查看: 7544|回復: 0
單片機兩位電子秒表源碼+仿真
兩位電子秒表
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. sbit K1 = P3^7;
  5. uchar i,s=0,Key_Flag_Idx=0,shi=0,ge=0;
  6. bit Key_State;
  7. uchar DSY_CODE[]=
  8. {
  9.         0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
  10. };
  11. void DelayMS(uint ms)
  12. {
  13.         uchar t;
  14.         while(ms--)
  15.         {
  16.                  for(t=0;t<120;t++);
  17.         }
  18. }
  19. void qidong()
  20. {
  21.   for(i=1;i<=10;i++)
  22.   {DelayMS(100);
  23.    if(Key_State != K1)
  24.     {
  25.           DelayMS(10);
  26.           Key_State = K1;
  27.           if(Key_State == 0)
  28.             {
  29.               Key_Flag_Idx=(Key_Flag_Idx+1)%3;
  30.                   return;
  31.                 }
  32.         }
  33.    }
  34.          ge=(ge+1)%10;
  35.          if(ge==0)shi=shi+1;
  36.          if(shi==6)shi=0;
  37.
  38. }
  39. void zhanting()
  40. {
  41.   while(Key_Flag_Idx==2)
  42.   {if(Key_State != K1)
  43.     {
  44.           DelayMS(10);
  45.           Key_State = K1;
  46.           if(Key_State == 0)
  47.             {
  48.               Key_Flag_Idx=(Key_Flag_Idx+1)%3;return;
  49.                 }
  50.     }
  51.    }
  52. }
  53. void main()
  54. {
  55.         P0 = 0x3f;
  56.         P2 = 0x3f;
  57.         Key_State = 1;        //P3.7引腳的初始狀態為1
  58.
  59.         while(1)
  60.         {
  61.                  if(Key_State != K1)//若P3.7引腳值有變化,其中K1為P3.7引腳值
  62.                 {
  63.                          DelayMS(10);//消抖
  64.                         Key_State = K1;        //將當前P3.7值賦給Key_State變量
  65.                   if(Key_State == 0) //若當前P3.7值為0,即若有按鍵按下
  66.               {
  67.                     Key_Flag_Idx=(Key_Flag_Idx+1)%3; //按鍵按下次數為...
  68.                    }
  69.                  }
  70.                       switch(Key_Flag_Idx)
  71.                       {
  72.                              case 1:qidong();break;
  73.                             case 2:zhanting();break;
  74.                             case 0:shi=0;ge=0;
  75.                       }
  76.
  77.             P0 = DSY_CODE[shi];
  78.                 P2 = DSY_CODE[ge];
  79.    }
  80.   }
秒表.zip (57.24 KB, 下載次數: 23)
