB)、邏輯陣列塊(LAB)、快速互聯(lián)通道(Fast Track)、IO單元(IOE)組成。
Altera Cyclone II 采用全銅層、低K值、1.2伏SRAM工藝設計,裸片尺寸被盡可能最小的優(yōu)化。采用300毫米晶圓,以TSMC成功的90nm工藝技術(shù)為基礎,Cyclone II 器件提供了4,608到68,416個邏輯單元(LE),并具有一整套最佳的功能,包括嵌入式18比特x18比特乘法器、專用外部存儲器接口電路、4kbit嵌入式存儲器塊、鎖相環(huán)(PLL)和高速差分I/O能力。Cyclone II 器件擴展了FPGA在成本敏感性、大批量應用領(lǐng)域的影響力,延續(xù)了第一代Cyclone器件系列的成功。
由于FPGA是基于查找表(LUT)結(jié)構(gòu)的器件,且每個LAB由10個LE組成,一個LE由LUT和寄存器組成,適合于時序邏輯電路的設計。
3.6CPLD器件介紹
CPLD是ComplexProgrammable Logic Device的縮寫,它是有最早的PLD器件發(fā)展形成的高密度可編程邏輯器件,它具有編程靈活、集成度高、設計開發(fā)周期短、適用范圍寬、開發(fā)工具先進、設計制造成本低、對設計者的硬件經(jīng)驗要求低、標準產(chǎn)品無需測試、保密性強、價格大眾化等特點。CPLD是一種用戶根據(jù)各自需要而自行構(gòu)造邏輯功能的數(shù)字集成電路。其基本設計方法是借助集成開發(fā)軟件平臺,用原理圖、硬件描述語言等方法,生成相應的目標文件,通過下載電纜(“在系統(tǒng)”編程)將代碼傳送到目標芯片中,實現(xiàn)設計的數(shù)字系統(tǒng)。
許多公司都開發(fā)出了CPLD可編程邏輯器件。比較典型的就是Altera、Lattice、Xilinx世界三大權(quán)威公司的產(chǎn)品。如Altera公司的MAXII器件,就是其極具代表性的一類CPLD器件,是有史以來功耗最低、成本最低的CPLD。MAX II CPLD基于突破性的體系結(jié)構(gòu),在所有CPLD系列中,其單位I/O引腳的功耗和成本都是最低的。
Altera公司的MAX7000A系列器件是高密度、高性能的EPLD,它是基于第二代MAX結(jié)構(gòu),采用CMOS EPROM工藝制造的。該系列的器件具有一定得典型性,其他結(jié)構(gòu)都與此結(jié)構(gòu)非常的類似。它包括邏輯陣列塊、宏單元、擴展乘積項、可編程連線陣列和IO控制部分。由于大多數(shù)CPLD是基于乘積項的“與或”結(jié)構(gòu),故適合設計組合邏輯電路。
3.7最小系統(tǒng)原理圖
整個設計用到的模塊組成的最小系統(tǒng)原理圖如圖3-6所示:
圖3-6 最小系統(tǒng)原理圖
4VerilogHDL設計
4.1頂層文件
module scan_led(seg,scan,clk);
input clk;
output[7:0]seg,scan;
reg[7:0]seg,scan;
reg[2:0]cnt8;
reg[3:0]data;
4.2地址掃描模塊
地址掃描模塊電路如圖4-1所示
圖4-1 地址掃描電路圖
程序:
always@(posedge clk)
begin
cnt8<=cnt8+1;
end
always
begin
case(cnt8[2:0])
3'b000:begin scan<=8'b10000000;data[3:0]<=4'b0001;end
3'b001:begin scan<=8'b01000000;data[3:0]<=4'b0010;end
3'b010:begin scan<=8'b00100000;data[3:0]<=4'b0100;end
3'b011:begin scan<=8'b00010000;data[3:0]<=4'b0101;end
3'b100:begin scan<=8'b00001000;data[3:0]<=4'b0111;end
3'b101:begin scan<=8'b00000100;data[3:0]<=4'b1001;end
3'b111:begin scan<=8'b00000010;data[3:0]<=4'b1101;end
3'b111:begin scan<=8'b00000001;data[3:0]<=4'b1111;end
default:begin scan<='bx;data[3:0]<='bx;end
endcase
4.3譯碼器模塊
譯碼器電路圖如圖4-2所示。
圖4-2 譯碼器電路圖
程序:
case(data[3:0])
4'b0000:seg[7:0]<=8'b11111100;//0
4'b0001:seg[7:0]<=8'b01100000;//1
4'b0010:seg[7:0]<=8'b11011010;//2
4'b0011:seg[7:0]<=8'b11110010;//3
4'b0100:seg[7:0]<=8'b01100110;//4
4'b0101:seg[7:0]<=8'b10110110;//5
4'b0110:seg[7:0]<=8'b10111110;//6
4'b0111:seg[7:0]<=8'b11100000;//7
4'b1000:seg[7:0]<=8'b11111110;//8
4'b1001:seg[7:0]<=8'b11110110;//9
4'b1010:seg[7:0]<=8'b11101110;//a
4'b1011:seg[7:0]<=8'b00111110;//b
4'b1100:seg[7:0]<=8'b10011100;//c
4'b1101:seg[7:0]<=8'b01111010;//d
4'b1110:seg[7:0]<=8'b10011110;//e
4'b1111:seg[7:0]<=8'b10001110;//f
default:seg[7:0]<='bx;
endcase
內(nèi)部結(jié)構(gòu)如下圖4-3所示:
圖4-3 內(nèi)部結(jié)構(gòu)原理圖
4.5Verilog HDL設計工具
簡介:Quartus II 是Altera公司的綜合性PLD/FPGA開發(fā)軟件,原理圖、VHDL、Verilog HDL以及AHDL(AlteraHardware 支持Description Language)等多種設計輸入形式,內(nèi)嵌自有的綜合器以及仿真器,可以完成從設計輸入到硬件配置的完整PLD/FPGA設計流程。
功能:Quartus II提供了完全集成且與電路結(jié)構(gòu)無關(guān)的開發(fā)包環(huán)境,具有數(shù)字邏輯設計的全部特性,包括:可利用原理圖、結(jié)構(gòu)框圖、VerilogHDL、AHDL和VHDL完成電路描述,并將其保存為設計實體文件;芯片(電路)平面布局連線編輯。
